Foundation cooling
Foundation with Copper
Overclockers are always trying to come up with new, colder, and quieter ways to keep their PCs cool. [gigs] was so dedicated to this, he decided to lay 6 meters of copper pipe to use as a radiator in his new house’s foundation. As of now, the foundation is laid (copper pipes and all), and the forum posts … Read the rest
Experimental search engine display
gtse
goodTimes.searchEngine is an experimental set up to display search engine results. Be sure you’re using Firefox or IE, because it isn’t working with chrome right now.  [Gordon] pointed us to it and asked for our feedback. We had a pretty quick list of improvements we would like to see, such as the category changes not popping up in new windows, … Read the rest
PS3 Slim Teardown
be1bSIBJJAk1dEvk.large
The new PS3 Slim has just been released, and ifixit has already posted a teardown. First, they easily removed the included 120GB hard drive, suggesting that upgrading it  shouldn’t be too hard. In order to get inside the cover, however, they needed to use a security Torx screwdriver. In the end, the Blu-ray drive turned out to be the … Read the rest
Propeller Platform
Propellor_Platform
[nmcclana] has posted an assembly walkthrough for an Arduino-style prototyping board for the 80 MHz, eight core Parallax Propeller Microcontroller. While not board compatible with Arduino shields like the ARM-based Maple board we covered, it does have that familiar layout, and provides access to all 32 I/O pins, and the 3.8″ x 2.5″ footprint was kept in mind … Read the rest
DIY bench vice
diy_bench_vice
A bench vice can be one of the most used tools in your workshop.  For those that don’t have a workshop [Matt] built a vice that clamps to a table. He used scrap wood, MDF, threaded rod, washers, nuts, and wing nuts.  Cheap, easy to build, and very useful!
[via Toolmonger]… Read the rest
Hard rock radio
rock_radio
[Guus] sent in his project where he put a radio inside of a rock. He started with a 1970′s car stereo and encapsulated it in cement by wrapping it in duct tape, building a wooden form around it, and pouring in the wet cement. Three ports are included on the back for power, antennae, and speaker. He included an Read the rest
WiFi Mapping with a smartphone
map
Not so long ago, mapping WiFi required a laptop, GPS, a big antenna and Kismet/NetStumbler. Today’s smartphones have replaced even this task. For those of us running a GPS and WiFi equipped Windows Mobile phone, WiFiFoFum is an excellent and simple solution, as well as a great companion for installing an AP. … Read the rest
