build a lcd projector
lcd projector
okay, so here’s my idea. i’ll use a portable media as the lcd for this “do it yourself” lcd projector. even if it’s not the best quality, i really don’t mind, i’m going to do make a little art installation here at hack central. think it’ll work?
Comments
  1. ShiftClick says:
  2. tim says:
    Yeah I was going to recommend Tom’s hardware guide too – it’s nicely done & cheap, but it takes up a ton of room, and I’m unsure how quiet it is when you are watching movies ;-)
  3. tim says:
  4. Fabulo says:
    It should work fine except maybe for dim images. LCD/DLP projectors usually have 7 trillions watt lamps, spuing out zillions of lumens in order to project a bright enough image on the screen.
    A pmp will probably not be very bright on the wall. the backlight is not gonna be bright enough.
    If you’re not scared, you can take it apart, ditch the week backlight and replace it with a homebrewed 1000000 watts lamp. Or an overhead projector, whatever is more convenient.
  5. Sam seide says:
    Yes it does work. I have one set up in my house now. Check out:
    http://www.diyaudio.com/forums/forumdisplay.php?s=77413c0bca082ea92db84756be067aa0&forumid=20
    as there are lots of people that have made these and a bunch posts results there.
  6. Chris says:
    I would like to second the vote for http://www.diyaudio.com web forums. There is a LOT of information there on how to build a lcd projector as well as a lot of people who are currently running/building them.
  7. Rightcoast says:
    I am building one as well, and using the lumenlab forums as a fantastic support tool for this. They have a great gallery of ones that people built. The diyaudio.com forums are very good as well
  8. Rightcoast says:
  9. Evan Zaker says:
    sounds like a great idea. This is the whole idea behind the LCD projector. I am very interested in the suggestions and the complications of actually making this. Right now, I have a broken 17″ LCD that I wish to use for a projector.
    All of the ones that I have seen are using the overhead/dry-erase projectors. Which is fine, but they won’t fit a 17″. I might work on moving the lens around to use all of the 17″ panel.. it’ll get the best quality. otherwise, I guess I’ll just manually size my screen down to fit the viewable.
  10. X says:
    1 million watts? No LCD monitor even begins to take up a million watts. That’s 70 dollars an hour worth of electricity! 7 trillion watts would cost 4 900 000 000 dollars an hour to run, and would trash your local power grid. Next time research what ur talking about before u say it.
  11. Phill says:
    Does anyone know if I can get lens sets from a UK supplier ? DIYprojectors seems to be the only place to get them, Don’t like the idea of shipping pieces of glass from the states. Just started my build, using a 300w security light(!)with a 230v metal fan (!) does anyone know what temperature you start to do damage to your LCD ? one of those questions that can only be answered after a costly mistake, don’t fancy finding out the hard way..
    many thanks
    Phil
  12. Great blog I also have a blog like you but just for lcd projectors and have always wondered if you can actually build your own, drop by my site if you have a minute or two…
    Do you still use and watch movies with your home built LCD projector?
  13. Allen says:
    Guys. if interested in projectors, this site has good pricing http://www.saveonprojectors.com
  14. donu gameli says:
    i want to make my owm LcD projector but i dont have access to lcd and fresnel lenses.who will help me?
  15. chris says:
    ar you seling thows home made projectors if not i was going to make one ok would this mini 3.5″ lcd screen work that i got ??
  16. Hosea says:
    Am having a school project where i have to incoporate a webcam to make/manufacture a webcam projector using a combinations of mirrors to project a laptop screen on a laptop onto a white board at a distance. Is there anyone who has an ideal on how to go about this please.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
