Metasploit Running On A WRT
metasploit
The folks from See-Security have gotten the Metasploit Framework running on a Linksys WRTSL54GS. They were inspired after seeing the Hacker Pimps pen-testing firmware, which we’ve covered before. The Metasploit Framework is used to develop and execute exploit code against target machines. The See-Security team ran into trouble getting Metasploit running due to RAM limitations. This particular model of router has a USB port so they were able to create swap space on a flash drive. The web interface worked as well once they set the bind address to the gateway IP. They’ve got all the steps you need to do this starting with OpenWRT.
[thanks muts and stillbourne]
10 thoughts on “Metasploit Running On A WRT
  1. OT but what would people reading this site recommend for a hackable AP other than the WRT? I’ve been reading and looking at the openwrt docs but all the routers it supports are all discontinued/unavailable or very expensive.
  2. #1 You might want to look at building your own with m0n0wall/pfsense (or any other router/fwall distro) they are very robust and the price can be very right if you use old hardware, or you can get small soho-formed hardware from PC Engines or Soekris(expensive)
  3. i just flew over the articel….
    he might get problems because he uses a USB stick for a swap partition.
    But these have a limitation of ~10.000 – 100.000 read and write cycles!
    That’s not very much for a swap partition!
    Greetings one
  4. So what was the conclusion? Was metasploit able to run on it or not? It seems like you’re saying that they were able to, yet at the same time you’re saying that they weren’t due to memory issues. I’m wondering whether it’s worth my time to read your article source if the whole effort was in vain due to memory constraints.
  5. So what was the conclusion? Was metasploit able to run on it or not? It seems like you’re saying that they were able to, yet at the same time you’re saying that they weren’t due to memory issues. I’m wondering whether it’s worth my time to read your article source if the whole effort was in vain due to memory constraints.
  6. metasploit is a library of exploits. Whats it use? It houses exploits you can launch with a payload on systems. Like lets say a pc has winamp, and of course it runs windows. I can boot up my linux pen test distro, Run metasploit, look under winamp apps and find winamp exploits, pick a payload, then launch it. Some might require the pc to go to a url (locally or remotely), and there’s ways to make a pc go to a url without them clicking. Why would we do this? Mainly to get command line, or root in linux. Another reason? Vnc injection also. It all depends on your needs.If your more of a newbie, or just want to quickly find an exploit, you can use the nice gui. If your a die hard cracker/hacker, or just learning how to fully use metasploit, you can also use it from the konsole.
    Now I will shutup before I tell you guys too much. And dont go emailing me asking me to hack your friends or how todo this and that :P
Leave a Reply to BaalpeteorCancel reply
