DIY TOSLINK to SP/DIF converter
posted Dec 12th 2006 11:50am by Will O'Brienfiled under: misc hacks
Given the variety of… uh, non-traditional hardware that’s connected to my home theater, I’ve found the ground isolation provided by optical TOSLINK connections pretty handy. After poking around a bit, I found a stand alone coax to optical converter. It uses a hex inverter to convert the signals to TTL levels, and a Sharp (or toshiba with some extra components) optical transmitter.
1st?
Reminds me of what I need to eventually do…
Posted at 12:15 am on Dec 13th, 2006 by Nick
