22 thoughts on “Laptop External Antenna Mod
  1. I’m going to do this one.. I have a miniPCI atheros total card with two U.FL plugs on it, but what I need is an external plug for testing and such. The tricky part really is finding a good spot to mount the SMA plug :(
  2. i have a compaq presario the antennas are mounted on pcbs underneath the plastic covers just above the hinges for the lcd. i have thought about mounting an external connector for antennas but i have a suck ass broadcom card and want better signal strength i want to retain the original pcb tennas but i havent found a good jack that would fit
  3. mojotek-
    basically, there are 2 leads going to the mini-pci slot, you need to splice into thoe wires. These wires are a main and a backup wire which run around the monitor of the laptop. It’s quite simple to do.
  4. This was done years ago with a “clamshell” mac and an airport card. I gotta contact the person that did it because he took down his “book” that has it in it and i dont know if he wants me to put it up or not.
  5. man, this is crap. i did this to my thinkpad t20 over a year ago with a rp-tnc connector so you can use the wrt type antennas. i also beleive i submitted and it never got posted. it looked really quite nice.
  6. ya im not impressed at this he used a pigtail with a card that had a connector for one and just drilled a hole. now if he modified an internal card that doesnt have a connector that would be another story
  7. Wow, exactly what I’ve been looking for… And all this time I was thinking how to boost the range of the router instead… Maybe finally I can get a little better signal through these concrete walls :p
  8. im surprised that many laptops dont come with plugs built in for attaching an external antenna, especially considering all the people that use laptops inside cars or in the backyard just out of range of a network, they could just plug in an extended antenna
  9. Adding external antenna capability to devices that don’t have it is classic hardware hacking.
    Kudos!
    (adding connectivity of _any_ kind rocks!)
    Internal antennas are a compromise at best.
    Free the radiating elements and you’ll see RF performance jump considerably.
    I scoff at “asthetics”.
  10. have been sourcing the parts (and time) to do this to a thinkpad t40
    I think I’ll put the the mmcx connector in one of the vents on the left hand side. I could put it above the audio jacks (hello interefence) or at the front end in the cpu cooling vent… the third option is to bog up the rj11 socket and bung it through there
  11. I been thinking bout this for over a year for my Thinkpad R51. There a cover over where a firewire port could have optionally been. Its between the vent and PCMCIA slot. Thats where i think i will put mine.
  12. Bah, I just went and bought a pcmcia card. The broadcom wireless card on my craptop dont get signal even when ur 10 foot away!
    So I dont know if making this external mod will make a difference. Please someone convince me. I have to be like 5 feet or closer to make my broadcom work…wtfover?
Leave a Reply to grayskiesCancel reply
