Last chance to enter The Hackaday Prize.
How to crack a Master lock
masterlock01
Long, long ago we covered a method to crack a Master lock in about 30 minutes or less. Here’s a revival of the same method but now the instructions to retrieve the combination are in info-graphic format created by [Mark Edward Campos].
If you didn’t get to try this the first time around, here’s how it works: A combination of a physical vulnerability, math, and brute force is used. First, the final number of the code can be obtained by pulling up on the latch while the dial is rotated. Because of the way the lock is built the correct number can be extrapolated using this trick. Secondly, a table of all possible first and second number combinations has been calculated for you.  Third, it’s your job to brute force the correct table of possibilities which includes only about one hundred combinations.
We’re not really into felony theft and hopefully you’re not either. But, we have a nasty habit of needing to use a combination lock that’s been in a drawer for a few years and having no idea of what the correct code might be.
Update: We’ve had a lot of comments about shimming as a better method. For your enjoyment we’ve embedded a video after the break that details how to shim a Master lock using a beer can. Just remember: friends don’t let friends drink and shim.
Comments
  1. monkeyslayer56 says:
    this could be usefull… both good and evil…
  2. Jesse says:
    haha, I used this trick just the other day. I work in a recreation center and we lend out locks. Each lock has a number written on the back in sharpie that corresponds to a table we keep telling us the combination. well the numbers wear off after a while and if nobody catches it, pretty soon you don’t know which is which!
    I don’t think there should be much worry about theft, as you can cut or shim a master lock MUCH faster than this.
  3. kyle says:
    aye you can shim this lock in seconds if you already have one cut. you do have a shim tucked behind your drivers licenses right?
  4. Jac says:
    If this were some kind of DRM scheme, you guys would already have someone ringing your doorbell with a Seize & Decist order. I wonder if you’ll get one for this, and if so, how long it will take.
    ===Jac
  5. calebkraft says:
    @jac,
    considering we posted the original story in 2005, I think we’re ok. no one has sued us yet.
  6. Yeah, you can cut it off faster… but this way not one is the wiser that you know the combo
  7. Mike Szczys says:
    Ha. If we did get a sieze and desist order I think it would be because people can use this to reclaim their lost combinations and don’t have to buy a new lock.
  8. Jesse says:
    @kyle: of course! several, made from red bull cola cans.
    @jac: This method is VERY old, just the graphic isn’t.
  9. pete says:
    I agree with the above, a shim is much faster and easier and can be made with commonly-available materials or brought along. I doubt anyone would attempt the brute-force cracking without carrying the list with them anyway.
  10. sl says:
    This method is from at least the 1940s, and maybe earlier. Richard Feynman talks about indpendently discovering (or maybe inventing) the technique while he was working at Los Alamos on the first atomic bomb. All the top secret cabinets were secured with locks that could be defeated this way.
  11. nope says:
    BOOOOOOOOOOOOOOOOOOOOOOOOOO! Beer/popcan hack 4tw. That is all.
  12. Simon E. says:
    There are errors in the number sets for step 3: To fix it, add 2 to the first number in row 2 of each block of numbers.
  13. Simon E. says:
    There are errors in the number sets for step 3: The first number in the second row of each of the four sets of numbers is wrong. Add 2 to each to fix it.
  14. rofl says:
    we used to use this and shims to play pranks on ppl at school. but my school forces us to use master locks with a key hole in the back for a master key. so we made our own key from tearing it apart and looking at the pin heights. took a while to get it right but it works on every school lock.
  15. Jon says:
    My main problem with this is that ….What if the lock is LOCKING something already???? haha…..I broke one of these open in high school when throwing it at a wall. Credit to whom ever did this though…..
  16. mike says:
    I think that someone should get a few hundred locks and find out why they stop at those half numbers, and how they are related to the combination. Also as a note, some locks only stop at 4 even numbers and the last digit is one of those. I used to open allot of locks in high school.
