Enable Bluetooth Headsets On Ipaqs
enable bluetooth headsets on ipaqs
here’s one hack a day pal lars sent in…
there is a reg. key you can edit to enable bluetooth headsets on ipaq.
put 1 insted of 0 in:
HKeyLocalMchineSOFTWAREWidcommBtConfigServices005Enabled=1
and add a DWORD Enabled=1 Enabled=1 to
HKeyLocalMchineSOFTWAREWidcommBtConfigServices006
and also there is a key in softwaremediaplayer that has somthing in the lines of play unsupported=0 (off) enabeling it must do something but i dont know what,but i supose U people could figure it out.
so if you have a bluetooth headset for your phone and have a bluetooth ipaq, there’s a good chance you can use your headset to listen to audio through the headset.
26 thoughts on “Enable Bluetooth Headsets On Ipaqs
  1. I have an Audiovox XV6600. (Not the same as an iPaq, but runs WM2k3se just the same.) My Services folder in the registry only has 4 services. There’s no 5 to change the dword in. Also, “Enabled=1” isn’t a dword I see anywhere in my reg.
  2. There’s a reason it’s not enabled by default – the quality stinks (at least it does on my 2200 series). Which is too bad – the headset profile is available by default on my new X50v, and it sounds pretty good.
  3. I just found this site and am lost with the above directions. I want to listen to my audio via a “paired” Nokia Model 0277663 Bluetooth Headset. Can someone point me in a more detailed direction for instructions?
    Thank you!
  4. If anyone figures out the registry setting for enabling audio streaming to a bluetooth headset under Windows Mobile SE, it would be a great service to the world. I listen to audiobooks and couldn’t care less about the sound quality but to be free of wires would be a great thing!
    I hope this topic stays alive and some brilliant hacker comes up with a solution. (By the way, I use an i-mate Jam, tried this iPaq 6315 but this is a thousand times better)
  5. This hack is included in Tweaks2k2 .NET but it only works in a few iPaqs (5400 is one of them) in the majority of them the sound quality is very bad and I said VERY BAD.
    BTW, I don’t think that this hack in needed in any other brand.
  6. I’m travelling in the U.S. right now (natively, I’m a Canuck) without my BT headset. As soon as I get back I’m going to give this a try. I would love to cut the wires I wear everyday.
    I’ll let you know if it works.
    Question: What happens if my phone rings when I am listening to an audio book? Can I pause and answer and then go back or is it a choice of one audio source or the other?
  7. I’m travelling in the U.S. right now (natively, I’m a Canuck) without my BT headset. As soon as I get back I’m going to give this a try. I would love to cut the wires I wear everyday.
  8. it worked for my ipaq5450
    but the sound quality suck soo bad
    i am using Sony Ericsson HBH-660 (the one with LCD screen)
    the play unsupported=0 (off)
    doesnt reli matter…both worked (on and off)
  9. play unsupported=0 in the media player reg settings is for the option “play unsupported file types”, so you can play an mp3 that you have just changed the exetension of (eg *.mp3 => *.1337)
    helps for avi files with windows media content
  10. I wasn’t able to get this hack to work with my iPAQ 4150. Is this a type-o, add a DWORD Enabled=1 Enabled=1 ?
    You just add it once, right??
    My headset will pair, and it discovers the headset service. When I try to connect, it fails with the following error:
    Unable to initiate the bluetooth connection (Error code:0x81000006).
    Any ideas??
  11. Работаю менеджером. Хочу сделать интернет магазин. Порекомендуйте человека или организацию, кто поможет мне в этом. Главное чтоб человек, который его делает был адекватный и недорого.
  12. Tired of a competitor’s site? Hinder the enemy? Fed pioneers or copywriters?
    Kill their sites! How? We will help you in this!
    Obstructions of any site, portal, shop!
    Different types of attacks: Date-attack, Trash, Attack, Attack, etc. Intellectual
    You can work on schedule, as well as the simultaneous attack of several sites.
    On average the data, ordered the site falls within 5 minutes after the start. As a demonstration of our capabilities, allows screening.
    Our prices
    24 hours of attack – $ 70
    12 hours of the attack – $ 50
    1 hour attack – $ 25
    Contact via ICQ: 588 666 582
Leave a Reply to Da_BlitzCancel reply
