HOW-TO: Make A Nokia Pop Port To Female Mini Jack With Volume Control
nokia popport
When Nokia announced their music player capable phones they neglected to mention the lack of support for external headphones. Since the release of the 6230 and its related family with mp3/aac playback support, many disgruntled users have made their own home-brew cables to plug in headphones. Today we will show one such mod for the Nokia HDS-3 cable. Our mod includes an analog volume dial integrated into the push to talk unit. The HDS-3 cable ships with the 6230 and other Nokia phones capable of stereo playback.
by Fabienne Serriere
Before starting, a quick rundown of some other Nokia models of pop port headphones and adapters include:
Nokia HS-3 “Nokia Stereo Fashion Headset” white or black,
smaller push to talk unit than the HDS-3, headphones are still of an inferior audio quality
Nokia HS-8 “Nokia Activity Headset” ugly and bad audio
quality headphones
Nokia HS-6 “Display Headset” lcd display and controls for
audio and calls, but yet again no port to plug in your own headphones
Nokia HS-23 “Nokia Stereo Headset” includes volume control,
lesser quality headphones
Nokia AD-15 “Nokia Audio Adapter” allows you to plug in your
own headphones, unfortunately this is achieved with a big box on the end of the cable, there is no mic, and as far as
we can tell no button to switch tracks.
Even headset models that are not available on the market yet don’t allow for the consumer to plug in their own
headphones. Why Nokia? Why! For a few weeks we assumed that the audio quality coming out of our 6230 was just as dismal
as the headphones in the HDS-3 headset led us to believe. The astonishing part is that no, the audio quality of the
6230 is comparable to most mp3 players on the market once you manufacture your own adapter cable.
The second mistake by Nokia is the misinformation as to how much memory can be recognized on the mmc cards. The
manual for the 6230 states the mmc card can be up to 128 mb.
In reality the phone can recognize mmc cards up to 1 gig. To see if your phone’s firmware is up to date enough to work
with that much memory, in the 6230 type: *#0000#. On the screen you should see something similar to:
Nokia 6230
V 05.24
25-11-04
etc.
The important information in this is of course the firmware version on the second line, in this case 5.24. If your
phone is not up to date you can have the firmware flashed at most cell phone provider stores. Note that firmware
upgrades will wipe the memory of the phone, so be sure to save important info before upgrading. The firmware of the
6230 starting with version 4.44 should correctly recognize 1 gig of memory on the mmc, but may not search the
subdirectories on the card for music files to include in the playlist. Before loading audio on the mmc card, we suggest
you format it in a card reader on your computer rather than on the phone. Format the card, re-name the card, then fill
that 1 gig of happiness with a playlist of mp3/aac and/or mp4 if you have a Nokia model that supports it.
You will need for this how-to: a soldering iron, a knife of some sort, a multimeter, a round file, hot glue gun,
electrical tape, a Nokia stereo headset (we will be using the HDS-3, but you should be able to extrapolate to another
on the list above), a cheap pair of headphones with integrated volume control, a cable with a female mini jack (3.5 mm)
connector on one end, or if you have only a cable with a male mini jack connector you will also require a mini jack
female to mini jack female adapter (see the second to last picture at the end of this article). You may also need a
small philips screwdriver depending on the model and make of your Nokia headset.
The Nokia HDS-3 (ships with many Nokia models including the 6230):
3342
3343
The HDS-3 has several flavors: the older models have four screws on the back of the push to talk module. If you have
this model, first remove the screws. Now for both models, we are ready to pop open the connector. We use a knife to
carefully separate the front from the back of the push to talk unit in the middle of the cable:
3360
Once the unit is open, check to see if the speaker is on the front or the back of the unit. Chances are if you have
a model with screws, your solder points for the headphones are already visible. If you have the newer model without
screws on the outside, you must now carefully pry up the circuit board and flip it over.
3364
If you have the newer model your circuit board should resemble this:
circuit02
Note the connections on the circuit board. The headphones Nokia supplies are attached to (from left to right) L-,
L+, R+, R-. These are the points which we are now going to de-solder:
3367
Your de-soldered circuit board will now look something like this:
3368
Prepare the housing for the volume control knob by filing a rectangular notch out of one edge of the push to talk
unit. Ideally you would do this before adding the volume control unit shown in this picture:
3397
Now cut off the volume control from the cheap pair of headphones (ours cost about six bucks at our circuit
city-esque store). We used the Proline IE-500, but any no-name cheap in-ear headphones with volume control on the cable
will do. Pop open the volume control module. The circuit will look something like this:
3372
Note the direction of the audio with respect to the circuit. Our audio comes in on the left side of the circuit and
exits on the right hand side. The board may even be labeled as ours was:
G (ground)
R (right)
L (left)
We will be inserting this volume control where the Nokia headphones were originally attached on the push to talk
unit. Our female mini jack port will then be connected to the output of this volume controller. De-solder the cables
from the volume controller and if needed, file down the circuit board to fit it under the circuit board in the push to
talk unit.
3394
Now tin (prepare them with a bit of solder) and solder jumper cables (you can salvage these from a piece of the
cable you cannibalized for the female mini jack connector) from the push to talk unit’s output (labeled L-, L+, R+, R-)
to the input side of the volume control circuit. Both L- and R- are soldered to ground on the volume control
circuit:
L- ___    G
push to talk output     R- /
volume control circuit input
R+ == R
L+ == L
This image shows the volume circuit partially soldered to the push to talk circuit and the mini jack cable soldered,
which will be covered in the next step:
3397
Since we filed down the volume control circuit where the input ground and output ground were connected by a trace in
the circuit board, we also added a jumper cable from input ground to output ground on the volume control circuit.
Next prepare your female mini jack cable by cutting it to the desired length (we chose a length of about 3
centimeters). This length will be how long the mini jack cable extends out from the push to talk unit. Denude the
cables leaving a half centimeter of shielding over the two audio cables. Do not split the grounding wires as they are
in this photo, but instead twist them into one bundle:
3365
Determining which is right and left in the mini jack cable is easy if the colors of the cables are red and white.
Red is right and white is left. If, like us, you found yourself with a creatively colored cable, notably orange and
yellow, bust out your multimeter and a male mini jack connector on a cable that has been similarly denuded. Test the
male mini jack connector with a multimeter and note the wiring, for example our male mini jack connector was (where tip
is the tip of the connector, ring is the middle, and sleeve is the base):
TIP orange
RING yellow
SLEEVE ground
This meant that our mini jack female connector would have the same pin-out because the female and male mini jack in
this case were cut from the same cable. Let us assume for a moment that your male mini jack connector came from a
different cable and had this pin-out:
TIP white
RING red
SLEEVE ground
We would then simply plug the male mini jack into the female mini jack and test the cable with a multimeter to
determine the pin-out. In the example noted above:
TIP white === orange male
RING red === yellow female
SLEEVE ground === ground
Now we can extrapolate from the fact that on a tip-ring-sleeve style connector the pin-out for L/R/ground is:
TIP left
RING red
SLEEVE ground
This leaves us with the wiring to the volume circuit board as follows:
TIP left orange
RING right yellow
SLEEVE ground ground
So to solder to the output of our volume control board we will have:
G ground
L orange
R yellow
Your diagram may be a bit different depending on the colors of your female mini jack cable. A common example would
be:
G ground
L white
R red
Next tin your cables (prepare them with a bit of solder on them) and trim them down. Solder them onto the points on
the output of the volume control circuit following the diagram you have made yourself with the tip-ring-sleeve
explanation above:
3397
Note that the volume control unit is face down. This allows the volume control dial to spin freely against the
smooth plastic underneath it. Also note that it is facing towards the rectangular notch we filed earlier.
Underside of the completed soldering:
3401
Now file a rounded notch to let the cable exit out of the top center of the push to talk unit. You only need to file
the round notch into the backside of the unit (the side without the button):
3375
Stick a piece of electrical tape between the volume control unit and the push to talk circuit. Push the volume knob
to the edge of the rectangular notch. At this point, plug your phone in and your headphones and play some music to test
your wiring skillz.
3403
Now add a blob of hot glue on the inside edge of the volume controller circuit to force it to the edge of the
plastic housing. Take care to not glue the volume potentiometer in place. We want to be able to change our
volume!
