194 Transistor Clock Will Blow Your Mind
It’s nice to have tip put on our desks that we think everyone, yes everyone can enjoy. The Transistor Clock is just as its name implies, A clock that doesn’t rely on ICs. 194 Transistors, 400 resistors, 566 diodes, and 87 capacitors are all that makes this clock tick – no programing, and most importantly no Arduino. The clock is offered as a kit, but there is a complete parts list and manual (including debugging help) so anyone can build (and fix) their own. The Transistor Clock might even beat out the VFD Clock and the Word Clock on the ‘pure awesome’ scale, tell us your favorite in the comments.
[Thanks Hoopstar]
59 thoughts on “194 Transistor Clock Will Blow Your Mind
  1. @jeicrash
    Probably pretty accurate, since it uses your utility for the timebase (the AC frequency.) Of course that’s only so long as you don’t take it somewhere with a different frequency ;)
    @Peter
    A PCB that size in low quantities is not cheap. $100 doesn’t seem so crazy to me considering that.
  2. jeicrash:
    Following up on what Gene said, utilities periodically adjust their frequency to keep the average daily value at 60 (or 50) hertz.
    From wikipedia article “Utility Frequency”:
    “Over the course of a day, the average frequency is maintained at the nominal value within a few hundred parts per million.”
    This became common when electric (not electronic) clocks started using synchronous AC motors.
    Also, there is a 50hz mod on the website.
  3. I think a RC time constant clock is awesome. Unfortunately I didn’t have enough money to complete mine. :(
    With that many resistors, capacitors, and diodes they could do a little better presentation on the board. It looks too clean. Maybe make a symbol or something made out of the components.
    Sweet project!
  4. @Pidgeon500
    You, Sir, should be shot… though one has to admit, that would be a very fun project, and produce a huge amount of heat. Would make for a cool table lamp, too. Perhaps use nixie tubes for the outputs… Hrmm… I’m getting that itch…
  5. Seems overkill to me if you wanted to build a clock without ICs, the simplest thing to do would be to use the mains AC. If you want to do battery, then a motor plus either quartz or RC oscillator…
  6. KITT could synthesize this in less than 2 seconds, given the proper ingredients, except i don’t remember ever hearing kitt ask for atomized toner cartridges, but if you want to build a proper KITT, thats the part you start with, the atomic printer /”Molecular Synthesizer” interfaced with the supercomputer because then KITT can build itself from that (the KITT starter-kit). now Pidgeon are you talking more ‘mercury powered valve clock’ -or a pneumatic valve clock.. nuclear powered steam-valved conduit ?
    lol what i mean is what is subbing in for electrons. at, a scale like, steam-liquid water or atomic like H or Hg.
    what if the valves are powered by solenoids.. that thing would be so noisy and inefficient. it already has valves, in its current state, and attempts steampunk it as i believe pidgeon500 is hinting at, would be best carried out with nukulur-enerjii
    it took me am hour to write this confusingly stuupid c0mment
  7. actually you can build your own microsolenoid type things.. but then its so fragile using wires and magnets to make resonator kinda thing. oscillator is the word for it, what it does when i wrap a magnet in a coil of wire and feed it juice. if you could completely macgyver-hack it, handcrafting every component with formulas, wire lengths, coils, cores of different compositions.. substitute every microcomponent into a macro-electromechanical, or electromagnetic like building transformers and solenoids.. then once your mind is set to work with magnetic circuits, thats when you discover the flux capacitor. (of course you first conceived the idea when you banged your head on the sink because you fell off the toilet while attempting to hang the clock on the wall)
    Superconductors.
  8. My experience with line-referenced clocks is that short-term accuracy is not so hot (within a few seconds a day) but long-term accuracy is very good. They always eventually come back to correct time, unlike a quartz clock which will keep gradually diverging.
  9. @The Steven, Yeah, I thought of making a clock like this from relays about 3 years ago until I started drawing the schematic and realized my skill at the time wasn’t that good. Then I just priced the relays from digikey. That stopped me dead in my tracks.
  10. Put a high voltage power supply on there, swap out the 7 segment LEDs for Numitron tubes (basically 7 segment incandescent display tubes), and no screen printing or green solder mask would make this thing an instant buy. As it is, this thing is absolutely amazing already, but a few tweaks could send it over the edge.
  11. Don’t get me wrong, I think this is a beautiful hack (another quality Hackaday article, w00t!), but this whole thing is not something I’d build.
    I’d much rather design it than build it. And .. as a kit, its quite ‘meh’, to be honest. Not enough blinking lights, sound, and so on. Where is the little birdy? Alarm clock version!? Time-Zones?!!
    You get the point. Still, very, very cute project.
  12. @Peter
    The kit price looks reasonable to me. The PC board is huge and the kit comes with over 1k components!
    I think what’s more remarkable is the amount of time it would take to assemble and troubleshoot it.
Leave a Reply to TheDudeFromMiamiViceCancel reply
