HOW-TO: SSH HTTP proxy setup
posted Aug 31st 2005 9:30am by Eliot Phillips
filed under: pcs hacks
putty config
We’ve been linking to a couple proxy options in the links posts recently and [tom] thought it would be a good idea to write up how to use Privoxy. In [tom]’s case he wanted to route all of his internet surfing at work through an encrypted tunnel to his home machine. The guide is Windows based, but it won’t be to hard to translate to your OS of choice. It starts by setting up an OpenSSH server and new user on the home machine. Then Privoxy is installed. Next PuTTY is used to establish the secure tunnel from the work machine. The last step is to configure the browser to use the proxy. You can use this for IM too. You may not need this at work or school, but it should offer you some decent protection if you’re out using open access points.
Recent Posts
Reader Comments
hack a day serves up fresh hacks each day, every day from around the web and a special how-to hack each week.
send us your hacks
hacks
resources
rss newsfeeds
powered by wordpress
Most Commented On (30 days)
Recent Comments