3406
Now gently fold the original circuit on top of the volume controller knob and test once again with audio to make
sure you don’t have any connections shorting or breaking.
3408
Now replace the top cover and test the push to talk unit. Now carefully put hot glue all around the outside edge of
the push to talk unit, taking care to not glue the volume knob.
3410
If you wish to change the fugly beige color of the unit, you can do so now. Tape off the button and the base cable.
Bust out that black nail polish from your goth phase or some black hobby model paint from that black hawk helicopter
you never finished. Alternatively you can pick a more vibrant color to match your colorware computer. Give the unit two
coats of paint, leaving time for it to dry between coats. If you don’t dig paint, you can also go for the ghetto black
electrical tape look.
Version 01 with ghetto black electrical tape, without the volume controller, a male mini jack connector and a female
to female mini jack adapter and some not-so-stellar sony in-ear headphones:
3340
Here is the completed unit with volume control (unpainted) with a Nokia 6230:
3416
And finally a painted version of the completed unit in use on a messenger bag:
bagview
If you are feeling less adventurous or don’t want the analog volume control on the push to talk unit, hop over to
Engadget to read the basic How-To. Nokia, if you are
listening, please include ports for standard headphones on the phone itself and if not, at least in the cables that are
provided with the phone.
38 thoughts on “HOW-TO: Make A Nokia Pop Port To Female Mini Jack With Volume Control
  1. I don’t know what I did wrong but when I completed the process I only had mono sound coming out of one earpiece, when I removed one of the grounds then I had mono sound in both earpieces…..any suggestions
  2. I don’t know what I did wrong but when I completed the process I only had mono sound coming out of one earpiece, when I removed one of the grounds then I had mono sound in both earpieces…..any suggestions
  3. Very useful, Thank You.!!!
    To all nokia user:the earphone provided with my 6230(HDS-3)was a very good one,but unfortunatly went broken.So I decide to buy a new one.
    The HDS-3(Original Nokia spare part)i bought for
  4. Nice hack! But I noticed the headphones on the 6230i do not have a common ground; wouldn’t it harm the circuitry to connect r- en l- ?
    I connected the 6230i to my stereo and noticed the signal was quite soft, compared to connecting an old walkman or discman. Why could that be?
    Greetz,
    EJ
  5. hi there, I have recently tried to make an audio adapter just like the ad-15 (don’t really need the mic).. so I cut the cable like 2 inch. from the end and soldered the cables r+r-l+l- to a female jack (I knew which were the right ones cuz I opened the mic part).. this didn’t work.. then connected the other 5 cables to ground with r- and l-.. and sound comes out just from the left headphone.. now dont know what to do to get the thing to work properly.. any advise???
  6. hello, i tried this modd yesterday on my hs-3 which came with my 6630 phone but. it did not work. it just says “enhancement not supported” on the screen right after i connect the headset on the phone. but it works perfectly fine on my dad’s nokia 6170. can anyone ple help on what went wrong? thankyou.:)
    btw i did the modd without the volume control
  7. Welcome to Sule Wireless Trading company,that deals with brand new mobile phones and accessories. Now we would like to introduce you our offer of mobile phones we sell and at the bottom you can get some information connected with our mode of payments and many more. we deal in mobile phones ,accesories ,laptops camcoders and has branches all over the world ,all our prices are wholesale price ,thus discounts are granted to customers depending on the volume of purchase … Specifications: below are some brand of phones we have in stock in all quanties required Here is the price list with the actual prices: Do contact us direct by E mail sulemaninc@yahoo.co.uk WE ARE SELLING ALL KIND OF MOBILE PHONES AT A CHEAP PRICES MOTOROLA RAZOR V3 AT JUST……… $140USD MTOROLA MPX 300 AT JUST …………$130USD MOTOROLA MPX 200 ………………$125USD Sony Ericsson K500i…..130 USD Sony Ericsson P800……170 USD Sony Ericsson P900……140 USD Sony Ericsson P910i…..160 USD Sony Ericsson T230……80 USD Sony Ericsson T310……80 USD Sony Ericsson T610……100 USD Sony Ericsson Z1010…..180 USD Sony Ericsson Z200……90 USD Sony Ericsson Z600……130 USD Sony Ericssson T630…..130 USD Sony Ericsson S700i…..130 USD Sony Ericsson S750i…..120 USD Nokia 3200……40 USD Nokia 3220……60 USD Nokia 3300……60 USD Nokia 3660……70 USD Nokia 5100……60 USD Nokia 5140……70 USD Nokia 6100……50 USD Nokia 6108……60 USD Nokia 6220……70 USD Nokia 6230……90 USD Nokia 6230i……110 USD Nokia 6260……120 USD Nokia 6270……160 USD Nokia 6600……100 USD Nokia 6630……90 USD Nokia 6610……70 USD Nokia 6610i…..90 USD Nokia 6650……120 USD Nokia 6670 Smartphone…130 USD Nokia 6820……70 USD Nokia 7200……80 USD Nokia 7210……60 USD Nokia 3230……140 USD Nokia 7610……120 USD Nokia 9300……150 USD Nokia 7250……70 USD Nokia 7250i…..75 USD Nokia 7260……130 USD Nokia 7200……110 USD Nokia 7600……90 USD Nokia 7610……120 USD Nokia 8910i…..120 USD Nokia 8910i…..110 USD Nokia 9210i Communicator..160 USD Nokia 9500 Communicator..180 USD Nokia 9300 Communicator..180 USD Nokia N-Gage….120 USD Nokia N-gage QD.180 USD Nokia 7710……150 USD Nokia 6680……140 USD Nokia 8800……160 USD Nokia 6680……130 USD Nokia 6681……130 USD Nokia N90……180 USD Nokia N91……180 USD Nokia N70……230 USD Nokia 6060……240 USD Nokia 6111……200 USD Motorola A388C……170 USD Motorola A760…….250 USD Motorola A768…….260 USD Motorola A768i……200 USD Motorola A780…….290 USD Motorola C550…….90 USD Motorola C650…….100 USD Motorola E365…….100 USD Motorola E398…….120 USD Motorola E680…….240 USD Motorola RAZR V3….270 USD Motorola V220…….170 USD Motorola V303…….100 USD Motorola V400…….150 USD Motorola V500…….150 USD Motorola V501…….200 USD Motorola V525…….150 USD Motorola V600 (OEM) w/ Bluetooth Headset..260 USD Motorola V600 OEM…180 USD Motorola V690…..170 USD Motorola V750…..180 USD Motorola V80……200 USD Motorola V80 with Bluetooth…260 USD Motorola V872…..200 USD Motorola V878….180 USD Motorola V300….150 USD Samsung D500…240 USD Samsung E600…140 USD Samsung E800…180 USD Samsung P510…120 USD Samsung SGH-D410.200 USD Samsung SGH-D500..270 USD Samsung SGH-E700..150 USD Samsung SGH-E715..170 USD Samsung SGH-P100..130 USD Samsung SGH-P400..95 USD Samsung SGH-P408..240 USD Samsung SGH-P730..150 USD Samsung SGH-S200..90 USD Samsung SGH-S300..70 USD Samsung SGH-S300M..100 USD Samsung SGH-S500…100 USD Samsung SGH-V200…110 USD Samsung SGH-X400…100 USD Samsung SGH-X430…100 USD Samsung SGH-X600…100 USD Samsung X450…….100 USD PDA’s HP IPaq Pocket PC H4150 ========= $190 Asus MyPal A716 ================= $175 HP IPaq Pocket PC H4350 ========= $185 Toshiba Pocket PC E405 ========== $120 Sony Clie PEG-TH55 ============== $155 Toshiba Pocket PC E800 ========== $220 PalmOne Zire 72================== $120 PalmOne Tungsten E ============== $90 PalmOne Tungsten C ============== $140 PalmOne Zire 31 ================= $65 palm Treo 650=====================$240 1 year worldwide warranty. If this is ok for you reply me asap here; or u can mail me on sulemaninc@yahoo.co.uk Thus payment methods , are western union. We look forward to your prompt reply …….SERIOUS AND LEGIT BUYERS . Do contact us direct by E mail sulemaninc@yahoo.co.uk Apple 4 GB iPod Mini Pink M9435LL/A ……40 USD Apple 40 GB iPod photo………………..40 USD Apple 4 GB iPod Mini Silver M9160LL/A ….40 USD Apple 60 GB iPod Photo M9830LL/A……….60 USD Apple 60 GB iPod photo ……………….55 USD Apple 30 GB iPod Photo M9829LL/A……….50 USD Apple 512 MB iPod Shuffle MP3 Player……40 USD Apple 4 GB iPod Mini Blue M9436LL/A…….45 USD Apple 2 GB iPod Nano………………….50 USD Apple 4 GB iPod Nano………………….60 USD Apple 30 GB iPod Vidoe……………….110 USD Apple 60 GB iPod Vidoe……………….150 USD X box 360 ………………$180usd Play Station 2 ………..$140usd Play Station 3 ……….$190usd Do contact us direct by E mail sulemaninc@yahoo.co.uk
  8. Just adding my 2 cents to the mmc memory card issue.I have a 2 month old 6255i. It came with the “jam pack”,which included a 64mb card.After the Nickelback vid and 2 songs,it could barely hold my Earth Wind and Fire Greatest Hits CD(17 songs).I went on ebay and found a 2gb card and it works just fine!I don’t know what Nokia’s problem is.They make a great phone but leave you in the dark as to it’s true capabilities.Thanks for the recipe for the headphones!
