Papydoo spends most of its time sleeping, but if startled by vibration it will wake up and stare you down with a cold and unnerving robo-gaze like you have not seen before. Or it might just do something crazy like display a scrolling Space Invaders character marquee. That’s the thing with Papydoo, you just never know.
Vibration sensing is accomplished with a piezo element harvested from an old horn speaker that is simply sandwiched between the project enclosure and the surface it is sitting on. A MCP601 op-amp is used to amplify the weak potentials from the piezo element and feed them to the ADC of a Zilog Z8F083A microcontroller. When sufficient vibration is detected, the MCU wakes up and displays one of a number of different animations on the front panel 32X8 LED matrix. The various display modes can also be manually selected using a small button on the back of the enclosure.
Power consumption is reduced to 150uA while sleeping by only briefly waking the MCU once per second to check the current vibration level. Nearly all of this power draw can be attributed to the op-amp, and although there are much more efficient models available, sometimes the best choice is just the one you already have on hand in your parts bin. Regardless, the power consumption is low enough to run the device off of a set of AA batteries.
We could imagine that similar setup could be used for a number of different low-powered messaging applications that would only “wake up” when someone was near enough to read and interact with. Add a loud speaker and this might even make a good alarm to keep pesky coworkers out of your “cube”. What would you do with a Papydoo?
Thanks for the tip [Laurence]! If you happen to read this, we are dying to know: why “Papydoo”?
Short video after the break.
Subscribe for weekly videos
Would make a great addition to Halloween decorations.
Greetings Hack-a-day,
I’m the creator of this project.
About the name, well, I’m from a mostly French speaking part of Canada. In French, “dad” is “papa”, and “daddy” is “papy”. I have 3 young daughters, and they often ask “What is Papy doing?” when I play with electronics in my shop. So I guess it became “Papy does [this]…” to “Papydoo”. It was a kind of a funny word that has stuck around in the house, while I was doing this project.
Nice job! Looks very clean and professional, and the shifty eyes look very mischievous =)
Maybe add some filter glass so it isn’t too obvious that the box contains an LED matrix and electronics
I would think the filter would blend the pixels on some of the other animations (space invaders). That would (in my opinion) detract from the aesthetic of those graphics.
Regarding the eye animations, I like the reflected version on the table with the flat portion at the top. Much more ominous “why are you messing with me” vibe.
