Breathing Walls with Shape Memory Alloy Wire
When you need something quietly bending or moving, don’t underestimate SMA’s (or Shape Memory Alloys). The Living Glass project by architects [David Benjamin] and [Soo-in Yang] catalogs an experiment in building interactive, flexible, “breathing”, walls out of SMA wire and microcontrollers. Although they use Basic Stamps, the project could easily be extended to more cost-effective microcontrollers for large surfaces. The project is well documented with videos (AVI) of each prototyping step and even includes the ideas that were ultimately scrapped. Even if you don’t build a wall of interactive gills, this project should give you plenty of ideas for uses of SMA wire embedded in semi-flexible materials.
8 thoughts on “Breathing Walls with Shape Memory Alloy Wire
  1. I believe that it is intentioned as an air circulation method. Or at least that is what I assumed after reading their article and test photos.
    I doubt it is chemically and biologically secure when closed but I can see green houses and energy efficient singular level homes using it.
    But it just damn looks cool also.
  2. I’d had a twisted idea utilizing this very same wire, micro controller and an interactive pron program. Unfortunately, I thought about the effects of a shorted controller stage and the subsequent effects of excess current through the wire. Needless to say, the idea was scrapped…
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