  9. We have All kind of Nokia, Sony Ericsson, Samsung, Motorola, Nextel.Our Mobile Phones are:- Brand new gsm phones (this includes accessories, Manuals, software and boxes) P2) Unlocked / sim free.BR3) Brand new (original manufacturer) box – no copies BR4) All phones have English language as default 5) All material (software, manual) – Car chargers – Home chargers – USB data cables -holsters/belt-lips-Wireless headsets (Bluetooth) – Leather and non-leather carrying cases -Batteries.Forward your questions and enquires to us via email with your order and Shipping details.We give 1 year warranty for every phone sold out to Our customers,Our phones are Manufacture Company class 1 tested And approved by global standard organization of Wireless industries,Extra charger and battery.we give one year international warranty..and two weeks return policy..kindly contact the sales manager if you do have intrest…
    anytraderequest@hotmail.com
    http://www.anytraderequest.com
    Sidekick II ………….$145
    sidekick 1…………..$70
    Motorola A008– US$50
    Motorola A388– US$70
    Motorola A388c– US$120
    Motorola A820– US$65
    Motorola C330– US$20
    Motorola C331– US$25
    Motorola C332– US$30
    Motorola C333– US$35
    Motorola C350– US$69
    Motorola E360– US$60
    Motorola E365– US$110
    Motorola E380– US$95
    Motorola E398– US$125
    Motorola MPX200– US$180
    Motorola Accompli 008– US$49
    Motorola Timeport 280– US$80
    Motorola T190T– US$25
    Motorola Talkabout 191– US$25
    Motorola T720– US$65
    Motorola T720i– US$85
    Motorola V3Razor– US$145
    Motorola V66– US$60
    Motorola V60– US$70
    Motorola V60i– US$75
    Motorola V70– US$105
    Motorola V80– US$115
    Motorola V290– US$80
    Motorola V750– US$125
    Motorola V3688+– US$20
    Motorola V8088– US$30
    Motorola V525– US$139
    Motorola V300– US$130
    Motorola V400– US$125
    Motorola V500– US$130
    Motorola V600– US$140
    Samsung SGH A200– US$50
    Samsung SGH A300– US$40
    Samsung SGH A500– US$70
    Samsung SGH A800– US$70
    Samsung SGH C100– US$85
    Samsung SGH E400– US$125
    Samsung SGH E600– US$129
    Samsung SGH E700– US$130
    Samsung SGH E715– US$155
    Samsung SGH-E810– US$140
    Samsung SGH-E820– US$150
    Samsung SGH-E800– US$155
    Samsung SGH-E850– US$140
    Samsung SGH D410– US$150
    Samsung SGH D500– US$155
    Samsung SGH P400– US$135
    Samsung SGH P510– US$139
    Samsung SGH N188– US$110
    Samsung SGH N288– US$60
    Samsung SGH N500– US$60
    Samsung SGH N620– US$60
    Samsung SGH M100– US$45
    Samsung SGH P400– US$140
    Samsung SGH P410– US$145
    Samsung SGH P500– US$155
    Samsung SGH Q105– US$40
    Samsung SGH Q300— US$70
    Samsung SGH R220– US$30
    Samsung SGH R225– US$25
    Samsung SGH S100– US$90
    Samsung SGH S200– US$100
    Samsung SGH S300– US$105
    Samsung SGH S307– US$130
    Samsung SGH S500– US$109
    Samsung SGH T100– US$100
    samsung SGH S105– US$35
    Samsung SGH T200– US$125
    Samsung SGH T400– US$60
    Samsung SGH T500– US$90
    Samsung SGH T700– US$99
    Samsung SGH V200– US$105
    Samsung SGH VM680– US$100
    Samsung SGH X400– US$105
    Samsung SGH X410– US$130
    Samsung SGH X426– US$129
    Samsung SGH-C200– US$125
    Samsung SGH-X460– US$140
    Samsung SGH-X450– US$130
    Samsung SGH-X120– US$99
    Samsung SGH X600– US$145
    Samsung SGH-X610– US$140
    Samsung SGH-Z105– US$120
    samsung d500…….$210
    samsung d600…….$230
    samsung d800…….$245
    Nokia 3650– US$185
    Nokia 3660– US$195
    Nokia 5100– US$65
    Nokia 5140– US$110
    Nokia 5210– US$40
    Nokia 5510– US$105
    Nokia 5550– US$50
    Nokia 5170iR– US$39
    Nokia 6020– US$130
    Nokia 6670– US$105
    Nokia 6630– US$175
    Nokia 6100– US$80
    Nokia 6108– US$90
    Nokia 6220– US$105
    Nokia 6230– US$110
    Nokia 6260– US$135
    Nokia 6310– US$69
    Nokia 6310i– US$70
    Nokia 6500– US$60
    Nokia 6510– US$60
    Nokia 6600– US$135
    Nokia 6610– US$80
    Nokia 6630– US$175
    Nokia 6170– US$145
    Nokia 6650– US$82
    Nokia 6800– US$105
    Nokia 6820– US$110
    Nokia 7200– US$185
    Nokia 7210 Turquoise– US$100
    Nokia 7230– US$120
    Nokia 7250– US$125
    Nokia 7250i– US$120
    Nokia 7260– US$135
    Nokia 7280– US$155
    Nokia 7600– US$165
    Nokia 7610– US$195
    Nokia 7650– US$160
    Nokia 8250– US$65
    Nokia 8310– US$90
    Nokia 8910 Titanium– US$160
    Nokia 8910 Black– US$165
    Nokia 8910i– US$185
    Nokia 8890– US$115
    Nokia 8850 Special Edition– US$105
    Nokia 8850 Gold Edition– US$110
    Nokia 8800 ———— US$250
    Nokia 6680……US $220
    Nokia 6681……US $220
    Nokia N90……US $170
    Nokia N91……US $175
    Nokia N70……US $165
    nokia n80…….$200
    Nokia 6060……US $130
    Nokia 6111……US $160
    Nokia 8855– US$100
    Nokia 9210 Communicator– US$195
    Nokia 9210i Communicator– US$195
    Nokia N-Gage– US$110
    Nokia 9500 (communicator)– US$170
    Nokia 9500 (communicator)– US$180
    Sony Ericsson P800– US$155
    Sony Ericsson P900– US$205
    Sony Ericsson P910i– US$210
    Sony Ericsson T20e– US$35
    Sony Ericsson T20s– US$39
    Sony Ericsson T28s– US$39
    Sony Ericsson T28 World– US$45
    Sony Ericsson T29s– US$49
    Sony Ericsson T100– US$30
    Sony Ericsson T105– US$35
    Sony Ericsson T200– US$45
    Sony Ericsson T230– US$55
    Sony Ericsson T300– US$55
    Sony Ericsson T310– US$50
    Sony Ericsson T600– US$69
    Sony Ericsson T610– US$130
    Sony Ericsson T630– US$135
    Sony Ericsson T68i– US$105
    Sony Ericsson T68m– US$110
    Sony Ericsson Z200– US$100
    Sony Ericsson Z600– US$170
    Sony CMD-J5– US$30
    Sony CMD-Z7– US$35
    Sony CMD-J7– US$40
    Sony CMD-J6– US$40
    Sony CMD-Z5– US$90
    Sony CMD-MZ5– US$155
    Sony Ericsson R520m– US$100
    Sony Ericsson R380 World– US$90
    Sony Ericsson R380s– US$105
    Sony Ericsson R600– US$35
    Sony Ericsson S700– US$175
