Hackaday Links: April 28, 2010
Cell phone chopper control
Control your tiny inexpensive helicopter with a Nokia N900. The chopper uses an infrared remote control, just like a television. Getting this to work was just a matter of figuring out the IR commands and writing an app for the phone to spit them out.
Fade to black; inconspicuously
Lost interest in your TV-B-Gone? Give it one last whirl by throwing it inside of an old iPod case. The dock connector hole is just about the right size for the LEDs and the kit fits nicely in the old 3G type iPods. With this kind of disguise it should be a lot harder to spot who’s messing with those TVs.
Surf your way to a cleaner house
This guy uses a roomba to clean his floors. The Wii balance board lets him lean forward and back to surf the little bot around the room. This seems a little more exciting than the exercise programs the board was originally designed for. [Thanks DXR]
G1 gamepad
[Tobias Weber] built a gamepad for the G1 Android phone. He used an old Atari control, cut out two buttons and the d-pad, and glued them in a housing to fit the G1 keyboard. Each presses a button on the phone’s keyboard which can be mapped through the emulator software.
Social power monitoring
Here you see a very small portion of the power meter installed in a Cafe at UC Berkeley. It shows the energy usage for the building, separated into categories such as lights, power outlets, and coffee machines. This lets students know how much juice they’re draining by plugging in their gadgets. The color bar uses 93 ShiftBrite modules controlled by an Arduino.
12 thoughts on “Hackaday Links: April 28, 2010
  1. Does the Roomba really play those sounds while it vacuums? That could get annoying very quickly.
    Otherwise a great bunch of mods. I have a Moto Droid and I still drool over the N900s
  2. FYI: We were working on the gamepad concept a while ago in DIY form on xda-developers. Never fixed the sliding issue. Ended up just adding enamel to certain buttons to raise them, works better than any add-on now.
  3. Love the button gamepad hack :) I did something similar this past weekend to my wifes ipaq as the buttons were recessed for travel. Yours looks much better and has inspired me to just go ahead and make something that covers the whole butt of the thing :)
  4. (@Gamepad)
    Hi
    first of all I’m really sorry for the crappy recording. Seems that theres a need to switch to a different driver (ps3 cam should do more frames).
    If I find some time in the next days I will prepare more detailled Information on how to build this.
    And a printable keyboard layout which is absolutely neccessary while arranging the buttons.
    But you cann also start building one yourself if you have old Gamepads lying around. I dont know if it was just a lucky accident that this worked so great with the atari gamepad. Need to order a bunch of gamepads on ebay.
    @wakeupkeo
    Now I have found your posting on xda-dev
    I didn’t when I build this although I searched the whole (;)) Web for similar projects. I came up with the idea of casting some silicone rubber parts to the gamepad so it can be easy attached or removed from the G1.
Leave a Reply to wakeupkeoCancel reply
