Toorcon Hard Drive Data Recovery
Eliot and I caught Scott Moulton’s talk on Hacking Hard Drives for Data Recovery. You can catch his slides here – but most of the content was in the talk. It was a great walk through of hard drive technology. Some interesting points: 85% of the time, software recovery is successful. 10% of the time, replacing the controller board succeeds. So, 95% of the time you can probably recover your data fairly easily.
Scott showed off a peltier enhanced drive sled for keeping a drive cooled for optimal operation/recovery conditions. He even got into replacing drive heads. If you’ve ever gutted a drive, you’ll know how fragile those heads are. You can actually fold a postit note to keep the heads apart and tranfer an arm with heads from a donor drive to get your drive working again. The difficulty of the operations seem to increase exponentially as the number of platters increases.
20 thoughts on “Toorcon Hard Drive Data Recovery
  1. “85% of the time, software recovery is successful. 10% of the time, replacing the controller board succeeds. So, 95% of the time you can probably recover your data fairly easily.”
    I think that actually translates to a total of 86.5% probability of recovery. If replacing the controller board works 10% of the time, it’ll only help in 10% of the 15% of the time that software recovery fails.
  2. I have used the controller swap method before when 2 drives in my raid-5 array died within 3 days of each other.
    The good thing about a raid is if you get all the drives at the same time then you don’t have to go around everywhere trying to get an identical drive.
  3. shawn, i think you are missing something vital: if software recovery works, i’m pretty sure most people wouldn’t go ahead and replace the controller board.
    so, while 95% may be a little too high, 86.5% is way too low.
  4. Terry, He understands that, so you do 10% of 15% which will give you the percentage of where replaced controller boards work. Which equals 1.5%, and then you add it to the other 85 and get 86.5%.
  5. Overall it was a good talk but he was less an expert than i expected (like most of the speakers). The way he spoke he sounded more like some random guy who has just opened up a huge number of hard drives (which i guess he was).
    “[The platters] are lubricated with something they call nanotubes” with a random picture of two rows of tubes in the upper right hand corner. Not very informative there. Yay tubes!
  6. Shawn and CaseyBlackburn have their math right, although it’s probably a little more complex than that. For example, if you have to replace the controller and then still have to use software recovery, you only have an 8.5% chance.
    Fred Thompson,
    I assume that when you fold the post-it, you fold it so the glue is inside. I also assume they suggest a post-it because they’re made of pretty smooth, lint-free paper. I’ll bet origami paper or parchment paper would be good as well.
  7. #11 Yeah, understood, but the nanotubes lubrication pipe system isn’t even being used outside of the R&D labs at Seagate. I’m a bit surprised that he even referenced it.
  8. the ‘presentation’ was shiteous… useless.. if whatever >80% recover w software then present some mothafugin software and compare efficacy or results not spank the monkey in 30000 shitty slides with hdd anatomy…
  9. If this is the same guy who spoke at DEFCON then yeah, this is a guy who has opened up a bunch of drives – nothing more. That guy had NO clue that *many* drives now store firmware on the platters and no idea how to recover it. He told me to swap the log board – duh that will NOT fix the firmware issue. This problem plauges Maxtor drives alot and you’ll see the drive show up as it’s family name in BIOS. Fixable with the right software but it’s NOT cheap If you can read Russian there are warez versions out there (lol)
  10. Not to beat a dead horse with this statistical recovery business but 86.5% is the correct figure. Here is one way of doing it (by analyzing the complete failure case):
    (failure rate of software) * (failure rate of controller replacement) = failure rate
    .15 * .90 = 0.135
    (possibility of failure OR success) – (total failure rate) = success rate
    1 – 0.135 = 0.865
    The way someone already covered is also correct:
    Showing that board replacemant solves 10% of the 15% software failures method:
    0.10 * (1 – 0.85) + 0.85 = 0.865
    Showing that software recovery solves 85% of the 90% of software failures:
    0.85 * (1 – 0.10) + 0.10 = 0.865
    Due to the unusual amount of constructive negative criticism I have to balance things out:
    wat r we lookin @ her folks lol i meen is it just me r wat weres the hack lol o #13 ur wit me ne1 else???
  11. the way it’s written, and the way the slides had the figured listed, the 95% figure seems correct. What you guys are listing are the conditional probabilities and you don’t have to do that in this case. it is pretty straight forward, out of every 100 hd’s crashed, 85 were software fixable, while 15 were hardware problems. the 10% number is that 10% of the 100 would be the controller board.
    If it were worded “10% of the remaining hd’s were the controller board” then you would be correct.
    a pie chart would have made it clearer than the vertical bar graph in the slides
    mmm pie. now i’m hungry
  12. When I gave the presentation, I guess you missed the part about how I was trying to help people understand that they can do some forms of data recovery themselves and cheap and under $200 in most cases. It is not meant to be an end all to data recovery.
    If we all were able to read the firmware off the platters, then we would need to be able to burn it back to the chip on a good board when we get one. If you thought I would try to whip out a rom burner or write something to bypass every manufactures firmware to plant it on the drive I think you missed the point of the talk.
    By the way, I am pretty sure without help from the manufacture with SPECIAL equipment you can not read that info from the drive since the equipment that writes the Servo Info is not easily available. That would defeat the purpose of the less than $200 target of doing recoveries for youself. I have hand several hundred people email me that said my info helped them recover data they had no idea about before.
    And BLKMGK – I don’t know what a LOG board is, I think you meant LOGIC BOARD……
  13. I have been seeking a internet place similafor some time. Numerous years ago I bought a whitewings book and made some astonishing stuff. Can you please share more on this theme. Perhaps you will find some other data out there. I’ll let you know if i find anything else likewise.
  14. I love wager on horses. It allows me to put a wager on horses from the comfort of my own home. Don’t get me wrong, I also love going to the race tracks to get the all-around experience. Forutunately for me I’ve had good lucky recently and I made money on “Mine That Bird” during the good ol Ketucky Derby.
Leave a Reply to Betting with HorsesCancel reply