    Sony Ericsson K500i– US$180
    Sony Ericsson K700i– US$189
    Sony Ericsson K750i– US$200
    Thanks
    sales manager
    wenatchee.washington 98801
    UsA.206-222-2831
  10. WE ARE SELLING LOTS OF MOBILE PHONES FOR VERY CHEAP PRICE AND THESE PHONES ARE THE LATEST PHONES ALSO THEY SELLS A LOT IN MARTEK SO THEY ARE AS FOLLOW””””””’
    If you are indeed interested and ready to order pls contact us on the information below. Email:clasicphones@yahoo.com
    X box premium console ……………… 190usd
    Ps3 …………………………………220usd
    Ps2 …………………………………..160usd
    Contact us birect by e mail clasicphones@yahoo.com
    FOR SELL MOTOROLA RAZOR V3 MOBILE PHONE AT JUST $140usd,
    FOR SELL MOTOROLA RAZOR V3x MOBILE PHONE AT JUST $150usd
    FOR SELL NEXTEL i930 MOBILE PHONE AT JUST $120usd,
    FOR SELL NEXTEL i860 MOBILE PHONE AT JUST $100usd,
    FOR SELL SONY ERICSSON P910i MOBILE PHONE AT JUST $150usd,
    FOR SELL SONY ERICSSON W800i MOBILE PHONE AT JUST $140usd
    FOR SELL MOTOROLA MPX 220 MOBILE PHONE AT JUST $130usd,
    FOR SELL MOTOROLA MPX 300 MOBILE PHONE AT JUST $140usd,
    FOR SELL SONY ERICSSON S700i MOBILE PHONE AT JUST $120usd
    FOR SELL NOKIA 9500 MOBILE PHONE AT JUST $160usd,
    FOR SELL NOKIA 9300 MOBILE PHONE AT JUST $130usd,
    FOR SELL SAMSUNG D500 MOBILE PHONE AT JUST $150usd,
    FOR SELL SAMSUNG D500 MOBILE PHONE AT JUST $170usd
    FOR SELL SIDEKICK II MOBILE PHONE AT JUST $100usd
    FOR SELL SIDEKICK III MOBILE PHONE AT JUST $120usd
    FOR SELL NOKIA N71 MOBILE PHONE AT JUST $150USD
    FOR SELL NOKIA N80 MOBILE PHONE AT JUST $150USD
    FOR SELL NOKIA N92 MOBILE PHONE AT JUST $175USD
    FOR SELL NOKIA N70 MOBILE PHONE AT JUST $150usd
    FOR SELL NOKIA N90 MOBILE PHONE AT JUST $170usd
    FOR SELL NOKIA N91 MOBILE PHONE AT JUST $170usd
    FOR SELL NOKIA 8800 MOBILE PHONE AT JUST $150usd
    Contact us birect by e mail:clasicphones@yahoo.com
  11. We have all kind of Mobile Phones and Computers For Sale. We have All kind of Nokia, Sony Ericsson, Samsung, Motorola, Nextel, Qtek, BenQ.Laptop,Our Mobile Phones are:- Brand new gsm phones (this includes accessories, Manuals, software and boxes) P2) Unlocked / sim free.BR3) Brand new (original manufacturer) box – no copies BR4) All phones have English language as default 5) All material (software, manual) – Car chargers – Home chargers – USB data cables -holsters/belt clips – Wireless headsets (Bluetooth) – Leather and non-leather carrying cases – Batteries.If you are interested, Forward your questions and enquires to us via email with your order and Shipping details.
    Serious buyers should contact.
    We offer the best item’s.
    Hope to hear from you soon.
    Best Regards.
    Store Name: Phone Telcom Ltd
    Addr : 183 Marsh Wall
    E14 9SR,London.UK
    Email : {phonetelcom@yahoo.com}.
    Contact Number: +44-703-186-1296
    Thank’s and God bless.
    Nokia 1100– US$51
    Nokia 2100– US$53
    Nokia 2300– US$60
    Nokia 3100– US$62
    Nokia 3108– US$70
    Nokia 3200– US$85
    Nokia 3230– US$120
    Nokia 3300 – US$65
    Nokia 3310– US$32
    Nokia 3315– US$32
    Nokia 3330– US$49
    Nokia 3350– US$42
    Nokia 3410– US$41
    Nokia 3510– US$49
    Nokia 3510i– US$54
    Nokia 3530– US$57
    Nextel i860 =========$170
    Nokia 6600 ==========$135
    Nokia 6630 ========== $215
    Nokia 6681===========$140
    Nokia 6680===========$160
    Sagem MY V-55========$65
    Sagem 3020==========$130
    Nokia 3595– US$54
    Nokia 3610– US$63
    Nokia 3650– US$185
    Nokia 3660– US$215
    Nokia 5100– US$74
    Nokia 5140– US$125
    Nokia 5210– US$51
    Nokia 5510– US$115
    Nokia 5550– US$69
    Nokia 5170iR– US$39
    Nokia 6020– US$151
    Nokia 6670– US$124
    Nokia 6630– US$193
    Nokia 6100– US$94
    Nokia 6108– US$120
    Nokia 6220– US$115
    Nokia 6230– US$140
    Nokia 6260– US$145
    Nokia 6310– US$91
    Nokia 6310i– US$96
    Nokia 6500– US$61
    Nokia 6510– US$61
    Nokia 6600– US$140
    Nokia 6610– US$86
    Nokia 6630– US$210
    Nokia 6170– US$190
    Nokia 6650– US$81
    Nokia 6800– US$115
    Nokia 6820– US$120
    Nokia 7200– US$215
    Nokia 7210 Turquoise– US$115
    Nokia 7230– US$144
    Nokia 7250– US$145
    Nokia 7250i– US$149
    Nokia 7260– US$162
    Nokia 7280– US$172
    Nokia 7600– US$185
    Nokia 7610– US$200
    Nokia 7650– US$165
    Nokia 8250– US$81
    Nokia 8310– US$94
    Nokia 8910 Titanium– US$170
    Nokia 8910 Black– US$184
    Nokia 8910i– US$211
    Nokia 8890– US$34
    Nokia 8850 Special Edition– US$120
    Nokia 8850 Gold Edition– US$124
    Nokia 8800 ———— US$240
    Nokia 6680……US $210
    Nokia 6681……US $221
    Nokia N90……US $165
    Nokia N91……US $173
    Nokia N70……US $163
    Nokia 6060……US $120
    Nokia 6111……US $170
    Nokia 8855– US$101
    Nokia 9210 Communicator– US$185
    Nokia 9210i Communicator– US$175
    Nokia N-Gage– US$116
    Nokia 9500 (communicator)– US$185
    Nokia 9500 (communicator)– US$194
    Sony Ericsson P800– US$163
    Sony Ericsson P900– US$210
    Sony Ericsson P910i– US$230
    Sony Ericsson T20s– US$38
    Sony Ericsson T230– US$54
    Sony Ericsson T300– US$53
    Sony Ericsson T310– US$53
    Sony Ericsson T600– US$67
    Sony Ericsson T610– US$120
    Sony Ericsson T68m– US$111
    Sony Ericsson Z200– US$120
    ny Ericsson Z600– US$165
    ny CMD-J5– US$30
    Sony CMD-Z7– US$35
    Sony CMD-J7– US$40
    Sony CMD-J6– US$40
    Sony CMD-Z5– US$90
    Sony Ericsson K750i– US$190
    Smsung SGH A200– US$50
    Samsung SGH A300– US$45
    Samsung SGH S307– US$12
    Samsung SGH T100– US$110
    Smsung SGH S105– US$35
    Samsung SGH-X460– US$130
    Motorola V66– US$60
    Motorola V60– US$70
    Motorola V3 —US$20
    Motorola V3I–US$25
    Motorola V7–US$31
    Motorola V3688+– US$120
    Siemens A35– US$15
    Siemens A40– US$19
    Siemens A50– US$25
    Siemens A52– US$29
    Siemens A55– US$30
    Siemens C45– US$30
    Siemens C55– US$35
    Siemens CL50– US$70
