Air freshener hacking
In an effort to improve his marital standing [Tech B] hacked an air freshener to make it Internet controllable. The main component here is a Glade Sense and Spray. It cost him $7 and is meant to spray out some sweet smells when it senses motion in the room. The unit also has a manual spray button which he patched into with the help of a relay. From there some Arduino code and an IRC bot take over, letting him unleash freshness from anywhere he has IRC access.
When reading about this we were also thinking: “motion sensing circuitry available at local stores for just $7?”. We may have to conduct an investigation into the alternative usefulness of that package.
If you have another brand of automatic freshener around it should be just as easy to hack as this one was.
Comments
  1. Aaron says:
    “Improve his marital standing”? What, does he fart a lot?
  2. t&p says:
    $7
  3. Maximillian says:
    I was just thinking that you could hack this with a fart detector in the couch….
  4. none says:
    “freshening” air by adding perfume is like “cleaning” stuff by only adding detergent.
  5. Nick says:
    $7? That’s awesome!
    I can see some camera adaptation in the near future…
    Every time someone walks by, snaps a pic…
  6. amishx64 says:
    Hmm motion sensing for $7!
    Anyone know the range? I assume this is a PIR (passive infrared), right?
    I think it’d make for some good home security as well…
  7. MS3FGX says:
    Motion sensing is exceptionally simple, you just need to watch the resistance in a pair of photocells for large enough changes, indicating something has past by and disturbed the light level of the area. Putting them behind a fresnel lens will increase sensitivity.
    So basically two CdS cells connected to the analog inputs on a micro will give you motion sensing in your project. So $7 hardly seems like something to be excited about.
    Though pulling the board out and getting it to trigger something else on it’s own might be handy for something very simple and quick.
  8. tikka says:
    I absolutely HATE those airfreshners
  9. StinkyPete says:
    So all this because “the house stinks when my wife gets home.” Maybe you should figure out why your house stinks in the first place, rather than covering up the odor with nasty chemicals that will coat everything in your house, your lungs, etc?
    For example, open up all the windows and air out the house completely, then close up all the windows and room doors, and see which rooms stink? Maybe you’ve got dead rats in the walls or some food fell into a hidden spot? Maybe you just need to take the trash out more / compost garbage in the back yard / buy a garbage disposal? Maybe the carpets need cleaning?
    Sigh.
  10. kernelcode says:
    I’m with MS3FGX, pretty sure these just use photoresistors which I really wouldn’t want to pay $7 for!
  11. matthew says:
    this doesent use PIR, i wish it did, its simple a CdS cell that detects dramatic changes in light, thats all
  12. James says:
    As above, motion sensing via PIRs and photodiodes etc has been about since the 70s, for buttons? I had a PIR kit that cost pocket-money back in the early 80s?
  13. Haku says:
    If the air freshener only uses photoresistors then $7 is a bit expensive if that’s all you want from the device, you can get 4 small PIR sensors from Chinese eBay sellers for $15 including postage.
    In testing I’ve found they can sense you moving two room lengths away easily, and their power usage is extremely low too; 40uA when running and 60uA when triggered. Only drawback is the postage time of about a week or so.
  14. Anonymous says:
    Cheap motion detectors sound like fun.
    The question is, why would you want to freshen a room you’re miles away from?
  15. ILeftTheBody says:
    @Anonymous to hide the smell of the body while you get far enough away so they cant catch you.
  16. Brennan says:
    Random question: What kind of light/motion sensors are used in the industrial automatic-flush toilets?
  17. firestorm_v1 says:
    Parallax’s PIR sensor (true IR) is $9.95 at radio shack last I checked.
    @Brennan
    Most devices that I’ve taken apart usually consist of an IR emitter and receiver combination. Kinda like an interrupter except the IR transmitter and receiver are both pointed the same direction instead of at each other. When the receiver detects a sufficient amount of IR, it triggers and whatever microcontroller triggers the desired function. The handsfree paper towel machines are less complex and uses a photocell and detect brief changed in light. If the reading’s the same across several readings, it does nothing to prevent killing the batts when someone turns the bathroom light off.
  18. Harvie.CZ says:
    what about filling it with laughing or tear gas? ;-)
  19. DLC says:
    I prefer the $9.99 motion sensor from Radio Shack, I have opened one of those and it works, but still prefer the Radio Shack one.
