Wii sensor bar projector
Having experienced quite a bit of trouble getting the Nintendo Wii remotes to work reliably with his home theater projector, [Sprite_TM] designed his own sensor bar replacement. If you’re not familiar, the Wii remotes have an infrared camera in the tip that sense two IR LEDs in the sensor bar that resides above or below your television. The problem is that if you’re too far away, the points of light are not where the remote expects them to be and the cursor will not perform as expected. Since this is a huge projected display it’s no surprise that the player is further away from the screen than the system was designed for.
[Sprite_TM's] solution was to build a projection system for the two IR points. The unit in the picture above is a driver circuit with two IR emitters mounted on a heat sink, each with its own reflector. The reflected beams are shined through a Fresnel lens and projected on the same wall as the TV image. The viewer will not be able to see this light as it’s in a longer wavelength than the visible spectrum. But the Wii remote performs beautifully now and the replacement sensor bar is happily mounted out of sight above the projector.
Comments
  1. je5us says:
    i hear you can also use candles, it’s quicker and sets a nice ambience
  2. biozz says:
    what cant this guy do?
    seriously XD
    @je5us anything that emits inferred … remote controls candles lighters ir lasers any of that
  3. Edward says:
    Brilliant idea!
  4. Andy says:
    Cool idea to project the dots… I would just be interested in how well they are focused… I guess you could use the Wii config screen’s view of the wiimote sensor to focus/position the beams.
    Re: alternate IR sources, I have a CFL in my range hood, with the bulb having direct line-of-sight to my rear projection TV… when the bulb is on, the faint reflection on my screen confuses my wiimotes! Pretty annoying.
  5. VIPER! says:
    Very impressed. I could build this If i could GET the parts. Where do you find the lenses and reflectors that all fit together like that and focus properly for your IR LEDs.
    When I build my projector mod my light source had to be aligned just right for the projection to be focused correctly.
    http://www.instructables.com/id/Head-Light-Projector-Mod-V1.2/
  6. Gil says:
    absolute genius
  7. M4CGYV3R says:
    I always thought there were 4 IR LEDs in the sensor bar. I never really looked, but I know the WiiMote is designed to track up to 4 points…
  8. Spork says:
    @M4CGYV3R
    There are 10 IR leds in the sensor bar.
  9. DanAdamKOF says:
    This is a great hack, I love Sprite’s writeups, and moreso, his ingenuity.
  10. LifeSizeActionFigure says:
    Nice project, and clever thinking! Congrats.
  11. NatureTM says:
    I think he’s going to give me a “TM” name suffix inferiority complex.
  12. biozz says:
    @Spork
    i count 6 on mine (using my IR modified DSLR)
  13. _Matt says:
    There should be around 6, 3 for each side pointing in 3 different directions to make sure there’s 2 dots at any angle.
    Also, those lenses he used are really cheap on dealextreme.
  14. Glen says:
    The only reason for multiple LEDS in Wii bars is to compensate for how directional they are.
    A way to overcome this if you make your own with just two is to rough the surface of the LED up with emery paper to diffuse the light coming out of it so it can be seen from any angle (it can reduce the range though)
    This idea of projecting the dots also overcomes the directionality problem
    Very clever
  15. cgmark says:
    How well do the normal IR remotes work when the room is flooded with IR for the wii, are they modulating the signal any ? I know you can jam another remote by generating an IR signal in the room at 38-40Khz from a single IR diode.
  16. Sprite_tm says:
    cgmark: It’s a constant light, so it’ll get filtered out by the highpass-filters in the receiver. I didn’t have any trouble using the remote for my beamer when the lights were on.
  17. Nintendo should make this… seriously.
    I sold my launch day Wii years ago because it was such garbage to play on a projector.
    I did try to shoot a couple of LEDs at the screen but it didn’t work out, apparently the lens is the trick.
  18. strider_mt2k says:
    “…there…are…FOUR…LIGHTS!”
    Sorry.
  19. Mitch says:
    Why not use infrared lasers? Powered by the wii’s sensor output cable and directed on the wall/screen. There would be no need to lenses and focusing and all that etc etc.
    I have been pondering this for some years now but have never got a difinitive answer on what wavelength diode to purchase… And dont know if I can simply power the diodes from the sensor bar cable… And I am also lazy…
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