    Siemens CL55– US$65
    Siemens CT56– US$30
    Siemens M50– US$35
    Siemens M55– US$120
    Siemens MC60– US$79
    Siemens ME45– US$50
    Siemens S45– US$60
    Siemens SL42– US$65
    Siemens SL45i– US$69
    Siemens S55– US$85
    Siemens SL55– US$125
    Siemens SX45– US$155
    Siemens SX1– US$180
    Siemens Xelibri 1– US$60
    Siemens Xelibri 2– US$70
    Siemens Xelibri 3– US$110
    Siemens Xelibri 4– US$80
    Siemens Xelibri 5– US$65
    Siemens Xelibri 6– US$85
    Siemens Xelibri 7– US$85
    Siemens Xelibri 8– US$95
    Nextel i55sr– US$65
    Nextel i2000plus– US$35
    Nextel i58sr– US$30
    Nextel i530– US$35
    Nextel i205– US$20
    Nextel i305– US$25
    Nextel i35s– US$29
    Nextel i88– US$30
    Nextel i90– US$59
    Nextel i95cl– US$70
    Nextel i60c– US$40
    Nextel 6510TM– US$110
    Nextel i730– US$85
    Nextel i733– US$95
    Nextel i736– US$105
    Nextel i830– US$115
    Nextel i860– US$125
    Nextel i930– US$140
    Qtek phones
    Qtek s200 =$100
    Qtek 9000 =$130
    Qtek 8310 =$200
    Qtek 8300 =$210
    Qtek 9100 =$240
    Qtek 8100 =$250
    Qtek s110 =$210
    Qtek s100 =$200
    Qtek 9090 =$210
    Qtek 8020 =$200
    Qtek 8010 =$180
    Qtek 2020i=$240
    Qtek 2020 =$250
    Qtek 8080 =$130
    Qtek 8060 =$160
    Qtek 1010 =$150
    Qtek 7070 =$250
    PDA’s
    Toshiba Pocket P
  12. We have All kind of laptops,ipods and palm phones… Nokia, Sony Ericsson, Samsung, Motorola, Nextel.Our Mobile Phones are:- Brand new gsm phones (this includes accessories, Manuals, software and boxes) P2) Unlocked / sim free.BR3) Brand new (original manufacturer) box – no copies BR4) All phones have English language as default 5) All material (software, manual) – Car chargers – Home chargers – USB data cables -holsters/belt-lips-Wireless headsets (Bluetooth) – Leather and non-leather carrying cases -Batteries.Forward your questions and enquires to us via email with your order and Shipping details.We give 1 year warranty for every phone sold out to Our customers,Our phones are Manufacture Company class 1 tested And approved by global standard organization of Wireless industries,Extra charger and battery.we give one year international warranty..and two weeks return policy..kindly contact the sales manager if you do have intrest… Markjohnsonphonesltd@iruda.com
    sidekick 111…………..$170
    sidekick 1…………..$70
    Nextel i55sr………US$65
    Nextel i2000plus……. US$35
    Nextel i58sr……….. US$30
    Nextel i530……..US$35
    Nextel i205……… US$20
    Nextel i305……. US$25
    Nextel i35s………US$29
    Nextel i88………..US$30
    Nextel i90….. US$59
    Nextel i95cl………. US$70
    Nextel i60c– US$40
    Nextel 6510TM…… US$110
    Nextel i730– US$85
    Nextel i733– US$95
    Nextel i736– US$105
    Nextel i830– US$115
    Nextel i860– US$125
    Nextel i930– US$140
    Eten m500——us$220
    Eten m600——-Us$250
    Motorolab razor V3……..$165
    Motorolab razor V3i…….$170
    samsung d500…….$210
    samsung d600…….$230
    samsung d800…….$245
    Nokia 3650– US$185
    Nokia 3660– US$195
    Nokia 5100– US$65
    Nokia 5140– US$110
    Nokia 5510– US$105
    Nokia 6020– US$130
    Nokia 6670– US$105
    Nokia 6630– US$175
    Nokia 6100– US$80
    Nokia 6108– US$90
    Nokia 6220– US$105
    Nokia 6230– US$110
    Nokia 6260– US$135
    Nokia 6310– US$69
    Nokia 6310i– US$70
    Nokia 6600– US$135
    Nokia 6630– US$175
    Nokia 6170– US$145
    Nokia 6800– US$105
    Nokia 6820– US$110
    Nokia 7200– US$185
    Nokia 7230– US$120
    Nokia 7250– US$125
    Nokia 7250i– US$120
    Nokia 7260– US$135
    Nokia 7280– US$155
    Nokia 7600– US$165
    Nokia 7610– US$195
    Nokia 7650– US$160
    Nokia 8250– US$65
    Nokia 8310– US$90
    Nokia 8910i– US$185
    Nokia 8890– US$115
    Nokia 6680……US $220
    Nokia 6681……US $220
    Nokia N90……US $170
    Nokia N91……US $175
    Nokia N92……us $180
    Nokia N93……Us $210
    Nokia N70……US $165
    nokia n80…….$200
    Nokia 6060……US $130
    Nokia 6111……US $160
    Nokia 8855– US$100
    PDA’s
    Toshiba Pocket PC E800 ========== $170 USD
    palm Treo 650=====================$180 USD
    HP IPaq Pocket PC H4150 ========= $150 USD
    HP IPaq Pocket PC H4350 ========= $145 USD
    Asus MyPal A716 ================= $135 USD
    Sony Clie PEG-TH55 ============== $125 USD
    PalmOne Tungsten C ============== $110 USD
    PalmOne Zire 72================== $105 USD
    Toshiba Pocket PC E405 ========== $100 USD
    PalmOne Tungsten E ============== $80 USD
    PalmOne Zire 31 ================= $60 USD
    Laptop
    APPLE G4 POWERBOOK 1.5GHZ SUPERDRIVE WITH 15 INCH DISPLAY……..$660
    APPLE G5 POWERMAC 2.0GHZ DESKTOP COMPUTER……………….$700
    APPLE G4 POWERBOOK 1.5GHZ SUPERDRIVE WITH 17 INCH DISPLAY……$600
    SONY VAIO A217S– 100GB– 512MB RAM– XP HOME……………..$500
    SONY VAIO B1VP– 40GB HD– 512MB RAM– XP PRO…………….$430
    SONY VAIO T370P/L– 60GB HD– 512MB RAM– XP……………..$400
    SONY VAIO A397XP– 80GB HD– 512MB RAM– XP……………..$700
    SONY VAIO B100B08 60GB HD– 512MB RAM– XP……………….$450
    SONY VAIO FS295VP 80GB HD– 512MB RAM– XP……………..$550
    SONY VAIO FS215Z 100GB HD– 512MB RAM– XP…………….$650
    SONY VAIO A417M 80GB HD– 512MB RAM– XP………………$650
    SONY VAIO B1VP– 40GB HD– 512MB RAM– XP PRO………….$300
    SONY VAIO T370P/L– 60GB HD– 512MB RAM– XP PRO……….$600
    SONY VAIO LAPTOP– VGN-A117S…………………..$600
    SONY VAIO LAPTOP– VGN-S1XP…………………..$700
    Xbox 360 premium package: $230.00
    Psp (play station): $165.00
    Ps2:$135.00
    Ps3:$235.00
    Ps1:$75.00
    Apple iPod nano 4GB:$131.50us
    Apple iPod nano 2GB:$112.00us
    Apple 30 GB Video iPod:$202.50us
    Apple 60 GB Video iPod:$217.00us
    Apple 20 GB iPod : $126.00USD
    Apple 4 GB iPod Mini:$105.00USD
    Apple 6 GB iPod Mini:$114.00USD
    Apple 40 GB iPod photo:$110.00USD
    Apple 60 GB iPod photo:$130.00USD
    Apple 30 GB iPod Photo:$116.00
    Apple 512 MB iPod Shuffle MP3 Player:$94.00
    Markjohnsonphonesltd..
