Cheap GPS receiver
gps
Here’s a short guide for converting a Palm III GPS sled into a normal serial GPS receiver. The Palm III is old tech so its accessories can be picked up cheap and modified for other purposes. The GPS receiver needs to be separated from the Palm specific board and a few components need to be transfered between the two. Once that’s done you should have a standard serial GPS receiver. Here’s a cache in case the “Read” link fails.
[thanks nevamore, who has done this hack with success]
Comments
  1. Chad says:
    Here is an even simpler way to modify a Palm Streetfinder GPS. No need to even crack open the case.
    http://www.chadphillips.org/zaurus/palmgps.html
  2. Elliott says:
    I’m all for hacking… but I bought a brand new USB gps for $40 on ebay, win/lin compatible and works perfectly for me.
  3. brandon says:
    too cool! I love gps and navigation technologies. i have the earthmate from delorme integrated into my car and i have the garmin m5 gps pda which is awesome. great hack guys.
  4. brandon says:
  5. mrklaw says:
    I had a palm III streetfinder gps and it was awful. It took forever to get a lock and actually figure out its position.
  6. kahn says:
    anyone got a hack out there for making the gps that comes with msft streets and trips ’05 mac compatible? thought i was going to get another dell for college, but the rents surprised me
  7. telloc says:
    I did this hack about a year ago. I used a USB cable to power the board, and put the resulting mess in an altoids can, soldering the antenna to the top. Good stuff!
  8. nevarmore says:
    I learned a LOT about the nature of GPS while toying with this.
    For compatibility look for devices that are NMEA 0183 compliant. The data coming out of those is just a raw string of numeric data that all mapping software should (had damn well better) be able to parse out.
  9. goldfish says:
    Interesting, in the UK PCWorld says they can sell you a palm iii with this gps on it, for the grand price of 97p. Unfortunatly its “temporarily out of stock”.
    http://www.pcworld.co.uk/product.php?sku=733645
  10. pimpybra says:
    I actually tried doing this before, but not separating the two boards… You can just hook directly up to the serial tx/rx leads on the connection to the palm, and then still use the power AC Adaptor.
    However, the circuitry must have been rather sensitive to the soldering heat, since after I soldered two small leads, the entire thing died. :(
  11. Matt says:
    Does anyone know if the Handspring ‘Magellan GPS Companion’ module can be hacked in this way? – I’ve got one lying in a drawer which I used to use with a long since dead Handspring Visor. It would be neat to make a GPS module out of it which I could use with my laptop. If anyone has any links etc, I’d appreciate a mail to iridium_sunrise@hotmail.com
    cheers
    Matt
  12. Matt says:
    cheers
    Matt
  13. Sabah Munir says:
    I have MapSource (Middle East V2 Map), and a normal Serial (PCMCIA) GPS Module in my laptop. Problem is that when i start the Tracking, all the details of Maps are locked, a message on the bottom right corner shows ” Map Details Locked”, what does that mean? and how can i unlock it. I have already unlocked the maps with the key but i don’t understand how to solve this problem.
    I don’t want to contact Garmin cause i am not using Garmin GPS Module.
    So any suggestion or advice?
    Only reason why i am using Garmin Map Source is that they have Middle East detailed maps.
    Thanks in advance.
  14. does anyone know how to get a good GPS system up and running in thier cart? The Magellan 300 GPS systems are closing out as low as the high 300 dollars on E Bay. I am interested in purchasing one. However, I don
  15. does anyone know how to get a good GPS system up and running in thier cart? The Magellan 300 GPS systems are closing out as low as the high 300 dollars on E Bay. I am interested in purchasing one. However, I don
  16. joez34 says:
    Is there any way to interface this stuff with a Dell Axim X5?
  17. jz says:
    Dear Hackers
    You guys seem to know a lot more about GPS than I do.
    I having been searching for quite awhile for an inexpensive GPS system that can be put into automobiles. The system doesn’t have to be fancy it only has to find the location of a car when needed.
    Does anyone know of such a system?
    If so, do you know how much it cost ? and
    Where do I get GPS tracking software
    Thank you in advance
    JZ Zabo
    gpssearch@mycarfs.com, USA
  18. papgaard says:
    I have cracked the Garmin Unlock Process (works perfectly with my Garmin V and Atlantic Bluechart), and would like to test it on another Garmin Chartplotter – so if you would like to unlock any Mapsource-area please contact me
  19. tobster says:
    Hi Papgaard – I’m game – what info do you need?
  20. tobster says:
  21. Motionbroker says:
    I would be interested in your garmin crack. I have a garmin etrex vista and really want to unlock some of the bluechart pacific maps.
    can you help?
  22. papgaard says:
    send an email to ruderpapgaard@yahoo.com
  23. jonmac says:
    papgaard – i emailed you for the garmin crack. thanks!
  24. Dave says:
    Ive got City Nav v6 that I cant unlock for my 2610 but what is unlocked on the computer. TIA
  25. pedro says:
    Hi papgaard,
    I have three Garmin chartploters. Gps III plus, Street Pilot and 182C.
    What do you need?
  26. neil says:
    Hi Papgaard,
    I have Euro City Nav Version 6 and a garmin GPSMap 60CS.
