14 thoughts on “Hackaday Links
  1. Soldering a printer cable to an LCD is “kicking our ass at technology?” Geez, they don’t even know how to solder properly. You thread the wire through the hole (that’s what the hole is there for) and put the iron on the pad so it touches the pad and the bare wire, give it a few seconds to heat the wire and pad, then apply the solder.
  2. I made the lcd today, it is insane for winamp stuff, but I did it with a backlit lcd out of a photocopier of all things. I am only able to get 8 charactors. Is it because I did a 4 bit interface
Leave a Reply to Matt SmithCancel reply