  17. markofcca says:
    So… I made this diagram. Can someone here contact me? The original can be found here: http://vdm3gd.files.wordpress.com/2009/09/masterlockredditt-01.png
    Can I at least get credit for the creation of the image?
  18. 3ldon says:
    @Jesse,
    It is a fairly common punishment in boot camp, 90 people times 2 locks each, = 180 combo locks all locked up in a big ball.
    Takes about 2 hours to get them all unlocked, and no; there are no beer cans to be had.
  19. markofcca says:
    Also, my website (the creator of the diagram) is http://www.markedwardcampos.com. I would appreciate it if the image linked there. Thank you.
  20. JD says:
    @markofcca
    Thanks for clarifying the 12.5 business — I really couldn’t tell what “between two digits” meant.
    But though I’ve never heard of any of this before, symmetry concerns lead me to reiterate Simon E’s point: it really feels like each of the second rows is has a number that is off by 2: 0->2, 1->3, 2->4, and 3->5. Maybe that’s wrong, but it fits the mod-4 pattern much better that way.
  21. mike says:
    Back in high school we just whacked them with a textbook until they opened. Shims and codes are overkill.
  22. 24601 says:
    everyone’s saying “it’s so much quicker to shim/cut the lock.” well, sure it is if you’re trying to break in to something. But what if you find an old lock in a drawer and want to use it? Shimming or cutting it won’t give you the combination to use it.
  23. dawningsun says:
    does the shimming work with key locks as well? Just wondering because my boyfriend’s ex took off with his key to his storage locker a couple of years ago when she moved out and he wants to get into it to see what she took (if anything) but we don’t want to cut it off, we’d rather find a way to open it and then replace the lock. It’s in an apartment with nosy neighbors so if one of them saw us trying to cut the lock off, they’d probably call the cops thinking we were planning on breaking into all of the storage lockers….
  24. Blunder says:
    Not quite 5 minutes…
  25. Blunder says:
    Doesn’t work for me.
  26. guamish says:
    404 anyone?
  27. octel says:
    @dawningsun:
    figure out the model of lock and post it here.
    If it’s a Master lock then it probably has weaknesses
  28. davey j says:
    i just grabbed one of my combo locks.. the correct combination isnt even listed in this file
  29. kohr says:
    30 Seconds? LOL.
    I’m a locksmith, and shimming a padlock is far more efficient.
    These posts in regards to locks are just ridiculous, and so newbieish. The last one I saw… decoding key cuts via pictures & software, how genius, LOL! Use a mico meter, and you’ll know the cuts before the software could even finish installing, geeze.
  30. speedblader03 says:
    @davey j: I have the same problem with one of my locks. Does anyone know why the combo isn’t there?
  31. bash says:
    I am sorry, but I remain unimpressed. Going to a high school ( I am now in college ) where every single locker had a master lock on it, it was only natural to figure out a way to crack them.
    My friend and I figured out a mathematical way to crack a lock in under 5 minutes, 2 if you got lucky. And this was the actual combination. Soda can shims are too unreliable, sure they work in a pinch, but unimpressive to say the least. Now what really made us proud was when we created the keys that went in the back of the locks. ( school issued, so of course there was a master key ) once we had all 3 keys made for the variations of the different locks. Only good was to come of it, after all, we did have a key to every single locker in the entire school.
    *sigh* good times…
  32. MrSomeone says:
    You can actually reduce the number of possible combinations to 64.
    http://joeshamah.com/projects/master-lock-calculator/
  33. mike says:
    @MrSomeone: thank you.
  34. Robot Woods says:
    There’s also a new iPhone App to crack Master Lock combinations: LockGenie, available at http://itunes.com/apps/lockgenie
  35. rf says:
    Kohr – I think you missed the point of the photo decodes/replication. Yes analyzing a key when you actually have it is done considerably faster by other methods. The photo replication is designed for hands-off, meaning you can just take a picture of a key from a distance, and come up with a working replica. Rather hard to do that with a micrometer.
  36. KI1313EY says:
    @Mr.Someone
    I tried that with a lock i know the combination to, and it didnt come up
  37. Min says:
    Does anyone know if it makes a difference if the master lock was school issued with a key hole in the back?
