[Jonas] sent in a surprisingly retro concept given the number of small cheap funky video recorders on the market. He built his own. At the heart is a sony Digital8 recorder, combined with a security camera and a SLR lens. It’s finished out with an LCD viewfinder and a handful of AA batteries to power the security camera.
15 thoughts on “DIY Camcorder”
Leave a Reply to LegendHasItCancel reply
wow.. that’s awesome. anyone have an idea how to record from the thing if you’re using a camera with an analogue output and don’t have the digital8 recorder? i love modular design concepts like this, but for me it falls down at the requirement for a specific recorder, which if it was cheap on ebay before, probably won’t be now.
You can use a DVR like Archos AV-500
By the way…
I’m curently about to make a 2. version camera, smaller, better, etc.
But i’m needing a super8 camera for it
So if any one would like to donate one for the project…
Please contact me through my website: http://www.c-h-a-o-s.com/chaos_c-h-a-o-scomcontact/
Pretty good. As a pro camera op, I’d be a little afraid of what my clients would think if I showed up on a shoot with one, but I do actually use a quite similar system for shots where I can’t put a big ol’ broadcast camera. I use a very small security camera, just with its built in optics, and a wide angle converter, and then a $200 MiniDV camera with analog inputs. Makes a perfect rig for doing things like taping to body panels of cars or flying down a road inches above the ground. (Obviously with the MiniDV recorder/camera in the car, but the security camera outside).
And as to the Super8 camera, are you going to add a CCD where the film plane was? That’d be a pretty cool idea. EBay always has a ton of really cheap Super8 cameras.
I dont get it, you said you used mono camera yet viewfinder picture and .mov file both have color
Well… I had to try with a colour of course
Awesome, I’m building a undercover police car and this will make the project so much easier than using scraped parts from a decom
HMM why not use a Hard drive instead of a Super8? I’d be interested in something like this if I could tak on my own 400GB IDE drive… at very least it’d be cutting edge as the HDD camcorder seem to be the latest trend these days.
I gues you are refering to the upcomeing version i want to make…
It is going to be with a harddrive… but i still need the super8 camera to make it.
by teh way, I read your post about the HDD recorders and you wrote you don’t want mpeg4 .. and you used mpeg2 converter .. ??? Am I missing something? mpeg4 gives better quality than mpeg2 when using same stream bandwidth
Mpeg2 converter… Nope! As discribet in the project i use pure DV and by my knowlegde DV vs. Mpeg4 is like Raw vs. Jpeg…
This is why i like the Quickstream… it can record in DV to its harddrive and the Canopus ADVC55 is a standard Analog video to DV converter…
It’s all pretty simple. ;)
I built something similar about 6-8 months ago for infrared night videos. I use my COWON A2 as a DVR.
Toshiba Color super low-lux security camera with a manual focus, manual zoom lens (autofocus would be way better.)
Camera powered by three 2400mah LiIon batteries built in the frame.
5 watt Infrared LED illuminator… Which is TOO powerful for anything closer than 10 ft.
Removed the camera’s infrared filter, so on daylight videos the color is a little off, but I didn’t intend to use it as a regular camcorder anyway.
Still needs some finishing touches, but works fine.
Photos here:
http://www.az123.com/NVC/back.jpg
http://www.az123.com/NVC/side.jpg
Short demo video of camera in dark room here:
http://www.az123.com/NVC/nvc.mpg
eh.. i wouldnt call that a do it yourself camcorder since it uses a camcorder in the first place
Totally is a DIY camcorder! It doesn’t use a camcorder… It uses a CAMERA and a RECORDER. Put the two together, and ya get a CAMCORDER. Get it?
This article is great!
some alternatives to the digital8 recorder are the samsung sports camera, or, if you want to use your own security camera, the aiptek personal media recorder/camcorder, which is $150 and records your video to an SD card.
and, it includes the screen, so in the end, it saves about $350
