Normally, this wouldn’t quite make my radar, but [sprite_tm] built it, and it’s funny as hell. He created a Terror Level indicator for… his toilet. Rather than create an exotic smell detector, he simply uses a photo diode to measure the amount of time that the light has been on in the ol’ water closet. As time progresses, so does the Terror Level indicator. To make an audible indicator, he used the PWM generator in the ATTiny231to create a sort of ping sound when the level escalates. (I can definitely think of someone I need one of these things for.)
11 thoughts on “Toilet Terror Level Indicator”
Leave a Reply to BigD145Cancel reply
a motion sensor of some kind combined with some fancy code could be used to determine if someone was in the bathroom too. it would have to determine the difference between motionless(room empty) and motionless(someone on the toilet)
he should have his terror levels indicated like “ORANGE” and “RED” instead.
Pressure sensor under the toilet seat would be a better way to measure whether someone is using the toilet instead of burshing their teeth/shaving in the washroom with the light on.
Mine would have just 2 levels.
1) Find a gas mask
2) Put on the damn gas mask.
~/ronWhite~
ain´t that the sign over a toilet in a store in sam & max 4
Yeah it is cheerios, no idea if it’s from the 4th though as I haven’t played it. It says it’s from the 2nd episode on the site
“I wasn’t the only one who came up with this idea: I have to admit I ‘borrowed’ it from the second episode of the ‘Sam and Max’ adventure series. The terror indicator in there has three colors: green for ‘all safe’, orange for a ‘number one’ and red for a ‘number two’. I liked the layout, so I decided to copy it. So, three levels of terror it was.”
cheerios: Yes, it’s in all of the Sam & Max episodicals. :)
I’ve spent so long in the can I’d have to add one more level of terror: “Call the morgue”
now that’s some funny shit!
How about a decibel meter? I know the silent ones can be trouble, but I also crack a smile when someone busts loose a nice wet one in the stall next to me.
I would have used pressure sensors for the toilet seat, because the photo diode would be useless if someone left the toilet and left the lights on or something.