    I tried it on my lock from high school and it won’t work but I cracked my husbands old lock with that method.
  38. kimberly says:
    gthank you so muck for the steps and numbers the try on the combo. i would have never found my number because many site say to remove any numbers +\- 2 from your third number
  39. Jim says:
    Okay, So I went through steps one and two and got 38 for my last number. I’m a little confused because I vaguely remember the combination having an 11 in it which doesn’t seem possible according to this chart. Am I crazy?
    Also, I tried the beer shimmy and succeeded only in lodging a piece of aluminum in the lock.
    I’m currently going through the combination list, but something tells me that I’m going to have to use the bolt cutters for this one.
  40. alsin says:
    argggggggggg cant do it too hard!!!!
  41. Matt says:
    Ya but newer masterlocks are shim proof
  42. Brandi says:
    One thing I would like to point out is that the cheap Masterlock combination lock- what you most likely used in high school- comes off if you hit it just right in the right place. I’m in the army and when I was in AIT going through training at Ft Lee, we used to do that all the time to each others lockers just to screw with each other. I would just grab a combat boot and hit the top of the lock with the heel of the boot and it would just pop open and it never damaged the lock or affected the combination and it would shut like nothing happened. We never took anything, we actually left things- like a messed up note or a pack of cigarettes (smoking isn’t permitted and getting caught with a pack would loose all privileges- stuck in the barracks- and often meant extra duty like pulling guard overnight or cleaning the toilets, etc.) so imagine having a drill sergeant doing a locker check and you aren’t phased because you think you’re good and you go to open your locker and there’s a pack in plain site as soon as you open it. Best prank EVER! I switched to a key lock after my roomie left a note in my locker and then showed me how she did it. So the chick that kept ticking me off had to get revenge elsewhere. ;D
  43. NatureTM says:
    I made an Android app that uses this process, but saves the user from having to write down and mess with the numbers. You just tell it where the dial gets stuck. It’s called Lock Hero and it’s in the Android market. It’s not open source and costs $1.99, so sorry about that, but it’s rough being a college student!
  44. Tomas says:
    For some reason it’s not working for me.
    i did everything by what it says on this and that youtube that has over 1million hits. [(1)] (4) 7.5 10.5 (14) 17.5 20.5 (24) 27.5 30.5 (34) 37.5
    3 7 11 15 19 23 27 31 35 39
    did all the 100 combinations, but nothing.
  45. Jake says:
    @ MrSomeone That worked perfectly. Thanks so much.
  46. Jeremiah says:
    I know this thread is old, but I just thought I would post that I have found at least one lock this won’t work with. The code is 38-2-8. If you look at the graphic you will see that there is no way to get that combo if I get the last number of 8.
  47. Jeremiah says:
    Sorry to double post, but I didn’t see an edit button. I just wanted to say that after reading the post saying to add 2 to the first number in the second line that the combo 0-2-8 did work for me. Sorry about that. I don’t know that I will come up with a last digit of 8 using this method though, I still haven’t tried. I guess I’ll do that now.
  48. loki says:
    Theres no point in cracking the combonation on these locks. As shown by the diagram image, the latch mechanism is held in place by spring tention, making them vulnerable to bumping. All you have to do is give a good tap the U-bolt wile lightly pulling it.
    • CanThinkForMyself says:
      Umm yeah there’d be a point say if you wanted to actually USE THE LOCK!
      P.S…I have two locks, (which I believe have the same combo because they have the same serial #) and this method is bogus! There is no single “odd man out” number where the lock sticks, it is only between 6 different combos of whole numbers…not 5…I’ve tried every combo for both possible last numbers and nothing…
  49. Jennifer says:
    Thanks, worked like a charm. Saved me renting bolt cutters.
  50. Chapelhillkidd says:
    Worked on two locks within 30 minutes total. I just found the last number then punched it in the website listed above. Makes it easier, thanks for posting Mrsomeone
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 91,150 other followers
