Record cutter
record cutter
Here’s a pretty rough project for cutting records out of acrylic. It uses a standard turntable for the base. The carving head is a chisel shaped needle attached to a small speaker. Speaker movement is translated into needle vibrations. The head is hand cranked across the surface of the record. The final addition to the system is a vacuum … Read the rest
