Building A Better Spectrum Analyzer For Radio Enthusiasts
This spectrum analyzer project seeks to improve the quality of tools available to amateur radio operators. A lot of thought has gone into the design, and those details are shared in the verbose project log. The case was originally a CATV link transmitter, but most of the controls seen above have been added for this build, with unused holes filled and finished to achieve the clean look.
One noteworthy part of the build is the time that went into building a rather complicated-looking 1013.3 MHz cavity bandpass filter. Despite the effort, the filter didn’t work. Details are a bit sketchy but it seems that some additional tuning brought it within spec to complete that portion of the device.
This certainly makes other toy spectrum analyzers look like… toys.
[Thanks William]
12 thoughts on “Building A Better Spectrum Analyzer For Radio Enthusiasts
  1. @Rob Wentworth
    Well played. Though, good luck making measurements with it :)
    Also, I know something about the 1013 Mhz cavity filter (I’m working on my own build of the “Scotty Spectrum analyzer” http://alternet.us.com/?page_id=751 )
    The plumbing pipe cavity filter he built probably didn’t work because the “hairpin couplers” between cavities look like they’re too far away from the sides. They’re really only supposed to be about half the width of the insulators away. He had an aluminum cavity filter machined from the designs of another spectrum analyzer, which did work. It looks like it shouldn’t be too much trouble to make it at home if you have a drill press, though.
  2. Very nice build, and quite educational!
    A bit off-topic: does anyone know what’s the software used for drawing block diagrams for RF? Something like the one in this project or like the numerous ones in ARRL or datasheets.
  3. Ah yes, the GBPPR, quite an interesting site to rummage around at. There are loads of other interesting projects and ideas there. If you’ve never gone to the site, you could spend hours reading various pages. Just one fyi, just ignore the pages/part of pages that are political :( .
  4. Hey – if you guys are interested I have built an spectrum analyser using an Arduino and Pi to an OLED display for audio. Check this out! And get in touch bearaudio.blog/2017/09/08/mvista-predac-spectrum-analyser/
Leave a Reply to d_Cancel reply
