[Steve DiRaddo] sent us this sweet little mod. After obtaining a free LCD TV that had a cracked screen, [steve] immediately tore it open to re purpose it. The end result was a computer controlled light table with audio. From what he says, it is very very bright due to the fact that it has 16 CFL tubes behind it as opposed to the usual 2 inside a PC monitor. The TV had a bult in RS232 command port. Whith some quick hacking, he was able to control power, channel, input, and volume via his laptop.
24 thoughts on “Broken LCD TV Turned Into A Light Table”
Leave a Reply to r1b4z01dCancel reply
“I’d like to be able to feed several audio inputs into the thing and be able to select which one I want. Too bad for me, if there isnt a legit video signal entering that input, it ignores it completely. The TV will only switch to an input with an active video signal. A quick and dirty way to fix this is to take a single composite cable and plug one end into ‘Monitor Out’, and the other into the video input of your choice. This is called video feedback. It works though. If the screen was still working we’d see some really weird shit. Luckily, we aren’t exactly going to be needing good video for our purpose.”
You can also just solder a 75ohm resistor across an RCA plug to make a terminator, and plug it into the video input. This did the trick on my TV.
Definitely very cool – but seriously, does anyone still use film/negatives? Methought everything was digital now.
I use a light table every day as do nearly all of the artists in the tattoo industry for tracing line drawings for stencils they’re not only used for film also make great soft boxes for photographing finished tattoos to display in our portfolios because they don’t create nearly as muck glare on the fresh tattoo as normal florescent lighting does and way less than a camera flash would.
Or you could just pick up a scanner for 3 bucks at a thrift store.
http://hackaday.com/2006/05/26/macro-photography-light-from-broken-lcd-monitor/
I suppose it’s alright since the old links aren’t good anymore.
I have a traditional light table and I use it all the time. I still do a lot of analog art (not photography) and it’s always useful. If nothing else, it’s really cool to have a nice piece of glass to cut things on. Mine has two layers – one of frosted plexiglass, and a top layer of tempered glass. I’ve also used mine for photo-exposing silk screens. Controlling the exposure time with a computer would be super cool.
Could use it for tracing.
@chrisla
Thanks for the tip! I will apply this to all inputs and update my site with credit to you :)
well at least the busted tv didn’t get thrown in the trash can like everything else that breaks these days.
This is not very effective for serious transparency (slide) review. Real light tables produce actual white light. Use a loupe to look at the “white” screen on the monitor and you will see the readily apparent components of the additive (RGB) color system rather than the white you expected.
keystoneclimber,
he’s just using the CCFL bulbs, not the LCD screen. They’re pretty darn white.
I’ve just tried this with a broken LCD. After LCD screen removal, the remaining light panel is very interesting: portable lighting system for photography/video, or may be flat light on the wall or ceiling…
On mine, there’s a light diffusing plastic sheet on top of lighting panel, but once LCD panel removed, nothing keeps it in place anymore. So i’ve tried to dismantle the LCD panel itself hoping i could reuse the plastic screen.
On one side, there was an adhesive sheet of dark plastic, and just under the broken glass. Once removed, the remaining part cleaned of the liquid cristal, i’ve realized it is in reality a polarising filter and could be usefull also! But in the other hand, it is a little dark, so it reduces the amount of light going through. I think i could remove another adhesive sheet of plastic on the other side but i prefer to keep the polarising filter as is.
After this process, i was wondering if liquid cristal could be toxic. I should have think about this before dismantling the LCD glass panel :-< Does anybody know?
There is no evidence at all that liquid crystals pose a health risk for humans, but tests are ongoing. At this point in time the teeny bits of glass that shred off at the edge of a cracked screen are far more dangerous.
Maybe I missed it, but what brand of LCD TV is this?
How did you find out the RS-232 command set?
Are there RS-232 commands for controlling the brightness?
Just a word of caution. While taking apart an lcd monitor, I realized that I opened the florescent light part of the monitor and probably exposed myself to the mercury.
Hello. Great job. This is a great post. Thanks!
Yeah, gotta watch the Mercury… otherwise these are great for coffee tables, ironing boards, fireplace covers, and/or otherwise making it look like you own a lot of TVs…
Aloha! I sumbled upon this site by chance, I was browsing Google for deals on LED televisions when I found your website. I�m lucky I found it. Just what I was browsing for. Favorited your site, I will continue my research tomorrow
I believed this was a really fascinating post and I am really glad that wrote on this subject matter, there are not too several other weblogs that take this perspective
My work donated a busted screen 32″ Apex Digital HDTV to me, but needed to keep the working power supply board and controller board for other projects. With just the inverter board and screen, is it possible to supply power enough for the backlight to craft into a light table?
hey all good itea amd im using a lcd monitor as a light table the only thing is i have to keep it plugged in to my computer and extend desktop to keep backlight on.
the lcd is broken and only backlight works.
i would like to figure out what to do to keep backlight on, i’m an electronics amateur, i know a little but dont want anything to involved.
have tried resistors across vga imputs, looked up pinout and other sites but cant seem to figure out how to keep it on short of plugging into computer and making active monitor.
HELP PLEASE
Dan
@ daniel w That’s exactly what I am trying to do as well and usually end up getting to about ***HERE*** using various avenues of research. No one has been able to help me power up an LCD from a laptop without using the accompanying computer.
Here’s the link:
This is the best answer I’ve gotten–just picked it up.
http://answers.hackaday.com/is-it-possible-to-use-an-old-lcd-as-a-diffused-light-source-in-other-words-just-have-the-ccfl-on-so-that-the-lcd-would-be-totally-white/
Argh Argh, it’s coming from every available channel, its mike tyson dressed as 3d me punching out my display conveying me. What am i acting out
