Reader [Mike] was not too impressed by design in a recent post we did on an LED menorahs. Doing what any self respecting hacker would do, he designed and built a better one then sent it in to us. He just happened to have an AVR ATtiny13 sitting around, so he used that for the brains. It has single button operation, is powered by 2 AA batteries, and even simulates the candles burning out. His custom PCB turned out quite nicely as well, the power plug connects to the batteries in a way that uses them as a base. Check out his site for detailed plans and source code. Great job [Mike].
Improved LED Menorah
7 thoughts on “Improved LED Menorah”
Leave a Reply to TechnoRabbiCancel reply
far more impressive than my attempt at the same
With it’s simplicity and visual symmetry it’s really very nice.
Well thought out and well done!
I don’t really like religion…
It looks intelligently designed.
I see what you did there! ;)
This is not a Menorah. A Menorah has 7 candles.
This is Hannukiyah – For Hannukah candles.
Obviously no one Jewish on hackaday…
Reserver is partially incorrect, some menorah do have 7 candles, but there is not a elevated middle candle. Most modern menorah have 8 candles, but the very fact that it is an electric light makes it non-Kosher, as it has to be FIRE!!…Either candle or oil.
Nice hack, but not a kosher menorah.
