Laptop Running On A Sealed Lead Acid Battery
steupup_box
[Viktor’s] laptop needed a new battery; he had the trade off between carrying around a cheap but heavy sealed lead acid (SLA) battery, or buying an expensive but light Li-Ion battery. Figuring his old laptop was pretty heavy already, and having an unused SLA available, re-purposing it for his laptop wouldn’t be too much of a hassle. Using a boost converter he built out of a custom dip MAX668, he is able to output the necessary 5 amps required. An MC 34161 voltage monitor chip is planned for future revisions, but he’s currently running it just fine. Check out some of his other cool hacks on Karosium.
Related: MSI Wind extended battery
24 thoughts on “Laptop Running On A Sealed Lead Acid Battery
  1. Doesn’t seem that portable… but, then, msybe the doesn’t need it to be that portable. Regardless, it’s always cool to see what kind of ingenious solutions people come up with using spare parts and spare time. Needs more arduinos, though.
  2. I did the exact same thing back in 2000… except that i didnt know what i was really doing. and the only thing i did was a conection straight to power jack and the 2 leads from the battery. worked pretty good. xD
  3. I have a laptop running off a SLA using a car adaptor – the Asus Eee 701 can be picked up & held easily with just two fingers, but the 24kg 70Ah SLA needs two hands to pick it up. No they don’t go travelling anywhere :)
    I estimate I’ll get up to 48 hours runtime but haven’t tried running it flat yet.
  4. IDK, about lugging it around anywhere. but there’s a few folks who live off the power grid that are interested in this kind of thing. Use a couple of solar panels and or a wind mill along with a charger and your all set. Don’t need the laptop to waste cpu time to do power monitoring. desktop pc use way more power then the laptops which is another reason why off griders use laptops.
  5. Am I the only one who noticed the strange wording in the description? It says he used a boost converter to get the 5 amps necessary. He used it to get the _voltage_ necessary at that current.. I know that’s what was meant, but the wording made it sound like he built a current-regulated supply.
    It is of course possible to have a current-regulated switching converter, but that’s not what is happening here :)
    Sorry for the nitpick!
  6. Just want to point out I’m doing a similar thing with my PSP atm. Scrounged an old SLA from a wheelchair and I have a luggage bag to carry it around in, best thing is I can also use a beagleboard with it if want.
Leave a Reply to ascendantCancel reply
