When I built my LumenLab projector, I used a thermal switch to run the fan. This simple control circuit looks like a nice alternative. The circuit is a simple adjustable temperature triggered Fet. If you know the resistance needed, you can replace the potentiometer with a cheap resistor. (You’ll want to use a DC fan)
3 thoughts on “Simple Fan Controller”
Leave a Reply to patrickCancel reply
I wonder, in the state that the fan doesn’t spin where the voltage is too low for it to start rotating, will it slowly burn out?
Nice – just what I need for my latest project: APRS temporary digipeater in a box. This is a better solution then a fan running constantly – even when it’s not seeing any use. – Kris
I made a similar one a while back, still using it in one of my computers to regulate a fan: http://www.swisstech.net/util/lm317t/
