9V Battery As A Project Case
I stumbled on [Carlos]’ blog while I was hunting for Arduino ideas. This simple IR detector caught my eye – not for the project, but for the project case. He stuffed his IR detector inside an old 9V battery case. The TSA probably won’t like it, but it’s a fantastic idea for those smaller projects.
10 thoughts on “9V Battery As A Project Case
  1. would be a heck of a stylish music player. (drilling out the larger negative terminal for a headphone jack)
    the problem at that point wouldn’t be the circuitry but probably where to cram in the batteries.
  2. Thats why you leave one or two of the little 1.5v cells in there, power it offa that… probably not your safest move, but, it would work… take up some space though. Maybe stick an empty 9v on top a full one? Put a 9v clip into the base of the gutted battery, circutry on top, click another nine volt of the bottom… idk, cool idea though.
  3. If you use a fresh 9v battery you can leave in a couple of the 1.5v cells that it’s made from and cram the circuit into the remaining space.
    Alternatively small li-ion cells are available which should fit easily – and charging chips like the MAX1555 are *tiny*.
Leave a Reply to DaneCancel reply
