[Jowan] sent in this excellent gameboy cartridge hack. The cartridge contains 1MB of flash and an 8 bit serial I/O interface. He’s using it to play percussion with some solenoids and a custom rom. If you guys like it, he might be convinced to put together a how-to on hacking the cartridge.
13 thoughts on “Game Boy Drum Machine”
Leave a Reply to SilasCancel reply
now run the mario theme through it =)
a how-to would be GREAT, i’ve been looking for something like this
A super easy way to do this using a Nintendo DS (66MHz ARM9 + 4MB RAM, much nicer than a GB/GBC) is by using the DSerial. It gives 18 GPIO lines, has PWM, ADC, UART with RS232 level compatibility, as well as a 2D tilt sensor for the heck of it. You can basically use it to interface to anything. Check it out here:
http://www.electrobee.com/product_info.php?ref=4&products_id=20
I’m trying to build a NDS-based heart monitor with mine, check my blog to see my progress on it: http://blog.davr.org/
That’s great! A how-to would be awesome please! :D
AWESOME! I love projects involving GameBoys prior to the advance… A How-To would be great!
HELL YEA!! add the rom hak.
very innovative!
the link port on the GBA SP can also be used as an RS232 serial port, but a level shifter is required to get the voltages correct.
That is officially the coolest thing I have seen today.
I would love to have a how-to on er… how to do this.
I have a gameboy color that is just gathering dust right now. This could be a fun way to get some more life out of it.
i started off with this version – GameBrain Ver 1
http://file-error.net/gamebrain/index.html
which is taken from the ‘gameboy project’ http://marc.rawer.de/Gameboy/index.html . Much respect to the man, all his work.
There is an amazing PDF on his site that does explain everything but it involves making your own, so, i will do a ‘how-to follow the pdf’ page asap. This will involve home etching and a parts list, and a few thing i felt the pdf left out, all pretty easy stuff, no smd, and cost about 5 quid per cart.
You can do anything with these cart including sensors, actuators and communication such as serial and midi – woohoo
Also the rom is on the page, it uses a basic shell then a really simple program written in GBBasic so lots of loops and bleeps, kiddy programming really but then i am an not techno wizard, i just love the creative use of technology. – jo
It shouldn’t be hard to get some cheap drum triggers (tk-9 i think?) to trigger of a real drum kit and hook them up. I think they run ~10$ each…
great idea and execution. can’t wait for a tutorial!
Very nice work!
_always_ great to see the Game Boy and DS hacks!!
Much updated version
http://devel.8bitplateau.net/kbang
downloadable rom and audio files.
JSP
