[Arthur Sacek] has really got something with the 3D Mill he built entirely from LEGO pieces. As you can see, it uses NXT parts to control the cutter head along three axes. The drill bit that acts as the mill’s cutting head is not a LEGO part, but that’s [Arthur's] only transgression.
The demo sculpture seen above was cut into a block of floral foam. The model was processed by Autodesk Softimage before being fed into the mill, where it took about two and half hours to complete the job. The foam comes out still in block form looking like a piece of outdoor carpeting. That’s because there’s no debris removal during the milling process. But hit it with the shopvac and you’ll reveal a physical model with surprising detail. We don’t think it comes close to the light-cured resin printing we’ve seen, but it would be a great asset if you’re doing some mold making.
Don’t miss [Arthur's] video of the milling process after the break.
Subscribe for weekly videos
neat hack, amazing resolution too, esp for logo!
I like the bit with the vacuum at the end :)
Now stick them in pretty vases with some flowers out the top – instant personalised gifts.
…I wouldn’t exactly say instant. –but that would be a neat idea. make some kind of glass frame for the sculptures, or even make little sculpted charms to fill in the space in the vase.
Is floral foam sturdy enough to be able to turn these into molds??
I’m sure it can be adapted to resemble a type of “cire perdue” casting method. Perhaps the material can be poured over having it incinerated on the spot like Styrofoam moulds.
@dgent — it’s sturdy enough for you to carefully make a mold from brushed-on RTV silicone. If you sprayed the surface with something hard like cyanoacrylate (superglue) or acrylic resin, you could probably do plaster as well. The real problem is that the foam disintegrates if you just brush it with your finger, so fine detail has to be carefully preserved if you want that level of resolution.
Car engines and a lot of other cast metal uses a process called lost foam casting. AFAIK the foam plus a sprue is packed in sand mixed with some sort of bonding agent. After the sand is cured, the foam is burnt out in a furnace leaving a cavity with a negative impression. This machine would work great for that, even if the rest of the setup is impractical for individuals.
Now you have me wondering.
Could you use styrofoam and a hot needle in something like this. If you could some how heat a needle and us it like a hot wire cutter That way you could have a more durable and accurate model.
@lwatcdr
soldering iron
Penn State has a pretty sweet foundry setup where I used to do a lot of lost foam casting as an IE student. We never used a binder on the sand or burned out the foam in a furnace. Basically we put the foam in a bucket, covered it with plain ol’ sand, and put it on a shaker table for a few minutes to settle the sand out. As you pour, the metal will vaporize the foam and fill the void. I can’t remember the accuracy we achieved with this method, but other types of sand casting can achieve +/- .020… not bad when you consider that’s the diameter of a single grain of sand.
You can spend the time burning the foam out before-hand, but that’s almost a wasted step (not to mention the cost of the binder you’re using). The main problem you run into with engine blocks and other large castings is all that foam-turned-gas needs to be properly vented. If your foam shape is designed to allow this, you’re golden.
with lego you can bild all the things you wand and make it work.this is a nice bild
meby hy can use bleu isolaion foam that is use in bildings.floral foam is good but can dry out in time
and it go to dust
Where did you get the extra parts for your build? My kit doesn’t have near that many parts (chains, etc.).
They look like Technic parts, but they could be from another series. I found this set that looks like it has the chain links (they’re separate links so you can make your chain as long as it needs to be…I think.) http://shop.lego.com/en-US/LEGO-Power-Functions-Motor-Set-8293
I’ve never really used Technic parts that much, so I’m no expert. Also, there’s always http://www.bricklink.com/ for those hard to find parts.
Hope that helps!
Good use of Legos, wouldn’t be much of a stretch to go 3D printing from there.
Can’t you cut faster with a slightly larger bit? I imagine you could go at least 2-4x thicker on the bit before you lose any real detail.
You would lose a lot of detail on concave surfaces. I imagine this setup would convert quite easily to a moving-base mill, though maybe you wouldn’t notice the difference in LEGO.
derpa is correct. You lose resolution with a bigger bit.
The faster way to do it is to change bits, but that requires more programing/changing tools. You use a coarse bit to remove lots of material at once, then the fine bit to detail it.
I think the X/Y motor speed may be the reason for such a long cutting time, on an industrial CNC mill, this should complete in nearly a fifth of the time out of similar material.
Usually there are 2-3 passes:
- first a fast&rough one with a large bit, just to get the most of the material out of the way.
- then a slow&fine one with a small bit. This creates most of the detail
- sometimes another pass like contour or waterline for stuff with sharp edges
drywall/cavity insulation foam would probably cut nicely on this and is a lot stronger than “oasis” floral foam
