Custom Shortcuts From Firefox Address Bar
firefox_bookmark
We picked up a great Firefox bookmark tip from [Colin]. He wanted an easier way to look up bug numbers on the launchpad bug tracker. Because the url is always the same with the bug number at the end of the address, he replaced the final portion of the url with %s. Now, when he types the keyword followed by the bug number in the address bar the bug page loads right up.
We don’t do all that many bug searches but it’s immediately obvious that this can be useful in a lot of ways. In the photo above you can see we’ve set up a shortcut to the tag pages for hackaday.com. Now we just type “hack” with the tag we want after it. Add this to your bookmarks and try typing “hack firefox” into the address bar.
23 thoughts on “Custom Shortcuts From Firefox Address Bar
  1. Another use of that is the one i just set up, you just put in the link of a category and replace the part before “-hacks” with the %s and give the keyword “hack”. Then you can type ‘hack arduino’ to get to the arduino-hacks category.
  2. AFAIK if you type ‘google’ followed by a space and a query it takes you to the search results. It has maybe half a dozen shortcuts already in when you install it.
    I have my shortcuts set up to use single letters: g, i, n, d, w… Google, Google Images, Google News, tfd.com, Wikipedia…
  3. Yeah, this is a nice little thing to get used to using. I’ve got a shortcut for all my standard searches (g google, wp wikipedia, am amazon) plus a few for my bugzilla at work, dev server stuff, media server stuff… the list goes on. I’m an absolute minimalist for my firefox, TBH, so this trick was one I started to use when I wanted to find a way to eliminate my search bar… especially great for my netbook. I literally have nav buttons (because I’ve found that flash, annoyingly enough, oftentimes steals keyboard focus to the point that shortcuts for forward/backward don’t work), a force stop button (for similar situations), and my URL bar… they’re all on one line. That, plus URL tooltip (https://addons.mozilla.org/en-US/firefox/addon/12015) to eliminate the need for a status bar has drastically decreased the amount of screen real estate used by my windows (one UI line, plus a tab bar)… On 1440×900 displays, or 1920×1080, it may be a little overkill, sure :P. On the smaller netbook screens (MSI Wind), though, every vertical pixel counts. It’s good stuff.
  4. So what, you guys read the firfox documentation? Whats next, when you put bread in a toaster and then push down on the lever in 5 minutes you will have toast? WTF is this?
  5. This is also possible with IE6, which I used for a bit, with sites others posted. don’t know[care.] about IE7/8.
    It was a simple .reg I had laying around somewhere, probably found it from tweakUI or similar.
    [And no, I don’t use IE6 still [often…], but my poor firefox is so many extensions.]
    @mrasmus : does flash eat alt+left right, etc? please elaborate on your setup. I appreciate the URLtooltip advice. should have been in all browsers… status bar used to get JS thrown at it. wouldn’t a combo of some: adblock; removeitpermanently; greasemonkey; aardvark; help with reading more? or is the goal less scrolling? 1024×600 is too small for myself, I hated my laptop having 1280*800. [and any other irregular rez’s]. Unfortunately, ANY netbook would be a bit of a HW upgrade in my world…
    –PidGin128
Leave a Reply to EricCancel reply
