Will This Mouse Get Me Kicked Out Of The Coffee Shop?
This [Dwight Shrute]-esque project will let you try out your taxidermy skills. Apparently you can acquire a ‘wetware’ mouse fresh or frozen from pet stores. We just need to wait until fall when our pantry is visited by the less-domesticated variety.
A travel-sized optical mouse acts as the replacement guts. Some creative dremeling brings the plastic housing down to a more acceptable shape. The furry bits need to be processed using the mouse taxidermy guide before they are fit over the electronics. What you end up with is a creepy peripheral that nobody wants to use.
One Minute Review Of Your Wasted Time
[youtube=http://www.youtube.com/watch?v=GuvR98k5KBU]
It’s easy to throw around the accusation that you waste time throughout the day. Now you can prove it by reviewing everything you did on your computer, all in just one minute. [Dan Paluska] ground out some code to take screenshots and assemble them into a video.
His script ties together the open source tools FFmpeg, ImageMagick, and scrot. It takes a snap every 15 seconds in a 10 hour period for a total of 2400 frames. He even outlines the process to automatically upload these clips to YouTube. Just remember, if you’re doing something naughty, there’ll be a record of it.
Add A Clean Room To Your Workshop
I Heart Robotics has posted a guide for building your own clean room. They’ve been clever with their materials, starting with heavy-duty shelving to provide the framework. We like that idea, it allows you to position your workspace at whatever height you desire.
The side walls are MDF painted with white enamel. Light, power, and tools are mounted to these walls. To keep things clean, a ventilation system uses a vacuum filter and 12V fans to keep filtered air moving in and dirty air out.
Maybe now we’ll be able to pull off that window hack without killing our hard drive.
[Thanks Mawitö and Ciric]
LEGO Sequencer Builds Sound In 3D
[Yoshi Akai] built a sequencer that is part steampunk, part injection molded plastic. The LEGO sequencer MR II has eight steps in a loop that is manipulated by adding the colorful blocks to a green base plate. Each color corresponds to one particular sound which can be modified by building skyward. On the other side of things he’s added a beautifully crafted control area for knobs and switches. We didn’t see much info about what is inside the device so, watch the clip after the break and then feel free to start the speculation in the comments.
This is a similar concept to the coin sequencer. From the picture above it seems the blocks have been altered and perhaps use light to identify the different blocks.
Continue reading “LEGO Sequencer Builds Sound In 3D”
Tube Clock Database
[youtube=http://www.youtube.com/watch?v=75Yl9hyPFRE]
[Brian] wrote in to show us a site he’s been working on for a while. He’s been building a tube clock database. We didn’t realize there was actually a big enough draw for such a site, but we have to admit that we spent more than a few minutes browsing through the different clocks. There isn’t a ton of data for each clock, but there are links to individual project pages wherever available. There is also a growing amount of information on the different components themselves, so submit any data you have that he’s missing to help flesh it out.
The video above wasn’t chosen for any reason other than it is quite stylish.
