[h. p. friedrichs] (AC7ZL) has some great plans for building a crystal radio. The stator coil and output coil are wrapped around the outside of a CDR sleeve. The tuning capacitor is constructed by sandwich two clear CDs between metal and attaching this inside the top of the sleeve. The rotor shaft is mounted using the bushings from a pair of disassembled potentiometers. A hot needle is used to tap the stator coil through the housing every fifth turn. Even though the parts aren’t very traditional it looks like a really solid radio. He’s got instructions for building a matching ear piece out of tea tins too.
Subscribe for weekly videos
Right ON! I remember my first Radio shack crystal set. Hours of fun.
This is a beautiful xtal set, his use of common items is impressive. Using a rotating coil helps out quite a bit when your trying to tune in a station. The tin box speaker desgin is very clever as well.
“Clever” is indeed the word of the day here. I never would have thought to use a CD spindle for making a crystal radio!
A crystal radio is one of those “must-have-must-make” projects that most tinkerers at some point tackle, whether it be as a kid from a kit or like this. This one takes it to a new level…very very nice!
Thought some people on this page might like this :-)
http://sfbayarea.craigslist.org/about/best/sfo/66795671.html
But does it work?
I’ve never seen a crystal radio that manages to convert the microwatts it pulls from the air into audible sound.
…then again, the ones I’ve seen weren’t as advanced and certainly did not have capacitors.
Stupid kits. grr.
whan the radio has a properly tuned tank circuit it need no power, other than amplification purposes if you need it loud
to theblunderbuss:
…i mention on my website that i have tuned the radio described to a strong local station and and collected enough energy from a fairly short antenna to actually light a red led. alternately, when used with headphones, the volume can be loud enough to make programming audible with the phones simply lying on the table. this is not stereo-level volume, to be sure, but a surprising loudness just the same.
hpf
Also check out Harry Lythall’s coffee-can-cavity-resonator “crystal set”. Works from a few hundred MHz up to 1GHz, try that with a traditional tank circuit!
I saw something very similar to this project, a crystal radio made from an empty cd spindle, in the March 2005 issue of The Xtal Radio Set Society. You can read the issue at http://www.midnightscience.com/comp.html
brasky:
from the bottom of the article:
This article was originally prepared for, and appeared in, the newsletter of the Xtal Set Society. Check them out!
That is nothing less than the art of radio right there.
just beautiful.
I want one !!
I want one !!
NICE !! I must be quite the nerd, ’cause I’m actually excited about maybe building one of these myself..
Wow great work!!
Just would like to add that crystal radio is one of those “must-have-must-make” projects that most tinkerers at some point tackle, whether it be as a kid from a kit or like this.
The moog suspension bushing was a nice choice.
