Flash trigger with programmable delay
Here’s a flash trigger with a programmable delay. These triggers are often used to capture quick events like a balloon popping. The technique takes place in a dark room with the shutter open. When the event is triggered the flash illuminates the scene and an image is captured. Because these require precise timing it has typically been a chore to synchronize the event, hence solutions like using a pressure plate.
This build, which centers around a PICAXE 08M, allows the photographer to use any trigger they desire, but adds a delay. The box above shows the apparatus set up for a 42 millisecond delay. So if you’re using the sound of the balloon pop as a trigger, you can hold the flash off until the event really gets going.
[Thanks Two Part Epoxy]
Comments
  1. Sounds like a perfect project for a 555, except without the digital feedback of time. Although, you probably will have to do a trial and error method anyways to get the best shot… with digital photographs you can throw away all of the missed shots without worry, although that’s a lot of balloon inflating :)
  2. Oren Beck says:
    42 is the answer.
    I used to service Microfilm cameras- 3M 2300/ 2800 and laser plotter to Microfilm output – 3m 2900 that needed timing delays incredibly sloppier intolerance parameters. R/C delays that fired a SCR or switched a transistor to open and close relays with large domed- “file service” possible- contacts. The Hack we began introducing as parts for the 2300 became scarce was using plug in “delay modules” that varied from Glass tube “Thermals” to a knob pot adjust to single second DIP switch setting models. And- they’re still made as a module to make some other Hack painless to make happen. No, that kind of module would never do a 42 millisecond anything except perhaps 42 milliseconds of contact bounce. This is an excellent hack and I wish we’d had it in 1997. And- if you want to get delay modules for places where a factory made is good enough- check out the relays etc from Amperite. Because sometimes Hacking from scratch like this 42 millisecond delay gets more appreciated when we compare it to commercial stuff.
    http://products.amperite.com
  3. biozz says:
    my HAD was linked! :D
    yeah i use a camera axe now … does the same thing but it has its flaws
  4. Brett says:
    Normally you don’t want any delay when you are photographing balloons popping. The burst happens in less than a millisecond so you need to instantly trigger the flash.
    A delay circuit is typically used for photographing water/milk drops.
    Fightcube is right, a 555 circuit is a perfect fit for something like this:
    http://www.instructables.com/id/Laser-Triggered-High-Speed-Photography/
  5. biozz says:
    @Brett
    no you need some delay when photographing poping of balloons generally of 1MS to 2MS
    at least thats what i do
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,369 other followers
