RFID Entry Uses Homemade Electronic Strike
[Fileark] built an RFID entry system that uses a pretty ingenious alternative to an electronic strike plate. An electronic strike is a rather expensive hinged plate that mounts in the door frame and catches the door latch. But this system opens a set of double doors. The door without the handle is fixed in place and has a normal strike plate. But it also has a deadbolt mounted in line with that plate. When the deadbolt is extended it is flush with the strike plate, pushing the latch from the door knob back and freeing the door to swing open. This is a bit hard to put into words so watch the video after the break to clear things up.
The system uses a cheap RFID package that provides a single signal line. This line connects to an old VCR motor which turns the deadbolt. Timing is provided by a 555 chip, and the deadbolt movement is limited by a couple of switches mounted along with the motor.
Now that the unlocking mechanism has been built it would be simple to use other authentication methods for unlocking the door, like a wristwatch-based proximity system.
[youtube=http://www.youtube.com/watch?v=hpOeuOM0NBo]
22 thoughts on “RFID Entry Uses Homemade Electronic Strike
  1. I like it but he has actually made the lock less secure. to enable the dead bolt to push out the latch he had to notch out the strike plate which makes it so anyone with a credit card can slide it in and unlock it.
  2. Last month I got locked out from my house. But, I could access my garage via an electronic keypad.
    So, I grabbed my Sawzall and a couple diamond blades.
    So, you know those “cut proof” dead bolts with the floating high carbon steel insert? It lasted about 2 minutes under the mighty wrath of the Sawzall.
    Point being, they have battery powered sawzalls.
  3. I was looking for a suitable lock for a project like this a while back. This is an excelent solution- there is nothing like this lock availiable for sale that I’ve been able to find. (there are some keypad/deadbolt combinations, but no standalone locks)
    The benefit to this design is that it only requires power when it changes state. Electronic strikes and any other type of electric lock (again, that I’ve been able to find) all either require power to stay locked (fail safe) or power to stay unlocked (fail secure).
  4. Have done this on 2 doors, works well. I actually extended the handle through the motor assembly so that you can lock/unlock it manually from the inside as well. Works good, and is a hell of a lot easier than hacking up the door frame and installing an electronic striker plate!
  5. Uhm this kinda looks like a ghetto haxx. You could kick that door in easily why putting locks on it.
    I even lost the last rfid key for building thats how much I care about the security.
    He shouldve implant that rfid tag into his penis.
  6. Well I found a few things from this $10 RFID kit… First its a MOD (in itself a hack of the original) from a CAR immobilizer (thats the reason for the 12V). Also the MOD’s are more for use, it’s no longer connected to a car computer (if you open it, the Yellow is connected to 2 pins, one of which is a special data pin that when used in it’s intended purpose it will send a unique serial data stream depending on which known fob was used). Also the unmarked IC is a UM3758-120AM encoded/decoder chip. The reason for the removed pins from the chip, it appears to prevent re-encoding the master chip and to control the output to instead of a unique serial stream now just an on/off stream.
    Also found another mod for this device: http://home.btconnect.com/QTEKNOLOGY/rfid/RFID_new.htm
Leave a Reply to osgeldCancel reply
