[Alexy Sha] has done this fantastic hack, where he modified a magnetic floating globe to be motorized and spin on a tilted axis. The original globe was simply levitating via a magnet mounted inside. Though you could spin it by hand, it wasn’t motorized, and actually floated completely vertically instead of being tilted.
[Alexy] wanted to take this idea further and make it automatically spin on a rotated axes. He built a rotation assembly that was basically a motor, hung off-center, attached at the center of the globe. He had to power it via a coil hidden in the base unit, so that it could remain light enough to float. He did a fantastic job and the final product seems like it is the true way it should have been sold.
Check out a video of it in action after the break. We actually like the spinning ring, when he’s testing it, just as much as the final spinning globe.
Subscribe for weekly videos
Awesome.
that is awesome
To me it looks like he just took the off the shelf globe that was already floating and rotating and shifted all the bits inside the globe to make it tilted. Its not clear why he would have to tune the induction coil, unless adjusting the tilt meant it needed to be re-calibrated. I don’t think he “made” any of it. Just adjusted.
that is a great project and a great conversation piece. my hat is off to you. what a great job.
Love it!
Now to only add the moon to the Earth and orbit them both around a sun! :)
@frozenlazer
I was under impression that the original implementation used magnets to turn the globe, without any motor.
So I took it as, he added the inductive power, and motor. However, if you are indeed right, then I feel rather ripped off, and violated.
@frozenlazer
And on that note, I recall when watching this that there was, what looked like a ton of hot glue holding the “wheel” in place on the globe. That alone would suggest he installed the motor.
From what I understand, the original had no motor. I could be wrong, but from the diagrams in the writeup, it shows without a motor on the original.
The original was simply suspended and could rotate if it was spun by a hand. He added the motor and the tilt.
This is really cool. I would have expected the motor to also rotate in the opposite direction but I guess the magnetic field keeping it suspended also introduces something like drag or resistance?
Upon close inspection, I think I stand corrected. I was thrown off by how well that “equator” ring fit on to his motor assembly.
So is it the magnetic field that holds onto the floating base and prevents it from rotating in the opposite direction? I was wondering why the base didn’t go one way while the globe went the other way like a helicopter without a tail rotor.
Of course he added the motor!
When you rotate the globe in the vertical axis you don’t need it, because the distance to a point in the globe is always the same, you can do that by a simple magnet inside the globe.
But, if you want a tilted axis, where the height changes with the angle, you can’t do that in the same way… that’s why he needed to add a much complex mechanism.
The globe rotates because of the conservation of angular momentum. The motor inside rotates one way, and the ‘frictionless’ globe will rotate the OTHER way, because angular momentum has to be conserved.
The globe rotates slower than the spinning motor rod because the globe is far heavier. The magnets beneath don’t resist the rotation at all.
This is a _very_ clever hack.
THIS. IS. AWESOME.
I never thought I would actually see someone pull this off- the same thing has bothered me for years!
I MUST BUILD ONE!!! A very BIG one.
If you notice at about 2:00, he fixed the rotation from backwards to correct. :)
Awesome, no other words :)
What a beautiful job. I’ve wanted to do just that for a few months now and am very impressed by how well Alexy got it to work.
One of the best projects ive seen on hackaday in a long time
Absolutely brilliant!
That is very very good. excellent work to get that operational.
What speeds could this thing reach?
Wow, that is quite impressive and the project seems easy enough to duplicate.
I really like the inductive coupling power supply. What a novel idea to have on a base with power already applied.
What would be even more awesome is some light inside the globe that light up on “the dark side”.
Sweet.
Need one for my office. Can I buy one?
Wow! Pretty up the base a bit and I bet Brookstone would sell a bazillion of these!
build it into an end table and tell everyone you’re a wizard! this is so cool!!
I have nothing to add, other than this project/hack is awesome!
Marvelous !
Questions: how stable is the floating globe on the base? Will the globe remain stable over the base if the base is moved in a smooth uniform motion?
I envision this earth revolving around a larger, floating sun (moon optional). For added effect, place the moving bases beneath a uniform black surface.
ok, but now it looks like it’s always summer
I was grinning from ear to ear when I watched the video.
Bravo!
This STINKS OF WIN!!!
The instant I saw this I started thinking how cool it would be to have it rotate once a day with a bright light source illuminating one side. Then I was trying to come up with a way to add a moon that slowly orbited. Then I was picturing how one might have the whole thing move around a scale sun and how this might be elegantly incorporated into the architecture, perhaps a large circular room with a counter around the perimeter. Then I realized I was daydreaming.
If you guys want to add a sun and moon, and keep things to scale, I hope you have a large living room… :)
I’d like to make myself believe that planet Earth turns slowly…
It’s like win with an extra side of more win.
Beautiful BEAUTIFUL work!
This is the kind of thing you patent.
i was imaging something much more complicated and wondering how he could pull it off. then i watched the video. angled floating internal motor powered by inductive coupling FTW! that is awesome. you could recreate the entire solar system on a big enough table, bases moving on tracks underneath, and put it in a museum. but i would just like to have it built into a desk. doesn’t have to be the earth.. power some LEDs via the inductive coupling as well, people would buy that shit up. you sir, are a genius :D
you could have a floating model of a helicopter with blades spinning. or just build a fake perpetual motion/ antigravity machine, powered by induction and fuck with people like its alien tech
I’d really like to see a light added to this that represents the sun. And then control the motor so it’s in tune with the Earth’s rotation. So one could tell what areas of Earth where in sun and what parts weren’t. Mostly just because it would be awesome! I’d be tempted to buy something like this hack if it was made. The other globes just don’t seem as cool to me.
A. Brilliant!
B. Motor turns too fast
C. That globe is ugly and should be replaced.
D. I would probably just hover the “guts”, possibly modded to look (more?) like a space station (Empok Nor FTW!)
FTW would be the Deathstar.
Okay at least we can all agree that it’s no moon…
Amazing. Could more powerful magnets be used to suspend it further from the base station? It would be pretty cool to have it floating in the center of a room with nothing nearby.
http://www.amazon.com/Fascinations-LEVG21-Levitron-Anti-Gravity-Globe/dp/B000X22JEA
chris27: You could, but the inverse-square law is not your friend. The base also needs to be proportionately wider to center it.
I love it!
It looks like the heavier globe is closer to the base. Is there even room for the shiney domed cover? Speaking of that, it is likely the cover (metal surface on plastic) will interefere with the induction field.
” I need more power!”
I think the globe may be upside down. Isn’t the magnetic north of the globe supposed to be pointing up?
i like the idea of a solar system of these things.. but screw moving bases, use a 2D magnet array to move them around, varying their height along the way. First step, giant 2d maglev floor.
So I guess no one else is thinking that this is how that plasma turrets from Halo work? More Proof that we are the Forerunners.
But he doesnt say the main thing:
How do you attach the power supply or the electric system to the magnetic base to keep it energized. That is the main secret. So you need to buy the Globe first and then apply the hack, but you cannot build one from scratch.
Erik: If you want the globe to rotate in time with the Earth the solution is even simpler than this – instead of a motor and inductive pickup simply attach the hour hand of a clock mechanism to the tilted equitorial ring. Of course you will need a 24hour clock, not a regular 12hour clock – or replace the 32KHz crystal in the 12Hr clock with a 16KHz crystal. :)
