[Rob] just finished reinforcing a cheap drill motor. He picked up the tool at Harbor Freight and ditched the case. The plastic retaining ring was replaced with a thick metal washer which he machine The washer uses three bolts to attach to the mounting plate that he welded together. We’re not exactly sure what he’s got in mind as he only mentioned that this will be used with a robot. We wouldn’t mind having one of these as a bench motor but there must be hundreds of uses now that it can be attached to just about anything. It seems Harbor Freight has become popular as hacking’s raw material source. The last example we saw of this was a welding table made from a utility cart.
18 thoughts on “Beefing Up A Cheap Drill Motor”
Leave a Reply to PhilipCancel reply
Come See the new hackerspace this was made at. Newly opened Makeit Labs at 111 tanner st Lowell MA. there will be open houses on thurs from 7pm on. Come down see some projects or work on some of your own.
So… it looks like this post is about a bracket bracket used to mount a motor. I’d say ‘hack-worthy’ because more mechanical knowledge is always great (I’m a mech eng student), but I can hear the arduino/LED crowd whining already…
Harbor Freight FTW. Been shopping there for years. If you have one in your area you should check it out, it’s a hacker tools paradise. . .
My suggestion is to waterproof it and mount it in the kitchen sink, put a brush head adapter on it and have an automatic dish/skillet scrubber.
i got some wireless headphones from harbor freight for 6 bucks lol. they only play in mono but theres a built in FM radio too and a MIC you can plug in to have a wired headset for skype or whatever. thats some raw hacking material 4ya
Why my comment didn’t got posted?
okay, it’s a hack, but he made a bracket. is that really post worthy? :/
hackaday editors need to proofread before posting
Hey- these 18v motors aren’t bad, I took apart a HF portable circular saw and it uses the same motor.
You would want to remove the gearing for a (light duty) CNC spindle but this mount is a great idea.
does not work well…
either the speed controlers start burning, and after you build better ones, the motors will.
i tried that, but i might have used batteries that were to heavy.
http://sites.google.com/site/philipdoering/goliath
Harbor Freight really is a great source of cheap components and gadgets. When you are buying things just to take them apart or repurpose them, it makes sense to go with a cheap supplier.
Between Harbor Freight and online resellers like DealExtreme, there are a lot of interesting things you can pick up at very low prices.
The chuck comes off pretty easy too if you want to replace it with a pulley or something. Open the jaws as wide as they’ll go and there’s a LH thread crosshead screw right down inside. After removing it, give the chuck a whack and off it comes to reveal a keyed shaft.
The torque limiter ring is part of the gearbox though unfortunately, so it can’t be removed.
Ok on the subject of hackworthyness:
1.This bracket looks to be hand fabricated.
2. The plastic retainer piece was custom fabricated to eliminate weakness.
3. Ive personally seen the bracket today, the reason for the chuck is because the 10 inch wheels have a hole saw welded to them which directally chuck right up
they’ve been giving away LED flashlights for months too. now i think they’re switching to free multipurpose scissors.
He should give the bracket a lick of (auto)paint.
I work at HF and some of the stuff we sell there gives me too many ideas some days for ptojects its hard to work xD
This type of this has been done by robot combat builders for years. We need them to not fall apart after getting hit.
“Beefing up” is not the correct -It’s still a cheap, non-durable drill motor. “Motor mounting bracket” might be more accurate?
