Don’t Point That At Me
Some things are made to look steam punk but others are steam punk. This example of the later is a camera made mostly of brass. The body has been soldered together with only a shutter and lens being purchased for the project. There is a viewfinder and separate range finder to determine the proper focus for pictures as this is not a single lens reflex.
It should be obvious by now that this is a film camera. It relies on the photographer to turn the winder until an arrow on the knob lines up with a mark on the body for proper alignment. If you set out to make one of these, perhaps you should also manufacture your own film for it.
[via Dvice]
10 thoughts on “Don’t Point That At Me
