One-click unbrick for Samsung phones
[Adam Outler] has been pretty heavy into mobile device hacking lately. The biggest problem with that field is recovering from back flashes or development firmware glitches. In many cases you can use a JTAG programmer to reflash stock firmware to resurrect a handset. Unfortunately you’ll be hard pressed to find a phone that comes with a JTAG header, and soldering to the microelectronic boards is not for the faint of heart.
But a solution is here, [Adam] pulled together a wide set of resources to create a package to unbrick Samsung phones. Now we’re sure that there’s more than a handful of people who would argue that a bad firmware flash that can be fixed this way means that the phone wasn’t actually “bricked” in the first place. But what we see is one more barrier torn down between being a hardware user and becoming a hardware hacker. You’re much more likely to get in there and get your hands dirty if you know that you’ll be able to undo your mistakes and reclaim you precious pocket hardware. See just how easy it is in the video after the break.
Comments
  1. j0z0r says:
    I think it’s crap that you can turn any high end consumer electronic into worthless plastic with a few ones and zeroes… I mean, where’s the virus killer app that just bricks the planet?
  2. james says:
    thx
  3. Jonathan Wilson says:
    Reminds me of when I modified a dbus config file and caused my Nokia N900 linux phone to refuse to boot properly. Was up till about 3am booting various kernels (using the flasher tool option to load a kernel into the phone and boot it) and other things until I finally got something on the phone that could mount the root filesystem so I could copy off anything important. Then I was able to reflash the kernel/rootfs and my phone worked again.
    Try doing THAT with anything from Samsung :P
  4. Eric in Milpitas says:
    Very cool. Looks like a nice alternative to Odin.
    That said. If download mode works you’re not bricked.
  5. Adam Outler says:
    @Jonathan Wilson That’s the kind of stuff I do for fun in my spare time on my Samsung device.
    SBL> eraseall units
    bbm_erase_all: step 1. Start unit=1, End unit=2.
    bbm_erase_all: step 1. Start unit=52, End unit=2004.
    bbm eraseall success.
    SBL> reboot
    command_loop: parse command error! (reboot)
    SBL> reset
    Rebooting...
    SB1
       Samsung Primitive Bootloader (PBL) v3.0
       Copyright (C) Samsung Electronics Co., Ltd. 2006-2010
    +n1stVPN       2688
    +nPgsPerBlk    64
    +n1stVPN       3008
    +nPgsPerBlk    64
    PBL found bootable SBL: Partition(4).
    Set cpu clk. from 400MHz to 800MHz.
    OM=0x9, device=OnenandMux(Audi)
    IROM e-fused - Non Secure Boot Version.
       Samsung Secondary Bootloader (SBL) v3.0
       Board Name: ARIES REV 03
       Build On: Jun  8 2011 21:44:47
    Re_partition: magic code(0x0)
    [PAM:   ] ++FSR_PAM_Init
    [PAM:   ]   OneNAND physical base address       : 0xb0000000
    [PAM:   ]   OneNAND virtual  base address       : 0xb0000000
    [PAM:   ]   OneNAND nMID=0xec : nDID=0x50
    [PAM:   ] --FSR_PAM_Init
    fsr_bml_load_partition: pi->nNumOfPartEntry = 12
    partitions loading success
    board partition information update.. source: 0x0
    .Done.
    read 1 units.
    ==== PARTITION INFORMATION ====
     ID         : *unknown id* (0x0)
     ATTR       : RO SLC (0x1002)
     FIRST_UNIT : 0
     NO_UNITS   : 1
     ID         : *unknown id* (0x1)
     FIRST_UNIT : 1
     NO_UNITS   : 1
     ID         : *unknown id* (0x14)
     ATTR       : RW STL SLC (0x1101)
     FIRST_UNIT : 2
     NO_UNITS   : 40
     ID         : *unknown id* (0x3)
     FIRST_UNIT : 42
     NO_UNITS   : 5
     ID         : *unknown id* (0x4)
     FIRST_UNIT : 47
     NO_UNITS   : 5
     ID         : *unknown id* (0x15)
     FIRST_UNIT : 52
     NO_UNITS   : 20
     ID         : *unknown id* (0x6)
     FIRST_UNIT : 72
     NO_UNITS   : 30
     ID         : *unknown id* (0x7)
     FIRST_UNIT : 102
     NO_UNITS   : 30
     ID         : *unknown id* (0x16)
     FIRST_UNIT : 132
     NO_UNITS   : 1146
     ID         : *unknown id* (0x17)
     FIRST_UNIT : 1278
     NO_UNITS   : 536
     ID         : *unknown id* (0x18)
     FIRST_UNIT : 1814
     NO_UNITS   : 140
     ID         : *unknown id* (0xb)
     FIRST_UNIT : 1954
     NO_UNITS   : 50
  6. pogyhauler says:
    Ya, N900. late night scrambling.
    You’re a pioneer. good for you.
    Now, How’s ‘about you port Moblin to Every Nokia.
    While your at it, see what you can do about unlocking
    signed ROMs.
    Lemme know when your done.
  7. adam outler says:
    Didn’t nokia just sign with Microsoft Win phone7 for their mobile devices? Does that mean you get to take your BSOD with you?
  8. Bobstevejim says:
    @adam outler, RE: portable BSoD
    win.
  9. Aldo says:
    Nice reverse engineer on that Nokia.
  10. Terry_boy22 says:
    Thanks you guys, I will be trying this soon, once I get my Galaxy S2 Jigged, hope it works!
  11. brandon voigt says:
    HELP ME PLEASE!!! so i went to put run the clockwork mod on my phone i flashed it with the rom app then when i went to reboot it..it got stuck on the samsung screen. so i plug it on doing the hold volume button and the next screen that comes up is says warning a custom os can cause critical problems in phone and installed applications. if you want to download a custom os, press the volume up key. otherwise, press the the down key to cancel. up takes me to the downloading screen and down just takes me to the samsung screen. I was woundering what can i do to save my phone? i have the samsung infuse 4g. thank you for your help. Have a great day.
  12. unbrick all model android phones here for free. http://www.itcse.com/2012/08/unbrick-android-phone-touchscreen/
  13. ERIC MAC says:
    I am so frustrated ! I have a Samsung Galaxy S Stratosphere… its hard bricked coz Odin froze. I have tried everything to get it to boot. nothing is working ! your method doesnt work !!!!!!!!!!!!!!!!!!!!!!!!!!!! is there a way to fix this? all I get is the keyboard to light up… ive tried the Jig too… and nothing
  14. johndee says:
    bricked in download mode???
    you’re not bricked yet man..
  15. Gemma says:
    what does a custom os actually do?
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
