All About VLF Radio
If you’re interested in learning about Very Low Frequency communications take a look at what Larry has to offer on his site. He’s put together a guide to VLF receivers that is short enough to read and clear enough to understand with rudimentary knowledge of circuits. He builds a simple receiver as a working example and a high-powered transmitter that can put out over 2600 watts. Let’s face it, radio operators were the original electronic hackers. Get back to our roots and learn the ways of the transistor.
[Thanks Buddy]
20 thoughts on “All About VLF Radio
  1. Very cool stuff. I was looking for links to listen. There used to be a NASA site that lets you listen live to a VLF receiver. You can hear lightning happening anywhere on the globe, along with other earth related phenomenon. I think the sounds are called “tweaks and spherics” – youtube search seems to confirm this. very interesting!
  2. “Get back to our roots and learn the ways of the transistor.”
    Or you could grow a pair and stop considering beginner projects hacks and give attention to quality projects.
  3. I just got my technician license for HAM radio, so I’m not the savviest person in the hobby; however, I do believe transmitting over 1500W is against FCC standards just to let anyone out there know that this device you build may piss some people off.
  4. LOVING the radio stuff on here lately.
    Every once in a while you read a story about some ham, (usually out west where there’s still some elbow room)that went to the trouble to string a quarter-wave radiator or some other kind of cool VLF array.
    Great stuff HAD.
    Radio isn’t dead, it’s just gone so mainstream that you don’t notice it’s in your pocket.
  5. @Noxilenticus: Unless I’m mistaken, the VLF band doesn’t fall within the regulations of your amateur license. According to Wikipedia:
    “The frequency range below 9 kHz is not allocated by the International Telecommunication Union and may be used in some nations license-free.”
    Fill your boots.
  6. @Alchemyguy
    No need to be rude, you can’t blame the guy for not knowing everything.
    It still is 2600 Watts.
    although quite unreliable for anything else than listening to storms, it still is a nice analog project!
    1. Can you confirm this that VLF Radio Receivers below 1 KHz range can listen to human conversations and can be used as spying devices to spy on neighbours. In particular, 80 Hz to 280 Hz range can be used to listen to neighbours as eavesdropping device. And it can even listen to whispers and heartbeat.
Leave a Reply to captainCancel reply
