[Nick] caught [Alex]s GPS enabled AVR, so he sent in his project using the same Telit GM862 module. Rather than depend on an external AVR, he wanted to use the on-board python interpreter. Apparently, documentation is a bit sparse, so he put together a good write-up on developing python for the device. Since the GPS unit takes up the com port previously used for debugging info, he added a hardware python debugging board to speed development.
2 thoughts on “Python On The Telit GSM/GPS Module (vehicle Tracking)”
Leave a Reply to RusHCancel reply
finely a complicated avr hax wooooo
why use expensive module ($150-300) when you can use any GSM mobile with AT comman set ($10 on ebay, any old nokia, Ericsson T10) plus cheat GPS module ($30 ebay)
