Cheap and reliable portable face recognition system
faceaccess_portable_facial_recognition
For their senior ECE 4760 project, engineering students [Brian Harding and Cat Jubinski] put together a pretty impressive portable face recognition system called FaceAccess. The system relies on the eigenface method to help distinguish one user from another, a process that the pair carried out using MatLab.
They say that the system only needs to be hooked up to a computer once, during the training period. It is during this period that faces are scanned and processed in MatLab to create the eigenface set, which is then uploaded to the scanner.
Once programmed, the scanner operates independently of the computer, powered by its own ATmega644 micro controller. Users enroll their face by pressing one button on the system, storing their identity as a combination of eigenfaces in the onboard flash chip. Once an individual has been enrolled, a second button can be pressed to gain access to whatever resources the face recognition system is protecting.
The students say that their system is accurate 88% of the time, with zero false positives – that’s pretty impressive considering the system’s portability and cost.
Stick around to see a quick demo video of their FaceAccess system in action.
Comments
  1. bty says:
    nice, .. but holding up a picture of the person will likely also work.
  2. M4CGYV3R says:
    LOL! bty is so right.
  3. M4CGYV3R says:
    Do it with a kinect so you get stereo/depth data as well.
  4. Ken says:
    I believe bty may be right, and I’d love to see a follow up video where they try that. Some additional checks though could clear that up (but at a cost, of course). Maybe combine with a kinect and look to make sure the face is multidimensional, ir to check for tolerable heat, eventually you’re making it for real and not just a school project.
  5. french t0ast says:
    @M4CGYV3R
    What do you mean by stereo? I don’t know much about the kinect
  6. zool says:
    yeah they should see if holding up a picture works
    or twins, or just how close you have to resemble someone to do it
    for example i think mark zuckerberg could open that guy in the grey shirt’s account XD
  7. Haku says:
    bty, my thoughts exactly, especially as kids in Japan discovered this with vending machines that could be fooled with magazine photos to buy cigarettes: http://pinktentacle.com/2008/06/magazine-photos-fool-age-verification-cameras/
  8. Hirudinea says:
    Could be fun to use this approch for log in security on a laptop with a webcam.
  9. Hickhackerz says:
    Toshiba and HP already have Face Recognition software for login. Tohisha requires both left and right angle face shot for perpective. Then when you try a picture, and it wants the side shots, it won’t detect.
    We tried it out without side shots and it would not allow a photoID or a full page print to work.
  10. pRoFlT says:
    @Hickhackerz, what if you had two photos? one for each perspective?
  11. Jack says:
    I’d like to see this used in an augmented reality system. I walk up to someone and it tells me who it is and a bunch of stuff about them from previous encounters.
  12. Brennan says:
    @pRoFIT
    I think you just described the future role of the “hacker” guy in heist movies.
  13. Spork says:
    I’m curious if could use something like a PIR sensor to fix the possible photograph issue?
    Identical twins would probably work, but otherwise I don’t think two ‘alike’ people would pass as each other, the vectors are pretty good.
    Great work though. Showing off things like this will breed lots of other ideas (see comments!)
  14. M4CGYV3R says:
    @t0ast: I was under the impression the Kinect had two cameras to present a stereo image(two eyes == depth perception). I don’t own one, so there’s a possibility I’m wrong.
  15. GameboyRMH says:
    @Jack: Google Goggles actually does this in reverse. If you show it a person’s contact info it will show you their face and social networking info. Only a matter of time until it does facial recognition I figure…
  16. Squirrel says:
    @M4CGYV3R
    Kinect doesn’t use stereo. It uses pattern projection. Basically it has three openings: IR Pattern Transmitter, IR Camera, Color Camera. The IR Transmitter/Camera are processed to generate a 3D depth map. The 3D depth map and the color image are sent along the USB connection to the XBOX/Computer. All of the processing to assign the armature to the person is taken care of by the XBOX. I don’t believe that any of the drivers for computers have that functionality. …yet
    tl;dr: not stereo, pattern projection
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 93,771 other followers
