GameBoy Advance Rapid Fire Hack
Ever find yourself in the middle of a Game Boy game and your hand cramps up?  Save that sore wrist for something else because now you can hack the Game Boy Advance to add Rapid Fire for the B button.  [William] has developed a way to do this by creating a simple circuit that generates a square wave on the B button when it is pressed.  To do this hack all that was needed was a short shopping list of:
  • A Couple NAND Gate ICs
  • 2n2222 NPN Transistor
  • 0.1uF ceramic capacitor
  • A Switch
  • 1M ohm resistor
  • Some Thin Wire
After that you’re off to the races as [William] documents how he goes about transforming the Game Boy Advance and includes a ton of great pictures and a schematic.  This operation ends with [William] placing the switch for Rapid Fire excellence next to the Right Bumper where it is inconspicuous and yet easy enough to access.
Via [HackedGadgets]
Comments
  1. unaB says:
    YIKES! That is the gobbiest ugly solder mess Ive seen in a while. Maybe this is better suited for “kludge-a-day”?
  2. Daniel says:
    seems like “glued” not soldered ;)
    but nice idea also
  3. Fallen says:
    Agreed. Those solder joints need work.
    “Save that sore wrist for something else” I lolled.
  4. nave.notnilc says:
    always nice to see more freeform solder jobs :P
  5. Lars says:
    Good to see some very simple electronics hacks from time to time!
  6. johannesburgel says:
    “A couple NAND ICs”? I only see one.
  7. Jorge says:
    second one is buried under the solder.
    ZING!
  8. nes says:
    There was a similar thread on rec.games.vectrex just recently. Here’s a circuit with just two transistors which might work on the GBA with some tweaks to the values: http://groups.google.com/group/rec.games.vectrex/msg/806a33aa9557a19a?dmode=source
  9. Gdogg says:
    @johannesburgel He uses a single IC with 3 NAND gates
  10. Haku says:
    I remember taking the small autofire circuit from a joystick and putting it in my Amiga mouse, with an on/off switch, so I could have autofire on Star Wars.
    Ahh those were the days…
  11. cde says:
    A better way would be a small micro controller, have it monitor the backlight button. If it senses a button pressed while holding the backlight button down, it triggers auto-fire on that button. Same method for turning it off. Should only take the same number of parts and maybe a 3/4 extra wires.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 91,380 other followers
