Single-motor walker for Santa-Pede Challenge inspiration
This LEGO hexapod uses just one motor for motion. In the video after the break you can see that what [Valetnin Bauer] accomplished is almost magical, using just 210 parts. A central drive shaft uses worm gears to transfer motion to each of the legs. The limb mounting technique results in a sort of rowing motion that closely mimics what you’d expect to see from a biological hexapod.
We thought this might provide some inspiration for the Buy Break Build: Santa-pede challenge. Sure, using LEGO is a lot easier than reusing Santa parts. But a lot can be accomplished with a little creativity. Another point of inspiration might be this one-motor walker that should be a snap to adapt to the challenge. Better get going, just twenty days let until the project deadline!
[via Tinkernology]
Comments
  1. fluidic says:
    Yes, using gears to distribute and redirect motion from a single mechanical source is magical.
    Or at least, it was when the ancient Greeks were playing with them.
  2. hoditohod says:
    Amazing!!!
  3. Ned says:
    I love it. Now to find a way to make it turn :)
  4. roboman2444 says:
    Ned: he could just use 2 motors, one for each side of legs. The timing might get a tad bit off… but it would work anyway.
  5. Gilliam says:
    @roboman2444 and Ned
    http://www.zoid.us/deathstinger.htm
    this ZOIDS model does the dual motor thing, with a wired remote control add-on.
  6. Jack Sprat says:
    Perhaps if he could drop it into reverse he could use that to switch some gears around and allow it to turn still using one motor.
  7. This is what i like to call an “elegant design”, well done!
    If you were to use a universal joint to separate the 3 leg pairs, you could put in a servo to bend the whole body. This would allow it to turn because the walking force vectors would no longer be in a straight line. This method would also keep the drive as one motor with a consistent drive offset.
    I made something like that 10 years ago with 4 legs, and a LOT more hot glue.
    http://www.ctrobots.org/pics/2000/jan00ke2.jpg
  8. Jon King says:
    @fluidic
    You are what is wrong with hackaday.
  9. kristian says:
    @Kevin: I will get those instructions and try that!
    this is brilliant; it really is elegant.
  10. strider_mt2k says:
    I agree with fluidic.
    If it was done before by someone else it can’t possibly be magical or deserve to be revisited for any reason.
    Luddite.
    Being a douche predates civilization itself, so don’t bother doing it. -it’s been done.
  11. levsha128 says:
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,441 other followers
