Make: television premiering today
maketv
Make’s television series will be premiering on public television across the US over the next couple days. If it’s not showing in your area, you aren’t out of luck. All of the segments from the first episode have already been published online at makezine.tv.
Comments
  1. Almost_There says:
    My girlfriend got me a subscription to Make Magazine for my Birthday last year; the only thing I tried to make was “The Amazing Seebeck Generator” (http://makezine.com/15/seebeck/), which claimed you could get 5 volts at 1 amp from a single small Peltier device over a single candle.
    I spent time and money building it, but it didn’t work anywhere near as well as claimed. Then I did more research and found out that there was no way in hell anybody was *ever* going to get anywhere near the output claimed. Maybe 0.5V @ 1A with a blowtorch (not a candle) on it… maybe!
    Even at that, you are pushing the device *WAY* beyond it ratings, so it will only do it for a short while; then will it become weaker and weaker the longer you push it that hard.
    At best they got 5V open circuit (with a blowtorch) and 1A short circuit, and then claimed you could get 5V @ 1A (i.e. into a 5 ohm load.)
    In summary: Make is cool for creative ideas, but don’t blindly trust their claims.
  2. pt says:
    @Almost_There – if you look at the feedback on the article page which you linked to and all the folks who *did* get it to work i would say that it’s likely you didn’t build it correctly or gave up too soon without checking out the tips and hacks. you could email us, post in the forums, talked with other makers or documented your project. but it seems posting about this on our tv debut post is all we’ll get.
    if you only built “one thing” it’s possible that you’re not an expert in making things like this. part of making is trial and error, not every project will work on first try. we don’t expect anyone to “blindly trust” claims, but i don’t think you gave this project a chance. if you’re interested in getting the project working join in the discussion on the page.
  3. Almost_There says:
    Several people have run these up to 400F, which is *WAY* over the maximum rating, so they will deteriorate over time. No one came even close to 5V @ 1A with a single candle (not even with a hacked candle.) You might want to read what Don Lancaster has to say about the efficiency of these things at http://www.tinaja.com/glib/hack68.pdf
    Some select comments from the page where you said people got it to work…
    >it was able to output just over 8 volts no load, and 2.5 amps at .1 v. Again at over 400 degrees f.
    >I supported the test rig over a heat gun and was able to get the hot side up to over 400 degrees f. ( I agree this is way too hot), however I wanted to see what the absolute highest output voltage I could get from them.
    >As I said I tested at temperatures too high for regular use
    >I think the 136 watt coolers I used will be useless at candle energy levels
    >I got up to a 4V, 200mA output by hacking the candle
    >I have done a little research and it appears that the TEC modules have an upper end of about 180 degrees C.
    >interesting idea, but I think the TEC modules are the weak link.
  4. pt says:
    @Almost_There – again, have you posted on the magazine page besides saying “it doesn’t work” or have you contact MAKE or the author? this news story is about Make: television, it’s seems odd to be discussing it here without any way to actually get help with your project.
    i’ve reposted this comment from the other places (not on MAKE) that you’ve continued to post on.
  5. Almost_There says:
    No one came even close to 5V @ 1A with a candle (not even with a hacked candle.)
  6. pt says:
    @Almost_There – again, it’s puzzling that you do not post on the MAKE article page, contact the author or the MAKE team.
    others have got this project working, you said specifically that you’ve only made one project, i think it’s very unlikely that you could get it to work first try, please post on MAKE, contact the author or email us – i’m not sure why you keep posting this around the web in multiple locations.
  7. Hey, I found your blog with bing.. gonna bookmark this ;-)
  8. derek says:
    I am very grateful that I have discovered your posts, thanks for all the helpful info.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,295 other followers
