DIY Ultrasonic Range Finder For $5
After finding some ultrasonic transducers online for a dollar each [Kerry Wong] decided to create an ultrasonic range finder. The result is much like parallax’s PING))) sensor but much cheaper. His post is not only a good way to save some money, but also does a good job of explaining how ultrasonic sensors work.  The transmit circuit is essentially an H-bridge, much like what you would use to control a motor. To listen to the returning echo he uses a pair of high gain/low noise op-amps to filter and amplify the signal.  The board he uses to test the range finder (not included in the cost) is an ATMega328 running the Arduino boot loader.  He also provides lots of example code to boot.
25 thoughts on “DIY Ultrasonic Range Finder For $5
  1. Sweet, hopefully it’ll help me once the page recovers from the DDoS :P I tried creating something similar a while back but gave up. Circuits like these seem more like voodoo than science *sigh*
  2. @golddigger
    camera and a laser pointer on a stick. If you know the length of the stick and the angle of the laser pointer compared to the camera, it is just trig.
    Smaller it is, the less accurate or more expensive it gets.
  3. Thanks for your reply! I have been through the google searches and I have seen the people doing work with webcams. But I was hoping for something less conpicious. The trig method with a cell phone camera and an eye safe laser pointer would be ideal, but I wouldn’t know where to begin. If anyone could point me in the right direction, it would be appreciated.
  4. I like seeing an embedded arduino like this. I’ve built arduinos before and they work great. $6 can easily replace a $40 basicstamp or $30 arduino board.
    very nice build
    I’m building a Geocache GPS that I’ll be able to load coordinates into and track them down. Its like a reverse reverse geocache lol. It will have a standalone arduino like this.
  5. Site is back up as of right now for anyone interested.
    @adam
    I hate trying to incorporate a whole arduino board into a project. Its a waste of money and connectors. The only 2 cases I can think of would be a very temporary project (arduino controlled xmas lights) or a dedicated shield to bootload other AVRs.
  6. golddigger, zing-
    A lot of cheap laser pointers can project designs like a smiley face or a star instead of just a dot. Measure the distance between star points or the eyes on the face.
  7. How similar is this technique to the ultrasound used in baby scans? Could this be used as a Diy scanner or would there be risks? 3mm precision sounds very promising and a fascinating project, good work.
  8. yeah, i have considered that, and i think i’m going to. i would sell a version with smaller transducers, 10mm in diameter. and i would love to use an smd microcontroller, but i couldn’t find them here.
    i’ve made these because the parallax ones are too hard to get, and they cost like 65 dollars each.
  9. i am using a pic12f675, it sends the 40khz burst, and waits for the response from the RX amplifier, the ADC was too slow, so i am using an internal comparator and an internal voltage reference module to get the response.
    i didn’t publish the code mainly because it is used for a sumo robot competition, and i want to use them there. and i would be the first one with homemade ultrasonic sensors there. if i release the code and the schematics i lose my advantage in the competition.
    i am also selling them.
    anyway, it’s not that hard to do it. and you have to calibrate the detection voltages versus time for the comparator, and that varies with the construction and sensor sensitivity, so even if i publish the code, it will be probably useless.
Leave a Reply to NavicCancel reply
