Nixie Sudoku: A Look At The Hardware
We’re always happy to receive a tour of the guts that make things work. [John Sarik] posted several pictures and descriptions of the hardware that makes up his Nixie Sudoku build. The modular design uses professionally made circuit boards which greatly improve the durability of a large set of circuits such as this.
The design draws on good ideas from similar hardware. The Nixie Duo kit from Ogi Lumen allows tubes to be mounted on top of driver boards with cascading shift registers for control of up to 8 tubes. The ArduiNIX shield makes the high voltages needed for Nixies easy to control with an Arduino. No, [John] didn’t just order these kits and plug them into each other. He designed his own boards to suit his needs. Each driver board can control 9 tubes in a 3×3 grid, all on one PCB. His high voltage board can supply enough juice for the whole system which is tied together with a single Arduino board.
His writeup is quite interesting so do take a look. He also filmed a walk through video which we’ve embedded after the break. It clears up some questions, such as showing the use of a blinking decimal point to indicate the current cursor position.
[youtube=http://www.youtube.com/watch?v=YoixTdJzMoE]
8 thoughts on “Nixie Sudoku: A Look At The Hardware
  1. >>His high voltage board can supply enough juice for the whole system which is tied together with a single Arduino board.<<
    I think he uses 1 driver board (including a high voltage power supply) per 9 tubes, not a single supply for all 81.
    -Ferdinand
Leave a Reply to EquinoXeCancel reply