    Isolo,Lagos..23401
    +2348022657523
    Thanks
    sales manager
  13. ok, i’m looking for a way to hook up my 6230 to a car stereo. i have an adapter that fits into the bottom of my phone. it has a 2.5″ female end. when i connect a 2.5″ – 1/8″ adapter to the phone’s adapter then connect a car tape adapter to that, i don’t get very much sound. help! also, i bought a 2 gig mmc card for my phone and it won’t read. how do i make it work?
    mastersfanmail@yahoo.com
    thanx.
  14. Hello Great Buyers,
    Here is newest offer given by our great company given to mobile phone
    sellers and buyers all over the world as mobile phone company has come
    to extend there mobile saleing to all over the world for people to get
    more achivenment and enjoy benefits of the mobile company.
    We deliver via DHL and deliver within 1day and 24hours to any part of
    the worlds..Europe,america,africa,asia,carribeans and all over the
    world as we make benefits in giving you 100% customer service and we do
    wire transfer to make things fast and effective as we send immediately
    after the confirmation.
    We have All kind of GSM UNLOCKED MOBILE PHONES,ipods and palm
    phones,LAPTOPS… Nokia, Sony Ericsson, Samsung, Motorola, Nextel.Our
    intrest… vodaphonestelecoms@yahoo.com
    sidekick 111…………..$140
    Sidekick II ………….$135
    sidekick 1…………..$70
    Nextel i35s………US$29
    Nextel i90….. US$59
    Nextel i60c– US$40
    Nextel i730– US$85
    Nextel i733– US$95
    Nextel i736– US$105
    Nextel i830– US$115
    Nextel i860– US$125
    Nextel i930– US$140
    Eten m500——us$220
    Eten m600——-Us$250
    Motorola razor V3……..$145
    Motorola razor V3i…….$150
    samsung d500…….$210
    samsung d600…….$230
    samsung d800…….$245
    Nokia 3650– US$185
    Nokia 3660– US$195
    Nokia 5100– US$65
    Nokia 5140– US$110
    Nokia 5510– US$105
    Nokia 6020– US$130
    Nokia 6670– US$105
    Nokia 6630– US$175
    Nokia 6100– US$80
    Nokia 6108– US$90
    Nokia 6220– US$105
    Nokia 6230– US$110
    Nokia 6260– US$135
    Nokia 6310– US$69
    Nokia 6310i– US$70
    Nokia 6600– US$135
    Nokia 6630– US$175
    Nokia 6170– US$145
    Nokia 6800– US$105
    Nokia 6820– US$110
    Nokia 7200– US$185
    Nokia 7230– US$120
    Nokia 7250– US$125
    Nokia 7250i– US$120
    Nokia 7260– US$135
    Nokia 7280– US$155
    Nokia 7600– US$165
    Nokia 7610– US$195
    Nokia 7650– US$160
    Nokia 8250– US$65
    Nokia 8310– US$90
    Nokia 8910i– US$185
    Nokia 8890– US$115
    Nokia 8800 ———— US$140
    Nokia 6680……US $220
    Nokia 6681……US $220
    Nokia N90……US $170
    Nokia N91……US $175
    Nokia N92……us $180
    Nokia N93……Us $210
    Nokia N70……US $165
    nokia n80…….$200
    Nokia 6060……US $130
    Nokia 6111……US $160
    Nokia 8855– US$100
    Sony Ericsson w800……us$220
    Sony Ericsson w800i…..Us$230
    Sony Ericsson w900…….Us$240
    Sony Ericsson W600i……..$210
    Sony! Ericsson V600i…$200usd
    O2 3G Datacard………$127usd
    Orange Blackberry……$200usd
    Orange 3G Datacard…..$165usd
    Orange SPV C500……..$145usd
    Orange SPV M2000…….$134usd
    PLASMA TV……..
    TELEVISION Panasonic TH-42PD50U Television…..$600USD Panasonic
    TH-42PX50U Television…..$1000USD Panasonic TH-50PX50U
    Television…..$1500USD Panasonic TH-42PWD6UY Television….$500USD
    Panasonic TH-42PD25U/P Television…$400USD Panasonic TH-42PHD8UK
    Television….$450USD Panasonic TH-65PHD7UY Television….$2500USD
    Pioneer PDP-5050HD Television…….$1000USD Panasonic TH-37PX50U
    Television….$500USD Panasonic TH-42PX500U Television…$800USD Sony
    KLV-32M1 Television………$400USD Sony PFM-42V1/S
    Television………$500USD Sony KDE-61XBR950 Television……$5000USD
    Sony KDE-42XBR950 Television……$1000USD Sony PFM-42X1/S
    Television…….$500USD Sony KDE-42XS955 Television……$550USD Sony
    FWD-50PX1/S Television…..$1200USD Samsung HP-R4252
    Television……..$500USD Samsung LN-R328W – LCD TV – 32….$500usd
    Samsung LN-R408D – LCD TV – 40….$800usd Samsung LT-P326W – LCD TV –
    32….$650usd Samsung LTM 225W – LCD TV – 22….$500usd Samsung
    PPM63H3-plasma panel 63…$2000usd Samsung HP-P5071 50-inch 1366X768 HD
    Plasma TV Ref…..$800usd Samsung HPP5031 – plasma panel –
    50…$100
  15. Dear Buyer,
    We have all brands of Mobile Phones,Ipods,Sidekicks,Nextels
    phone,Laptops for sell at cheap and affordrable prices, they ranges
    from Nokia/Samsung/LG/Sony Ericsson/Motorola/Alcatel/panasonic With
    Bluetooth, all Brands and Models of Nextel Phones, we want you to
    get back to us with your ORDER so that we can begin a good business
    relationship. Note they are all Brand New T2 Euro specs, unlocked,
    no operator logo, come in their original sealed box, With 1 year
    international warranty from the manufacturer, English & Spanish
    manual. We want to assure you that you will never regret buying
    from us because the delivery will be to your doorstep via
    FedEx,Dhl,TNT,and UPS Courier service.And the Tracking number shall
    be sent to you upon acknowledgement of your payment. Kindly
    acknowledge the reciept of our mail and get back to us at
    tpl_stock@hotmail.com
    +234-805-770-8225 , +234014802674
    Here is Our Price list””””””””””
    MOTOROLA MPX 220 AT JUST $135usd
    MOTOROLA MPX 300 AT JUST $165usd
    MOTOROLA V3X AT JUST $180usd
    MOTOROLA RAZOR V3 AT JUST $140usd
    MOTOROLA L7 AT JUST $150USD
    MOTOROLA Q AT JUST $160USD
    NEXTEL 1930 FOR A CHEAP PRICE OF…$110USD
    NEXTEL 1960 FOR A CHEAP PRICE OF…$150USD
    NEXTEL i870 FOR A CHEAP PRICE OF…$120usd
    NEXTEL i450 FOR A CHEAP PRICE OF…85usd
    NEXTEL I830 FOR A VHEAP PRICE OF…..$100USD
    NEXTEL 1860 FOR A CHEAP PRICE OF…$105USD
    SONY ERICSSON P910i AT JUST $150usd
    SONY ERICSSON K700i AT JUST $135usd
    SONY ERICSSON K750i AT JUST $140usd
    SONY ERICSSON P800 AT JUST $120usd
    SONY ERICSSON W800i AT JUST $1550usd
    SONY ERICSSON S700i AT JUST $140usd
    SONY ERICSSON S700i AT JUST $130usd
    NOKIA N93 AT JUST $305usd
    NOKIA N92 AT JUST $210USD
    NOKIA N91 AT JUST $190USD
    NOKIA N90 AT JUST $160usd
    NOKIA 9500 AT JUST $200usd
    NOKIA 9300 AT JUST $175usd
    NOKIA N73 AT JUST $200usd
    NOKIA N80 AT JUST $180usd
    NOKIA N70 AT JUST $140usd
    NOKIA 8800 AT JUST $165usd
    NOKIA 7200 AT JUST $130usd
    NOKIA 6260 AT JUST $130usd
    NOKIA 7210 AT JUST $135usd
    SAMSUNG D400 AT JUST $130usd
    SAMSUNG D600 AT JUST $190usd
    SAMSUNG D500 AT JUST $175usd
    SAMSUNG D415 AT JUST $145usd
    Sanyo MM-8300 …….$160.00USD
    Sanyo mm-9000……..$200.00USD
    Nextel i960……….$150.00USD
    ppc-6700 ,………..$210.00USD
    Sidekick III…………$170.00USD
    SIDEKICK II AT JUST $110usd
    TREO 600 AT JUST $135usd
    TREO 650 AT JUST $150usd
    TREO 700 P/W JUST $160
    Verizon/Motorola E815 EvDO for just $110
    Verizon/LG VX4500 Voice Recognition for just for $100
    Verizon’s World Phone for just $120
    Verizon/Motorola V265 for just $110
    Verizon XV6600 $130
    Verizon/Samsung SCH-a890 EVDO Handset $140
    Verizon CDM8940 3G EV-DO $140
    Verizon LG VX8000 EVDO $110
    Verizon/LG VX8100 $110
    Verizon/Samsung a950 $110
    PLAY STATION 1 AT JUST $100USD
    PLAY STATION 2 AT JUST $140USD
    PLAY STATION 3 AT JUST $160USD
    MICROSOFT XBOX 360 AT JUST $180usd
    Apple 20 GB iPod Nano……$60.00USD
    Apple 4 GB iPod Mini Pink M9435LL/A ……$70.00USD
    Apple 40 GB iPod photo……$85.00USD
    Apple 60 GB iPod Photo M9830LL/A……$110.00USD
    Apple 60 GB iPod photo …..$105.00USD
    Apple 30 GB iPod Photo M9829LL/A…….$95.00USD
    Apple 512 MB iPod Shuffle MP3 Player……$50.00USD
    Apple 4 GB iPod Mini Blue M9436LL/A…….$70.00USD
    Apple 2 GB iPod Nano…..$90.00USD
    Apple 60 GB iPod Vidoe….$150.00USD
    Apple 30 GB iPod Vidoe……$110.00USD
    Send us an email to our email our below:
    tpl_stock@hotmail.com,tpl_stock@jojomail.com
    Dear customers we deal in all kind of phones and we give you the best price.
