Tesla coil bullet-time photography
One thing we can all probably agree on is that Tesla coils are one part high-voltage electricity and two parts pure awesome. [Rob Flickenger] thinks so too, and he built a pretty nice one in his workshop some time ago. He took a bunch of pictures showing off the coil’s capabilities, but he thought that one photo taken from a single angle didn’t do much to relay just how fantastic it is to watch a Tesla coil in action.
Taking a cue from the Matrix movies, he bought a stack of Canon point and shoot cameras and constructed a bullet time rig in his workshop. In order to get the pictures just right, he flashed each camera with a customized version of the CHDK firmware that allowed him to trigger all ten shutters with a single button press. A few scripts help facilitate collecting all of the images for processing, after which he identifies the good shots and stitches them together. You can see the awesome results in the video below.
[via LaughingSquid]
[vimeo http://vimeo.com/24977187 w=470]
20 thoughts on “Tesla coil bullet-time photography
  1. Not to nit pick but this isn’t bullet time. It is a multi-view time freeze. Bullet time would be where they fired the cameras very close, but independently to each other, so each frame was different.
    Sorry. Matrix fan and terminology purist. Still cool. Wonder how more wicked it would be if we could pool and get some more cameras and ring the whole tesla.
  2. From the description, I was expecting a complete circle of cameras to catch the action from all the way around like they used in the Matrix movies, but this is also quite good. Definitely the best and most interesting tesla coil photography I’ve seen.
  3. Hal, not to burst your bubble, but there are many definitions of what can be called “bullet time”. Warner Bros. trademarked the term but did not define an actual process, which happened to exist in one form or another far before the Matrix ever hit the screen.
    In fact, some definitions describe bullet time in this manner:
    “The bullet time effect was originally achieved photographically by a set of still cameras surrounding the subject. The cameras are fired sequentially, or all at the same time, depending on the desired effect.”
    Source: Wikipedia
    Not to say Wikipedia is the be all end all definition, but a terse interpretation such as the one you state fails to acknowledge other accepted examples of the technology as well as those which helped inspire the derivation used in the Matrix.
    Sorry. Reading fan and comment purist.
  4. Did a similar camera trigger a few years back. Instead of modifying the cameras we used 3 IR blasters to trigger 24 JVC cameras at the same time. 95% of the time they all captured the same frame. Our biggest issue was camera alignment, we had cheap swivel mounts that wouldn’t stay locked in place. You can see some of the results here – including the poor camera alignment.
  5. @jpslater, you do realize that the CHDK ‘modification’ is/can be a software/firmware patch that will revert back to stock whenever the camera is powered off? Hence, there was no visible or irreversible modification done.
  6. Looking at the rotating images generated by the ‘bullet time’ rig, it looks like doing something like this might be the optimal way to generate 3d models of the electrical activity of tesla coils (among other things, like 3d printing copies of film holograms)
  7. I too would like to see even more cameras used, for a full or near full ring effect. Also some true bullet time shots where the cameras are fired in sequence (and probably placed very close together) for some moving arc shots would be amazing!
  8. @birdmun I didn’t mean to imply that the firmware approach to triggering the cameras was a bad thing, just that it was also possible to do it using cameras right out of the box as well.
  9. This is very interesting.
    The first thing that comes to mind is synchronisation of cameras taking the photo. The time taken to send the signal to all cameras for the picture should be the same. These arcs occur for very short duration of time, so there may be some lag between.
    One thing I would love to see is influencing the air around the arcs. This would create different conductive paths. A simple test would be to put a lit cigarette near the arcs. Different chemicals would make different arcs, and lets not forget the excitation of different chemicals would create different colours.
    Just don’t use mercury fumes :P
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