    I will have a go – sending you an email
    Neil
  27. AJ says:
    How about that 182C hack? Sounds GRRREAT!
  28. Tony says:
    I am looking for bluecharts for New York/New Jersey can anyone hook me up with a copy.
  29. Frits says:
    hi papgaard,
    (and everybody interested how to fool your gps)
    I will explain how to make garmin metroguide work for gps and computer (unlocked for both), at the other hand i’ve got the question if it is possible somehow to make the city select v6/v7 work
    for solutions: fritziefrits@hotmail.com
    THERE IS A METHOD BY HACKING YOR GARMIN METROGUIDE v7. First A WARNING: You have to change something in your regedit, this is an essential system-part in your computer. When you change the wrong things or delete something else than that i wil subscribe in the following, your computer or some programmes might not work anymore.
    1)download the program Garmin metroguide v7
    2)Go to start menu and type ‘regedit’ in the ‘run’ program
    3)Now make a new key by clicking on the right mousekey. the key has to be exactly like this: [HKEY_LOCAL_MACHINESSOFTWAREGarminmapsourcefamilieseuropean metroguide v6]
    Now the computer thinks that your metroguide is already is installed on your computer
    4)Install the downloaded garmin metroguide v7
    5)Once you have finished installing, you have to run ‘regedit again AND ONLY DELETE THE KEY ‘[European metroguide v6]
  30. Knapper says:
    This old man needs help please. I have Streets and Trips and a new garmin vista c and I can’t make them work together. The garmin has only USB and the S&T map program needs a Nema feed. Is there a way to make these two work together? Hope it’s simple.(grin) Thanks for any help you can provide.
    Shortflake@yahoo.com
  31. 2-Dogs says:
    I am looking for help. I have a copy of BlueChart Americas and need some help with an unlock procedure that I have misplaced….;-)
    Any and all help is appreciated.
  32. WWPD says:
    i just got a garmin legend and am looking for a copy of bluecharts america – anyone able to help me out? thanks!
  33. LataDude says:
    I am looking for a download of MapSource V7 and National Parks West. Can anbody help?
  34. papgaard says:
    I can still provide Mapsource unlocks for any Mapsource product and Garmin GPS – just mail me: ruderpapgaard@yahoo.com
  35. munk says:
    would love to know how to unlock any mapsource product and garmin gps.have been searching for weeks.
  36. munk says:
    frits i have followed your instructions for the hack for v7 metroguide,but i keep getting error saying that i cannot name key with in it.any help would be great.
  37. FritZ says:
    That’s because you have to make subfolders/keys:
    for instance HKEY_LOCAL_MACHINESSOFTWAREGarmin is an existing key than make new key by clicking right mouse key give it name mpasource, click on it make new key name it families etc etc.
  38. munk says:
    fritz i have sent you an email.my addy is mel.yeates@tesco.net
  39. Mikey says:
    Is there anywhere I can download Garmin Europe V7 maps???
    Is that what you have Papgaard??
    Thanks!
  40. jango says:
    Please send me the crack for garmin city navigator middle east.
    Thanks in advance
  41. jango India says:
    Please send me the crack for Garmin MapSource CITY NAVIGATOR MIDDLE EAST at jangoindia@hotmail.com.
    Thanks in advance
  42. michael says:
    I just purchased Etrex Legend “C” ; downloaded City Navigator North America v4.0 (w/crack codes). Works great on my laptop, but handheld Etrex “Can’t Unlock Maps”. Can you help? Anyone with City Select North America??
    Etrex is worthless if I can’t unlock maps on it – Any ideas, please email me.
    michael_ps7@yahoo.com
  43. michael says:
    I just purchased Etrex Legend “C” ; downloaded City Navigator North America v4.0 (w/crack codes). Works great on my laptop, but handheld Etrex “Can’t Unlock Maps”. Can you help? Also, Anyone with City Select North America torrent file??
  44. ShadowLord says:
    I have that problem with my etrex vista c. When i try to upload city select europe (unlocked in my pc) i receive an error message telling impossible unlocking maps.
    If anyone know how unlock it please tell me
    Shadowlord_pinto@hotmail.com
    Thanks
  45. Ant says:
    hi ya
    I purchased a segway and it came with a etrex legend C and north american maps V7 city select…..
    I live in Spain…..
    Not much use to me but i would love to have the spanish/europe maps maps!
    I can send you the maps and my unlock codes if this will help you. or copy/swap the disk.
    Is it possible to send you just the maps that you need?
    Im new to this and have not tried much as the maps are useless to me. Only unlocked for myself out of curiosity.
    Cheers
    Madrid
  46. Ant says:
  47. Ant says:
  48. papgaard says:
    Hi
    I can generate unlockcodes for your GPS and MapSource.
    Will you please send an email to:
    gps@pinodyr.com
    With information about:
    - UNITID for your GPS (not SERIAL) – MapSource can extract this UNITID from your GPS.
    - Which Mapsourceproduct AND version you want an unlockcode for (i.e. City Select Europe v7)
    And I will generate a testcode for you.
    Cheers
    Ruder Papgaard
  49. carlos says:
    Hello from Spain
    i have City Navigator Europe V.7 but i can
  50. Why ask says:
    Hey papgaard Thanks for you help! You still out there? Not sure your getting e-mails…I may need more help!
    Why Ask
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