    delivery method.DHL,TNT,FEDEX,which will be after 48hours .
  16. Please be VERY CAREFULL, the 6630 has a bridged audio output. You can’t connect the left ground to the right ground, they are active outputs and there will be circulating currents when playing a stereo music. You might burn the audio amplifier. If you use a 3.5mm jack adaptor, the ground should be connected to the wire with the tag GND and the R+ and L+ must have a 100uF each in series with the phone jack. This will prevent the DC bias current. But the output power will be only 25%. To use the full power you have to connect all the 4 wires separately to the phones. You can’t use a 3.5mm jack adaptor.
    If you have any doubts please e-mail me.
    arturqueiros@yahoo.com
  17. Dear buyers,customers in the world.
    Markphonesltd is now bringing awareness to you about the new
    mobilephones,ipods,pda phones,laptops.We are the exporter and importer of mobile
    phones in finland BUT currently selling in lagos state part of Nigeria..We are
    selling discount sales of mobilephones such as
    Sidekick’s,Nextel’s,Eten’S,Nokia’s,Motorola,samsung’s,Sony Ericsson,xbox
    360,psp,ps2,ps3,ps1 and other video ipod’s..All our product are brand new one,Is
    seal and package in the original box with one year warranty.We ship to po box,
    and home delivery to intrested buyer address.Our phones are Manufacture Company
    warranty..and two weeks return policy..We ship via ups,dhl ,fedex or Nipost to
    any where in the world within 48 hours of order confirme and issue a tracking
    number to confirm the shippment and Pls we need a legitmate buyr not a
    unresponsible buyers..Contact :Markphonesltd@inmail24.com
    Note:All phones have Englsih version,spanish,arabic,italian,russain,french and
    others
    Contact details of the head office;
    100 wagbon road,
    City:jasi
    state:Lagos,Nigeria..23401
    Phone number:234018722978
    Fax: 18722978
    Price lists
    sidekick 111…………..$145
    Sidekick II ………….$130
    sidekick 1…………..$70
    Qtek s200 =$100
    Qtek 9000 =$130
    Qtek 8310 =$200
    Qtek 8300 =$210
    Qtek 9100 =$240
    Qtek 8100 =$250
    Qtek s110 =$210
    Qtek s100 =$200
    Qtek 9090 =$210
    Qtek 8020 =$200
    Qtek 8010 =$180
    Qtek 2020i=$240
    Qtek 2020 =$250
    Qtek 8080 =$130
    Qtek 8060 =$160
    Qtek 1010 =$150
    Qtek 7070 =$250
    Nextel i730…………$85
    Nextel i733……………$95
    Nextel i736…………$105
    Nextel i830…………..$115
    Nextel i860……………$125
    Nextel i930…………….$140
    Eten m500-………………..$200
    Eten m600……………….Us$230
    Motorola V3Razor– US$125
    Motorola Q……………………..$200
    Motorola PEAL U6 Mobile Cellular Phone ………$115
    Motorola l7………..$120
    Motorola V70– US$100
    Motorola V80– US$99
    Motorola V750– US$110
    Motorola V525– US$115
    Motorola V300– US$118
    Motorola V400– US$120
    Motorola V600– US$135
    Samsung d500…….$210
    Samsung d600…….$230
    Samsung d800…….$245
    Nokia 7710…………..$145
    Nokia 3650…………..$100
    Nokia 3660……………$110
    Nokia 5140…………….$65
    Nokia 6020……………$85
    Nokia 6670…………..$105
    Nokia 6630…………..$115
    Nokia 6100…………..$50
    Nokia 6111…………..$65
    Nokia 6108……………$55
    Nokia 6220………….$105
    Nokia 6230…………..$110
    Nokia 6260…………..$135
    Nokia 6310-…………..$60
    Nokia 6310i…………. $70
    Nokia 6600……………$125
    Nokia 6630…………..$135
    Nokia 6170…………$120
    Nokia 6800……… …$70
    Nokia 6820………..$90
    Nokia 7200……….$140
    Nokia 7210 Turquoise…..$95
    Nokia 7230……………$100
    Nokia 7250…………….$110
    Nokia 7250i………….US$115
    Nokia 7260………$120
    Nokia 7280…………$105
    Nokia 7600………. $130
    Nokia 7610…………$135
    Nokia 7650………….$125
    Nokia 8250………….$65
    Nokia 8310……………… US$90
    Nokia 8910 Titanium, Black……….US$139
    Nokia 8910i-…………$115
    Nokia 8890 Black Limited Edition ………….$10o
    Nokia 8850 Special Edition– $105
    Nokia 8850 Gold Edition– $110
    Nokia 8800 ———— $190
    Nokia 6680…… $165
    Nokia 6681……$172
    Nokia N90……$170
    Nokia N91…… $175
    Nokia N92…… $180
    Nokia N93…… $210
    Nokia N70…… $165
    Nokia E70……..$175
    nokia n80…….$200
    Nokia 6060……$130
    Nokia 6111….. $160
    Nokia 8855…….. $100
    Nokia 9210 Communicator…..$145
    Nokia 9500 (communicator)……….$160
    Sony Ericsson P800……………….$150
    Sony Ericsson P900…………………$160
    Sony Ericsson P90a………..$170
    Sony Ericsson P910i………..$175
    Sony Ericsson S700…………$155
    Sony Ericsson S700i ………..$165
    Sony Ericsson K500i…………$100
    Sony Ericsson K700………….$115
    Sony Ericsson K700i-………..$120
    Sony Ericsson K750i…………$135
    Sony Ericsson T610……………$90
    Sony Ericsson T630……………..$95
    Sony Ericsson T68i…………..$99
    Sony Ericsson w800………..$200
    Sony Ericsson w800i…..$205
    Sony Ericsson w900…….$220
    Sony Ericsson w900i……….$225
    Sony Ericsson W600i……..$19o
    Sony Ericsson W600……….$195
    Sony! Ericsson V600i…….$158
    Sony! Ericsson V600………$160
    O2 3G Datacard………$129
    Orange Blackberry……$150
    Orange 3G Datacard…..$130
    Orange SPV C500……..$125
    Xbox 360 premium package: $145.00
    Psp (play station)………………. $30.00
    Playstation3……………………….$160
    Play station 2…………………….$70
    Play station 1……………………$50
    Apple iPod nano 4GB………………….$95
    Apple iPod nano 2GB………………….$80
    Apple 30 GB Video iPod……………….$100
    Apple 60 GB Video iPod……………….$120
    Apple 20 GB iPod………………………….$70
    Apple 4 GB iPod Mini……………………..$60
    Apple 6 GB iPod Mini………………………$65
    Apple 30 GB iPod Photo…………………….$95
    Apple 40 GB iPod photo…………………..$105
    Apple 60 GB iPod photo……………………$110
    Apple 512 MB iPod Shuffle MP3 Player……$55
    palm Treo 600…………………………………………..$150
    palm Treo 650…………………………………………..$160
    palm Treo 700w……………………………………….$170
    HP iPAQ h4150 Wireless Color Pocket PC ……….$125