  20. Per Jensen says:
    Glade, a good way to obtain perfume allergy – when i visit my dad’s house, i always turn these thingies off, to his annoyance – but i really dislike all that chemical smell, eww!
  21. jh says:
    I just put an exhaust on the cat box using a PIR sensor tied to a time delay relay (ELK-960) to drive a fan for 30 minutes after the cat drops a load. works great. It did cost more than $7 though. wife loves it and cares nothing about the aesthetics.
    You can figure out how to build it just from looking at it. It’s real simple.
    check out the finished product if you want (myspace warning)
    http://blogs.myspace.com/index.cfm?fuseaction=blog.view&friendId=126778581&blogId=532460821
  22. Joel says:
    why wont my comments go through
  23. mr ugly says:
  24. medwardl says:
    I have a more devious purpose for this build. Add in an irc controlled lock and you have a perfume smelling irc controlled torture chamber. *^_^*
  25. erebus says:
    I used a motion sensor night light wired to a usb kb controller on the print screen key to wake a pc up.
    Cool.
  26. Tech B. says:
    @StinkyPete
    The house doesn’t stink per say. Its a very old building. We live in an apartment and that musky smell has been here since we moved in.
    I wasn’t after the motion sensing, I was after making the house smell good from an IRC channel. It was to learn.
    Nothing to do with farts lol. But that did give me an idea….
  27. vcarte says:
    Hey, I’m TechB’s wife. I feel like my housekeeping has been insulted. I clean my heart out in this place. i believe that a lot of what “clean” is, is how it smells. So i am paranoid that my apartment stinks and that if anyone shows up they will think that. There honestly may not even be a smell, besides, if it gave TechB something to hack….why not?
  28. Anonymous says:
    Seriously – hacking is always fun, but a smell in an apartment needs to be addressed in a different way.
    Do these:
    1) Wash (washable) surfaces with a microfiber cloth and household vinegar solution. That (unpleasant) smell will dissipate in a couple of days, but has the potential to transform many smelling compounds into non-smelling ones, and the microfiber picks up the gunk.
    2) Rent a good ozone generator and treat each one of your rooms.
    If these two do not help, you really need to consider moving out before your lungs are full of spores. I have talked to people who lived in rotting houses and their stories are not something you want to experience.
    An unpleasant smell usually signals you shouldn’t be inhaling that. Masking that with something else does not change the fact you shouldn’t be inhaling it. Actually, air fresheners may also contain stuff you do not want to inhale, such as phtalates and polycyclic musks.
  29. RBRat3 says:
    You could sell that ~” IRC Unleash The Freshness “~ God that would be great for a client ad.
  30. M H says:
    Air “fresheners” contain many compounds that are toxins, carcinogens, etc. Best not to be breathing them (or depositing them in your living environment).
    http://www.sciencedaily.com/releases/2006/05/060524123900.htm
    http://www.arb.ca.gov/research/abstracts/01-336.htm
    http://www.sciencedaily.com/releases/2008/07/080723134438.htm
    http://en.wikipedia.org/wiki/Air_freshener#Toxicity
    @Tech B. –
    If you have musty odor in building, important to find out why, and try to deal with the source. It could indicate mold, which can be a health hazard also.
    http://www.doh.wa.gov/ehp/ts/IAQ/got_mold.html
    http://www.epa.gov/mold/moldguide.html
    (Not as hacky, but more healthy.)
  31. IronJungle says:
    Here is my simple air freshener hack:
    http://www.youtube.com/watch?v=NAJKLZh136Y
  32. FrodoB says:
    Here:
    http://cid-4c7ec0c2176a0b0d.photos.live.com/browse.aspx/Environmental%20electronics
    is a Air Wick hack. I’ve seen these for $4.99 at discount stores (Ollies).
  33. jacky says:
    I made a puppet out of wood, with arms on pivots at the shoulder joint.No legs. I took out the canister. Fixed a small hook into the hole in the mechanism which moves downwards when motion detected. Put the puppet in place and joined the top of the arms together with strong cotton. hooked the mechanism on. When motion is detected, the hook moved downwards and the arms raise up. Had lots of cardboard try-outs to get the best lever mechanism – the attachment point had to be as near the pivot point as possible. had fun anyway!
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
