Hackaday links: November 28, 2010
The Clock Clock
This digital display is made from several analog clocks with thick hands. Together they make something of a 7-segment display, which can be used to display the time. It reminds us of the “Shared Time” installation we covered previously. [Thanks Drum365 via Anonimiss Files]
Quickly desolder lots of parts
[Rhys Goodwin] is grabbing parts from junk PCBs but he’s not using a rework station. Instead it’s a hot-air gun and a brisk tap on the bench to send the parts flying. Well, at least he’s not using a blow-torch like [Ben Heck] does.
Binary Hero
This bank of 8 toggle switches is the controller for Binary Hero, a geeky take on Guitar Hero. When you see a decimal number come down the screen set your toggle to the binary equivalent in time or the game will be over before you know it. [Thanks Fabien]
Quick fan POV
[GMG] took a small persistence of vision board and slapped onto an oscillating fan blade. Along with a couple of magnets on the safety cage this display is a persistence of vision hack you can pull off in an hour or two.
Speed up laser etching
[James] figured out a way to cut down on the time it takes to etch multiple copies of one item with a laser cutter. It doesn’t run the laser faster, but orients the pieces in a way that means less movement of the head while the laser is not on. Read through his article and see if this method can help you out when doing some CNC work.
Comments
  1. nes says:
    Depopulating a board using hot air is good so long as there isn’t too much on it. I’ve done it with old PSUs and CRT monitors where the components are relatively big and can be sorted easily afterwards.
    For computer boards, it’s not really worth it IMHO apart from maybe saving the connectors and low ESR caps. Everything else is not generic enough to be useful.
    If you need a specific IC for a project for example, it’s usually so much better to just hack off the section of PCB with it still soldered in situ as you then gain the properly designed power supply decoupling and any support components will be still attached. I like salvaging the high current servo op-amps and brushless motor controllers out of CD-ROM drives this way.
  2. fluidic says:
    If you read it, the guy at the end with the laser etch isn’t etching anything but the green bit. He didn’t “figure out a way” to do anything more than follow the instructions. I’m confused as to why that keeps getting reposted around.
  3. macona says:
    I have not had much luck with using hot air for mass component salvage. I found and repaired and old solder fountain. I can remove even the heaviest components at an amazing speed. Of course it only works for through hole components.
    http://www.flickr.com/photos/67292116@N00/5215452162/
  4. Daniel Reetz says:
    That etching information is outlined in the manual that comes with all Epilog lasers. Not saying it’s not useful, and glad to see it online, but if he’s working with an Epilog, reading the manual would have got him as far as that.
    Lasers have lots of hidden problems/tricks like that, it’s nice to see them becoming general knowledge.
  5. macona says:
    Looks like its a chinese machine. The manual that comes with those is pathetic at best. Its a lot of figure things out as you go.
  6. blue carbuncle says:
    Neat howto on board depopulation. I had to give up most of it last year after they changed my medication. I now have the hands of a 60yo alchoholic lol.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 93,941 other followers
