Distributed Flight Array
Though it is in the beginning stages of development, the Distributed Flight Array is already looking very interesting. Each unit can scuttle across the ground using the down force from its prop, but when 4 or more join forces, they can take off and fly. The documentation shows that they should be smart enough to fly in random configurations, though in the video we only see the standard 4 prop layout. This is being worked on by the same people who produced the balancing cube.
[via BoingBoing]
Comments
  1. monkeyslayer56 says:
    great next they’ll learn to think on their own and then they will try to be our robotic overlords… other then that its cool :)
  2. salec says:
    Exactly why is the sum of lifts greater when they are connected? Or perhaps it isn’t but they lack control unless there is at least four of them, so they decide to just hover low?
  3. polymath says:
    Adds a whole new element to the swarm concept. It will be interesting to see the commercial, military, and research applications this provides. NASA is working on something similar for their solar plane project. Don’t know if they’ve tried out the mid air docking bit just yet.
  4. salec says:
    I should had read the TFA before posting…
  5. crgwbr says:
    @salec I think its probably a matter of control/stability. With only one unit, the torque reaction of the prop would cause uncontrollable spinning. Two units would solve that problem, but it would only have direction control of the X and Z axis. Three units would theoretically work, but four would make the math simpler.
  6. Hirudinea says:
    Why didn’t see the doubles joining into four, that I wanted to see.
  7. aonomus says:
    @crgwbr
    The torque component is negated out on coaxial helicopters all the time by using counter rotating blades. This also allows for rotation by simply slowing down one of the props to allow the torque to become a non-zero value. That still doesn’t solve lateral movement control along the X-Y axis though.
  8. RP says:
    This seems pretty preliminary to me. The rolling-docking version is not at all like the flying version (no prop and the circuit boards are located over the duct) and the flying version seems to be uncontrolled and only capable of seeking the ceiling.
    I look forward to a controlled version that can dock-undock and demonstrate controlled purpose.
  9. zerth says:
    I’m amused that the handler only cared about protecting his right hand.
  10. Remarknl says:
    when the four are connected the pcb’s are placed on the side instead of on top… so they actualy can not join in and fly away…
  11. maroc says:
    I would like to see a dozen or so of these things to join and create a huge hovering platform, think sky captain and the world of tomorrow. http://www.rotaryaction.com/images/skycapwot.jpg
  12. MS3FGX says:
    Yeah I noticed that too, the flying hardware is completely different then the version they showed docking, and flight looks to be completely uncontrolled at this point.
  13. NatureTM says:
    So it has a bunch of problems, but they all seem like things a bunch of money could fix. I’m thinking defense.
    I don’t know, but right away I thought this could have some big military purposes. It could be a fast way to distribute ad-hoc network nodes. Or, a single unit initially with multiple capabilities could later separate and then more efficiently allocate its assets… Sortof a distributable multi-role aircraft.
    I don’t know, maybe I’ve just watched too much sci-fi.
  14. Amos says:
    Similar to maroc, I want to see swarms of these working together, except I don’t think they need to connect to each other (except wirelessly). It would be cool if this became a cheap device that could be bought in quantity, attached all over some heavy thing–wherever a connection could be made, and all told to carry it somewhere. The right software could even compensate for the inevitable differences in lifting strength caused by mass-production and differing battery charge levels.
    Of course, each unit would probably have to be able to at least fly vertically on its own, perhaps with the dual, counter-rotating blades that aonomus mentioned.
  15. Sam says:
    Hey guys let’s pick the shortest guy on the team to be the one to have to reach up and grab it.
  16. Freddie says:
    While you’re looking at ETH Zurich, check out their work with quadrotors. They learn. And they will take over the world.
  17. scott says:
    how s this even a hack where can i find details on how to make this?
    i cant find any plans
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
