[floe] wrote in to tell us about his multitouch based thesis work. While many projects have focused on the hardware side of multitouch, TISCH is designed to promote the software side. TISCH is a multiplatform library that features hardware abstraction and gesture recognition. This takes a lot of weight off of widget developers since they can specify known library gestures instead of writing the exact motions from scratch. Using TISCH also means a standard set of gestures across multiple widgets, so the learning curve will be much easier when a user tries out a new app. If you’re researching multitouch, check out this project and help improve the codebase.
Subscribe for weekly videos
So when are they going to combine this with smart paper? It would be pretty sweet to have google maps on a real honest to god folding map.
@polymath:
That would just mean that you’d have to fold it up!
*g* get me some smart paper with touch sensors that can take being folded and I’ll integrate that right away..
hey I never said it would be easy! there’s a reason why I switched from electrical engineering… but I did find this http://www.engadget.com/2008/11/24/samsung-concept-phone-unfolds-to-hypnotize-onlookers-with-flexib/
is there foldable smart paper? Cause it wouldn’t be very hard to add capacitive touch to it, then you hook it all to a small wearable computer. Must go do research now ^_^
is it just a coincidence that tisch is an acronym for “Tangible Interactive Surfaces for Collaboration between Humans” and also means “table” in German?
@alex: nope, not coincidence ;-) a colleague of mine came up with it, as the first hardware device it ran on was a big ftir-based interactive table.