    HP iPAQ H4150 PDA 400MHz, 64MB …………….$120
    Sony Clie PEG-TH55……………………………………..$105
    PalmOne Tungsten E ………………………………….. $80
    PalmOne Zire 31 ………………………………………… $60
    Intrested buyer should contact the regional sales Manager through this email
  18. We are gsm dealer, We deal on all brands of unlock gsm mobile phones such as Motorola, Nokia, Sony Ericsson, Samsung, Nextel, Qtek, BenQ, PDA,s, PSP games, Nextel, Sidekick II,Sprint,Ipods, Laptops, Mp3 players and many more at very cheap prices. We are using this medium of time to reach interested buyers of mobile phones. Our Gsm Phones are brand new gsm phones which includes the full accessories with brand new original manufacturer box, It include one year international warranty and Our phones are Manufacture Company class 1 tested And approved by global standard organization of Wireless industries. Forward your questions and enquires to us via email
    Do not hesitate to contact us for more details:
    Sales Manager:Joseph aaron
    cheapest_offer@hotmail.com
    Josephoffer@yahoo.com
    sidekick 3……………..$140
    Lrg sidekick 3…….$170
    Xbox 360 …….$170.00
    Playstation3…….$250
    Play station 2……..$70
    Play station 1……..$50
    Nintendo wii……….$200
    Nokia N90……$170
    Nokia N60…….$160
    Nokia N61……..$163
    Nokia N91…… $175
    Nokia N92…… $180
    Nokia N93…… $230
    Nokia N93i……$250
    Nokia N70…… $165
    Nokia N73……..$190
    Nokia E70……..$175
    Nokia N80…….$200
    Nokia E80…….$210
    Nokia E60…….$190
    Nokia N95……..$400
    Nokia N75………$280
    Nokia N76………$285
    Nokia 770 Table………..$350
    Nokia 8800(Black)………$210
    Nokia 8800(Gold)………..$220
    Nokia 8800 soricco……….$250
    Sony Ericsson W600i……..$190
    Sony Ericsson V600i…….$158
    Sony Ericsson V600………$160
    Sony Ericsson P900– US$195
    Sony Ericsson P910i– US$200
    Sony Ericsson P990 — US$250
    Motorola l6………..$110
    Motorola V60i– $75
    Motorola V70– $100
    Motorola V80– $99
    Motorola V750– $110
    Motorola V525– $115
    Motorola V300– $118
    Motorola V400– $120
    Motorola V500– $130
    Motorola V600– $135
    Motorola Q………$200
    Motorola V3 razor……….$100
    Apple 60 GB Video iPod……………….$110
    Apple 80 GB iPod photo…. ……………$150
    PDA’s
    HP IPaq Pocket PC H4150 ——— $170
    Asus MyPal A716 .—————- $155
    HP IPaq Pocket PC H4350 ——— $185
    Toshiba Pocket PC E405 ———- $100
    Sony Clie PEG-TH55 ————– $135
    Toshiba Pocket PC E800 ———- $200
    PalmOne Zire 72—————— $110
    PalmOne Tungsten E ————– $90
    PalmOne Tungsten C ————– $140
    PalmOne Zire 31 —————– $165
    palm Treo 650——————– $200
    O2 XDA Exec———————- $160
    O2 XDA ————————– $180
    O2 XDA IIi———————– $210
    O2 XDA Mini s——————– $190
    O2 Xda IIs———————– $310
    Palm treo 650…………………$150
    Palm treo 700…………………$160
    Qtek s110 =$210
    Qtek s100 =$200
    Qtek 9090 =$210
    Qtek 8020 =$200
    Qtek 8010 =$180
    Qtek 2020i=$240
    Qtek 2020 =$250
    Qtek 8080 =$130
    Qtek 8060 =$160
    Qtek 1010 =$150
    Qtek 7070 =$250
    Laptops
    LAPTOP’s
    Dell Laptops Dell Latitude D600———–200USD
    Dell inspiron 6000 ———————–300USD
    Dell Latitude D505————————-280USD
    Dell Latitude D610————————-380USD
    Dell Latitude D510 ————————240USD
    Dell Inspiron 9300 ————————430USD
    Dell Latitude D410————————-290USD
    Toshiba Qosmio E10 ————————650USD
    Toshiba Satellite PRO L20——————200USD
    Toshiba M100——————————580USD
    Toshiba M300 —————————–640USD
    Toshiba Portege A200———————-220USD
    Toshiba Satellite L10———————230USD
    Toshiba Qosmio F20————————400USD
    Sony VAIO VGN-T1 ————————–580USD
    Sony VAIO VGN-FS315————————320USD
    Sony VAIO VGN-S3 ————————–350USD
    Sony VAIO VGN-TX1 ————————–740USD
    Sony VAIO VGN-FS215————————–270USD
    Sony VAIO VGN-S5 ————————–610USD
    Sony VAIO VGN-FS295————————550USD
    Sony VAIO VGN-A517————————-490USD
    Sony VAIO VGN-S4—————————370USD
    Sony VAIO PCG-K35————————- 450USD
    Please Contact for more items if not found on posted list.
    Best Regards.
  19. We are mobilephone seller and ipods seller..we ship worldwide via fedex,ups and dhl.All these phones are brand new,seal and package in the company original box with one year international warranty.we deliver within 2 days to buyer doorstep:
    Any intrested buyer should contact through this email
    Josephoffer@hotmail.com
    Sidekick 3…………$140
    Lrg sidekick 3………$170
    sidekick 1…………..$70
    PPC-6700…………….$300
    Nextel i95cl………. $70
    Nextel 6510TM…… $110
    Nextel i730…………$85
    Nextel i733……………$95
    Nextel i736…………$105
    Motorola V3Razor……$100
    Motorola PEAL U6 M ………$115
    Motorola V60i– $75
    Motorola V70– $100
    Motorola V80– $99
    Motorola V750– $110
    Motorola V525– $115
    Motorola V300– $118
    Motorola V400– $120
    Motorola V500–$130
    Motorola V600– $135
    Nokia 3660……………$110
    Nokia 5140…………….$65
    Nokia 6020……………$85
    Nokia 6220………….$105
    Nokia 6600……………$125
    Nokia 6170…………..$120
    Nokia 6820…………..$90
    Nokia 7200………….$140
    Nokia 7230……………$100
    Nokia 7250i………….$115
    Nokia 7260………$120
    Nokia 7280…………$105
    Nokia 7600………. $130
    Nokia 7610…………$135
    Nokia 7650………….$125
    Nokia 8800 ——-$210
    Nokia 6680…… $165
    Nokia 6681……$172
    Nokia N90……$170
    Nokia N91…… $175
    Nokia N92…… $180
    Nokia N93…… $220
    Nokia N70…… $165
    Nokia E70……..$175
    Nokia N80…….$200
    Nokia E80…….$210
    Nokia E60…….$190
    Nokia N95……..$300
    Nokia N75………$250
    Nokia 770 Table………..$310
    Nokia 8800 Scirocco………$260
    Xbox 360 premium package: $170.00
    Playstation3……………………….$250
    Apple 80 GB iPod photo……………………$150
    Hope to hear back from you through the below emails.
Leave a Reply to ahmed el sokkaryCancel reply
